Question about LG 42LC2D 42 in. LCD HDTV
I get sound but no picture on my LCD tv - LG 42LC2D 42 in. LCD HDTV
  • LG Master
  • 5,100 Answers
It's a backlight or backlight inverter issue. (The backlight itself usually fades or makes the on-screen image change to pink/red.) With a bad backlight, you'll usually see a very dim image if you look at the TV from an inch from the screen. Block the room light from overwhelming this image (sometimes a carefully positioned flashlight will help you see something). If the inverter or video board is bad, you will see nothing. For an out-of-warranty TV, open up the back of the TV and remove the shielding. Look for any scorch marks or bulging or damaged capacitors. (Sometimes other parts will fail on this part but these can be spotted easily. Capacitors look like cylinders on a tripod.) The scorch mark and smoke may indicate a resistor or zener diode that had been used as a fuse and is now gone.
If you borrow (or have a) high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the inverter board and power up the TV. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency.
In either case, you can buy a replacement inverter for $50-150 and just do a simple swap. Disconnect all of the wires (connections are similar to molex and ribbon cables in a computer) and remove board (a few screws usually). Connect the cables to the new inverter. (If you google backlight inverter replacement, you'll find videos and text descriptions.) Note the part number on the board, including the Rev number, and order the exact one (shopjimmy.com or lcdparts.net are good starting points). Universal inverters do exist but can result in reversed controls (up to lower the brightness). Replacing individual parts on the board is cheaper but more prone to not tracking down all of the bad parts.
If the inverter is good, then it's probably backlights themselves (several in most TVs). These are sandwiched on the perimeter of the TV (usually under some tape that holds the lamp, reflector and other parts together. You need to order by length and width and get ones for your TV size. Separate the panel from the bezel. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything. See http://www.lcdparts.net/howto/default.aspx for more information but for an overview: http://www.inventgeek.com/Projects/BacklightFix/overview.aspx Then push the new backlights into place, reconnect the wires and close up the sandwich of tape and other parts around the screen. Then replace it in the bezel.
With a good spare backlight, you can test an inverter for condition (plug together and turn on the tv while the box is open). Similarly a good inverter can test the backlight.
I hope this helps.
Posted on Nov 13, 2010
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
Turned on, has sound but no picture. Why?
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
My tv stopped working, it had the sound but no picture, so I did a little ... +ducksfans76 have you done the flashlight test? what that is is turn the tv on in a ... screen that means your backlight is out and with LCD tv's most likely is the inverter. ... Samsung Flat Screen No Picture Only Sound 002 - Duration: 1:26.
Repair A TV With Sound But No Picture - YouTube
? 2:30
https://www.youtube.com/watch?v=MQj2t4nNVYc
Sep 18, 2012 - Uploaded by MonkeySee
Learn how to troubleshoot your television if you've got sound but no picture. ... I have a logik lcd tv and for some reason thescreen always turns ...
Dec 25, 2015 | Sanyo Televison & Video
We have sound but no picture
? 4:52
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 467,264 views. 2:30. LCD & LED TV Repair - No Image ...
How to fix sony bravia has black screen - Digital TV - Streaming ...
www.tomsguide.com/forum/56867-4-sony-bravia-black-screen
Aug 19, 2014 - 12 posts - ‎11 authors
Hello, My Sony Bravia TV screen has gone all black. The green on/off light comes on,but no picture appears. The model ... Your solution solved the non picture for live tvbut still no picture (just sound) fir OnDemand. Score. 0. No picture on LCD TV with HDMI cable plugged into ...
Aug 4, 2014
Tv problems picture ok but no sound - HDTV
Sep 8, 2011
More results from www.tomsguide.com
Dec 14, 2015 | Sony BRAVIA KDL-55XBR8 55 in. HDTV LCD TV
Sounds from tv when titles appear
U mean the tv have pictures flashes only a few sec. than dies have the tv pragram sound left only?Yes? Mean ur tv have a tv LCD Screen Panel have no tv LCD screen backlight to produce tv pictures tv now are having backlight problems.The tv have 1 or 2 long boards that are called LCD inverter boards problems and the causes.These 1 or 2 long Lcd inverter boards only job are to produced backlight for the tv LCD screen panel to hold on to give the tv screen panel to have pictures only.Tries websites like Shopjimmy.com,EBAY.COM to those refurbishes 1 or 2 long LCD inverter boards for the replacement.
Oct 03, 2011 | Philips Televison & Video
My new 55in sanyo lcd tv has sound but no picture. The tv is one week old. Is the problem the backlight or something else?
Tv only a week old take it back were u bought it,trade it in for another tv.Tv have a picture than flashes only a few sec. than died have sound left only?Yes,than those tv 2 long LCD inverter boards are dead.These tv 2 long LCD inverter boards are only to help the tv to have a backlight for tv LCD screen panel only to produced pictures.
Jul 14, 2011 | Sanyo DP46849 46 in. HDTV
Sound on tv but no picture.
Replaced the LCD inverter it dead.Replaced that board u will get picture back.It usally a long board..
Jan 19, 2010 | Vizio VO47L 47 in. LCD TV
LG LCD TV no sound
LG tv flatron no sound, picture everything else is fine but no sound what can be done to fix it
Jun 16, 2008 | LG 42LB1DRA 42 in. LCD Television
Repairing lcd tv.
thanks very much about your technical support.but i solve allready the problem of LG LCD TV MODEL LT-15A10 TROUBLE; no picture with sound, i replace the socketed ic SDA555XFL62 PINS. THANKS... LODIVAR.
Feb 17, 2008 | Audiovox VE920 9" ULTRA-SLIM DROP-DOWN LCD...
LG 42LC2D 42 in. LCD HDTV Logo
135 people viewed this question
Computer Repairing
Computer Repairing
