Question about Frigidaire Dryers
Frigidaire FEQB4000FS - lights are on and I can select to start the load, the light turns on saying that it's drying and there is an autable click, but nothing happens.
applianceboy
  • 77 Answers
SOURCE: Neff Tumbledryer
dont know much about commercial units but if it was a residential unit i would first check the door switch. in res machines it cuts the power to the motor only so every thing works but it wont go.
Posted on Nov 08, 2008
rickzilla
  • 706 Answers
SOURCE: HELP Whirlpool dryer LEQ9508PW1
Hello beeps299,
If your Electric Dryer isn't doing anything at all, I would encourage you to do a few basic checks..
First off, are you sure that the circuit breaker feeding power to the dryer hasn't tripped?
If that's OK and you are sure you have power getting to the dryer then the next thing to check would be the door interlock switch. If that is not working properly when the door shuts, that disables most other functions. The switch could be defective, the wiring that goes to it may have gotten disconnected or damaged so that is where I would start to look first....
Hope that helps.
Other things that may impact the dryer are non-resettable fuses inside but I wouldn't go that route until you've checked the basics.. Let me know what happens after your initial checks are done..
Regards,
Rick
Posted on Nov 22, 2008
aborcass
  • 2651 Answers
SOURCE: Frigidaire Affinity Door Lock
under 1st yr warr, sure if thats he issue they would cover, it, a clogged drain pump may cause the same problem though , not being able to drain water , the pump would just hum.
Posted on Dec 03, 2008
SOURCE: dryer wont run
I had the same problem. It was the door switch. cost me about 8 bucks to fix.
Posted on Jan 17, 2009
SOURCE: Dryer will not dry - drum will not turn
Just happened to mine also. The problem was that the Idler Pulley came loose from the drive belt. There is a switch on the idler pulley so that if there is no tension on it, the motor will not start and you will have the symptoms you describe. To reattach the Idler Pulley, remove the back plate surrounding the dryer exhaust. This will give you access to the Pulley. If the belt broke (unlikely with a new dryer such as yours), the fix is more involved. This dryer is the same as the Maytag MDE6700 - you can do a search for a service manual for that model and you can see the details. Hope this helps.
Posted on Jun 04, 2009
All else appears to be working except the dryness level selection button does not light up and will not allow selection
How do I read the digital display panel and controls on my ...
www.samsung.com/uk/support/skp/faq/1025253
Samsung ElectronicsAug 12, 2014 - The Drying light will illuminate and remain lit until the cycle is ... the indicators will light up until you press the Start/Pause button. ... When you turn on your dryer the Cotton Cupboard Dry cycle is selected by default. ... Drying Level button ... If you do not turn the Drum Light off within 5 minutes of turning it on it ...
Dryer Control Panel And Functions - Samsung
www.samsung.com/ca/support/skp/faq/230147
Samsung ElectronicsJan 7, 2015 - To set Dry Level in the Normal, Heavy Duty, or other Sensor Dry ... An indicator light illuminates next to the selection. ... Temp Selection Button ... When using Manual Dry, you can select the drying time by pressing the Time Selection Button. Important: Clothes may not dry completely if the drying time is not ...
MACHINE OPERATION
docs.whirlpool.eu/_doc/501930002795EN.pdf
Material thickness: whenever there is greater load than the dryer can handle, ... Do nottumble dry: nylon stockings, delicate embroidery, fabrics with metallic ... The indicator lamp above the relevant button lights up to confirm your selection. ... Wait at least 5 minutes, to allow the laundry to cool down, before you unload the ...
501930001546EN.pdfDOWNLOAD
Jan 01, 2016 | Dryers
FRIGIDAIRE FRONT LOAD WASHER WON'T START. DOOR LOCK WILL NOT LOCK. DOOR LOCK LIGHT IS OFF. PULL START HANDLE OUT/ NOTHING. HEAR CLICKING WHEN TURNING SELECTOR SWITCH/BUT WILL NOT LOCK DOOR OR TURN LIGHT ON...
Good Morning REDS, thank you for your inquiry!
I understand that your door indicates it is open and your washer will not operate. Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn on the washer. Select a normal cycle, confirmed the latched is securely latched and verify if the washer will start. If the washer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. At this point, it would be advisable to contact an experienced appliance repair tech to assist further.
Sep 11, 2013 | Frigidaire ATF6000ES Front Load Washer
I have a frigidaire gallery front load washer that won't start a regular wash cycle.When i select a regular cycle and pull up the start knob,the cycle light comes on and nothing happens.When i mov
Good Afternoon Leszek - Thank you for your question. Based on the symptoms you are describing it sounds like the unit has a faulty timer or a potential wiring failure. Try reprogramming the unit by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn on the unit. If issue persists, then at this point I strongly suggest reaching out to a professional that can accurately diagnose and repair the washer.
Jun 09, 2013 | Frigidaire Washing Machines
I have a stackable Frigidaire Gallery Dryer. It won't turn on...
turn the start and it's like the drum gets stuck. then starts smelling like burning.
Mar 05, 2010 | Frigidaire Dryers
Blinking AD
AD is auto dry you may need to clean the sensor or you may have a fauilty one ...Auto Dry Loads dried using the Towels, Heavy Duty, Normal, Perm Press, and Delicates cycles will dry automatically at the selected temperature to the desired dryness level. The dryer uses sensing bars to sense the moisture level of the load as it tumbles through heated air. Auto Dry cycles save time and energy and protect fabrics. The estimated drying time will be displayed for about 5 minutes, then the outside of the display will light up in a circular track to indicate the drying time is automatically being determined by the sensors. When the load has reached the selected dryness level, it will continue to tumble, unheated, during a Cool Down period. This helps reduce wrinkling and makes items easier to handle during unloading. The estimated Cool Down time will be displayed. Drying time varies depending on size and dampness of load and fabric type. If the load is too small or almost dry, the sensing bars may not detect enough moisture to continue the cycle and the cycle may end after a few minutes. Select a Timed Dry setting to dry such loads. Room temperature and humidity, type of installation and electrical voltage or gas pressure can also affect drying time. For cycle selection turn the knob on the front of the dryer control panel. The light will illuminate next to the cycle selected. The following is a brief description for what cycles should be chosen for certain items and materials to be dried.
Sep 18, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Beeping Sound on Dryer
okay, this same problem happen to kenmore elites, the touch panel will automatically come on and beep even when it suppose to be off, replaced not the board but the touch panel and you will be okay.
Aug 17, 2009 | Frigidaire FEQ1442ES Electric Dryer
Wont' turn on
Push the "Heat Dry" button for at least 5 seconds. After that you should be able to start your dishwasher. The owner's manual I have says nothing about this, but this is a "lock panel" feature for the electronic panel design dishwashers. I just had this problem and stumbled upon a service manual online. Saved me $75.00.
May 04, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
High efficency dryer won't spin-Frigidaire
Try this. Set the timer. Open the door, press and hold the light switch. Rotate the drum by hand then while still holding the light switch turn on the dryer. If it starts then clos the door while removing your finger quickly. If this problem persists it could be the starter on your motor.
Mar 22, 2009 | Frigidaire FEQ332E Electric Dryer
Wont start. no error. If press start, every light above the start button light up
Perhaps the control lock light is on. Press options and select at the same time for about 10 seconds to turn off light. That should get you going
Oct 15, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire GLEH1642DS1
Check the door switch on the dryer to make sure the leads are all on.Check your thermal fuse .Its likely that its one or the other.
May 20, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Dryers Logo
108 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
