Question about Poulan P3416 16Inch 34cc 2Cycle Gas Powered Chain Saw
Modle 2075 Replaced fuel hoses now wont start, It has fuel and fire. What should I check now?
    Brigadier General:
  • 4,088 Answers
Was it running before the replacement of the fuel lines? Does the primer bulb fill with fuel when pumped? Did you replace the line inside the fuel tank? Check the fuel filter, air cleaner, and muffler for plugging. Hope this helps!
Posted on Nov 13, 2010
I ran my 98 neon out of gas now it wont start an i replaced the fuel pump an still wont start
If it cranks good but won't start, have a helper crank it while you check for spark at the spark plugs. If spark everywhere, use a gage and check proper fuel pressure, also, check fuel injector pulse. Any applicable trouble codes?
I need more info, have you done any testing?
Apr 02, 2017 | Cars & Trucks
Ryobi wont start
Replace your coil and it should fix your problem
Sep 08, 2014 | Garden
I have a 1992 ford f150 pickup 2wheel drive it turns over and tries to start but wont it has new ignition cole new fuel pump new plugs and wires new distrubutor and cap all from napa and it still wont...
Is fuel getting tho the cylinders? Remove the fuel line at the intake manifold, put the hose in a container, try starting see how much and how fast is the fuel coming out. If normal, fuel is not the issue. If not check the fuel filter and lines. Is it getting enough air to start? Remove the air intake hose, see if it starts, if it does the air filter is most likely severely clogged.
Aug 16, 2014 | Cars & Trucks
Saw will not start and getting fire
Try checking the fuel filter. Open the gas tank and look inside the tank. You will see a plastic hose inside the tank. Pull the hose out and on the end of it is the fuel filter. Chances are it needs replaced. If the saw is getting fire but won't start it has to be a fuel problem. That is where you need to start at
Mar 03, 2014 | Husqvarna Chain Saw with 18" Bar
Car wont start and i have fuel pressure to the bleeder valve on fuel rail but it wont fire.I replaced fuel pump and filter recently.But when I spray starting fluid into air filter it will fire .What could...
check your fuel pressure regulator its location should be on the fuel rail.Pull vacuum hose off regulator if fuel drains out of it then the diaphram is bad. Hope this helps!!
Apr 20, 2011 | 1994 Oldsmobile Ninety Eight Regency
I replaced fuel line from carb to intake and now it wont start?
Check the carb fuel stub to see if its seated in the hose. Chech to see if you re-installed the piston underside scavenge hose to the bottom stub of the carb. Check your compression. New is 160 psi, operational but problematic (hard start) 130~140 and completely toast at 90. This saw is easy to flood when compression has fallen off. Cold start, 3 pulls choke on with the throttle trigger locked wide open. At first sputter, put choke in normal run and it should fire by the 3rd pull. If not its flooded. Then remove the plug and with an air hose vacate the cylinder of fuel for a few minutes and try again without the choke or throttle lock set at wide open.
Good luck.
Nov 27, 2010 | Makita DPC7311 73cc 14Inch Gas Powered...
Got a good one. my 91 coupe original 5.0 car. motor is new. it ran for two days then went to fire on third day and now will crank and crank but wont fire. got 42psi on fuel pressure 148psi compression on...
the fuel injectors are fired by computer producing a ground signal to them. so its unlikely they are fireing at once.possible power supplie problem but that would cause no injector pulse.beings how the engine was just replaced i would go over every wire and all grounds to make sure they are not shorted or pinched under a manifold or something.if you pull the plugs and they are black then you are getting to much gas. in wich case i would check to see if the fuel pressure regulator diaphram may be ruptured.if you take off the vacuum hose to it and look for moisture from gasoline. or leave hose off and try to start it if gas squirts out that regulator is bad and needs replacement
Apr 15, 2010 | 1991 Ford Mustang
Turns over but wont start.
Start by checking if it's a fuel or fire problem. Take a plug wire off and turn motor over.If there is fire, Take the hose going from the air cleaner to the throtle body off and spray a small amount of carb. cleaner in.If it's a fuel prob.,check the fuel pump relay (under the hood in a black box) (swap the relay out with another relay in the box ) If the relay is o.k., it's probly the fuel pump. If it;s a fireing prob., start with the coil and wires going to the coil.
May 19, 2009 | 2003 Kia Sedona
Poulan P3416 16Inch 34cc 2Cycle Gas Powered Chain Saw Logo
145 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
