Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Have sound, lose picture. D52W23
After being on for a period of time (varies from several minutes to hours) the picture will dim drastically and within a few seconds fade out completely leaving only sound. Turning it off for a couple minutes restores the picture but the problem repeats eventually.
  • RCA Master
  • 8,617 Answers
Sounds like a solder issue. try resoldering the Ics that are attached to heat sinks on the Board that has the flyback also resolder the flyback pin connections
Posted on Jun 18, 2008
Prima Cineplus 50" Plasma PH-50R18C will not turn on
The ambient temperature might be high. Check whether the foolinf fans are working or not. If not, check out the reason for it. The TV must be placed at least 6cm away from wall, and should have sufficant ventilaation.
Nov 15, 2013 | Televison & Video
Just tried turning i phone on after a couple of months of not using it but no joy. Doesnt even register its charging. Help
Hello teresadonach!
Your iPhone is probably fine! When a device using a battery isn't used for an extended period of time, the battery still loses its charge. More than likely, the battery is completely drained and will require you to have it plugged in for 15 to 30 minutes before even getting a charge indication. The time varies depending on device.
Keep it plugged in for about 2 hours and check back! As long as it was working fine when you stopped using it, it should power on!
Please remember to rate if this was helpful!
Mar 18, 2011 | Apple iPhone Smartphone
My KP-51HW40 clicks off after running for a period. The red power light blinks when it goes off but screen stays dark. When TV is shut off for a while it restarts and runs fine. The "On"...
KP-51HW40 shuts off due to incorrect white balance and blue arch lines is an evidence of that incorrect white balance. I hope tv standby red light would flashing 5 times then 3 seconds pause and again 5 times when tv shuts down.
This is rear projection tv that has three picture tubes (red-green-blue) inside to generate picture that projected at front screen. These three picture tubes must be drive with correct drive voltage to produce good picture of each color.
Solution for your tv problem is Screen Voltage adjustment that can be done easily if you are handy with electronics stuff repair.
Let me know your expertise level to guide you more and if you feel unconformable by tv repair then local tv repairman will help you to adjust white balance in tv.
Hope these info will help you.
Let me know if you have additional questions.
Thanks.
Nov 05, 2010 | Sony KP-51HW40 51" Rear Projection...
Lcd tv loses picture, power lght flashes grn; picture return
It sounds lamp is weak in TV and requires replacement.
I would be in better position to help you out if you post model and brand of your TV.
Dec 31, 2009 | Televison & Video
I have a Samsung HLN437WX DLPTV. The problem that
no if the lamp works fine for hours , could be a signal problem check signal connection and wiring
May 04, 2009 | Samsung HLN437W 43" Rear Projection HDTV
Excellent picture for a several hours, then gradually dims.
if this is a old unit the there is serious problem with the display.
check how many times the light blinks and get back to us.
Feb 08, 2009 | Toshiba TP43H60 43" Television
Projection TV
your problem is no doubt in the stand by circuitry You will have to trouble shoot your set as this is a thermal issue and you will need to do the testing of the various components while it is experiencing the trouble to find the problem. Let me know if you wat a manual. I can provide a link where you can get one .
Jan 22, 2008 | Televison & Video
Picture takes hours to appear
Spounds like the b+ feed filter capacitor off the flyback that supplys voltage to the three drive transistors on the crt board is bad.
Apr 16, 2006 | Sony KV-32V16 TV
Axim wont automatically shut off
I would guess your light should dim after 5 minutes. But I bet your axim wont shut off for 2,3, or 4 hours. My battery is wonderful so I have it shutting off after 2 hours.
Sep 14, 2005 | Dell Axim X5 Pocket PC
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
57 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
