Question about Lexmark X1150 All-In-One InkJet Printer
Black will not print at all
I have had issues with this printer not printing in Black for a while. I replaced the cartridge and then it started streaking so I clean and clean but it still won't print correctly. Now even though the ink cartridge is full it will not print out in black at all.
  • Anonymous Jun 27, 2008
    no printing black
  • glo1 Nov 06, 2008
    My Lexmark X1150 All in One Printer will only print in color. I have tried almost everything and it will not print in black and white. The ink level indicator doesn't show that the cartridge is empty. Does anybody know what is going on?
It says you have a best solution but i clicked all over the page and i can't get anything but an advertisement for hp ink to come up and i'm dealing with a lexmark printer. i'm sorry but this site is just a waste of time.
Posted on Oct 29, 2008
PRINTER MODLE X1185
Posted on Jun 18, 2008
I've a 564XL black cartridge when inserted into a HP Photosmart 7525 refuses to print...it happened while trying to print TICKETS WORTH $261 for an event this Sunday, the 25th...HELP......ROBE
The expiration date should not be of any problem. When the printer has an issue with the cartridge, it could be the contacts in the printer or on the print head are not clean or shiny. It looks as a communication problem. When the printer does not give an error, you just won't get black the hear must be cleaned.
OR when cleaning does not help we need a hefty measure.
When the print head is not on the cartridge, and cleaning does not work, remove the cartridge and let a drop of cleaning fluid fall in the nozzle, where the ink should go in. place the cartridge back and let the printer print a few pages of black. (just some text pages with black bold type face would do. Let it print till you see the printer is starting to show text, Then again do a clean cartridge and the printer should be fine for a while.
Jan 23, 2015 | HP PhotoSmart Office Equipment & Supplies
SLOW PRINTER
You have a cartridge problem.
This condition is typically caused by one of the cartridges failing. Try removing the black cartridge and printing (not copying) a test page. If this prints at near normal speed the black cartridge is at fault and should be replaced. If the printer still prints slowly then put the black cartridge back in and remove the color cartridge, then print a page. Replacing the cartridge that causes the slow printing with a fresh cartridge will resolve the issue.
May 03, 2012 | HP Office Equipment & Supplies
HP Office jet printer slow
I think it's that black cartridge!
The problem you've described is typically caused by one of the cartridges failing. Try removing the black cartridge and printing (not copying) a test page. If this prints at near normal speed the black cartridge is at fault and should be replaced. If the printer still prints slowly then put the black cartridge back in and remove the color cartridge, then print a page. Replacing the cartridge that causes the slow printing with a fresh cartridge will resolve the issue.
Assuming the cartridges are original HP (not re-manufactured or refilled) you can check the warranty status by CLICKING HERE
Let me know how you make out.
Ben
May 03, 2012 | HP OfficeJet 7410 All-In-One InkJet...
I'm getting an error code 59.60 on our HP 3015 printer. Last week I had to change the toner cartridge because we were getting a smudge on one side of the print. Could this be related? A bad printer...
Error 59.60 is an issue with the black cartridge motor starting up.
Check that connectors J5006 on the black print-cartridge drive motor and J208 on the driver PCA are seated correctly. Replace the black print-cartridge drive motor. Replace the driver PCA.
Feb 28, 2011 | Office Equipment & Supplies
The printing speed slowed to a snail pace. I pressed Setup, 2, and then 6 to print a self-test report. I got a a "cartridge error" message. Then I removed both cartridges and cleaned them. Still...
This is caused by the failure of one of your cartridges. Remove the black cartridge and print a test page. Does the printer print at normal speed? Is so the black cartridge was the issue and should be replaced. If not then put the black cartridge back in and remove the color cartridge and print test page. If the printer now prints normal speed the color cartridge was at fault and needs to be replaced.
please vote for better sharing.. thank you and good luck
Nov 24, 2010 | HP Officejet 5610 All-In-One InkJet...
I have a Kodak printer ESP5250. I have replaced the black ink cartridge, done a printer head alignment, and cleaned the printer heads. When I print a black and white printout I only get the outline, the...
Did you replaced the cartridge because of this issue or because it was depleted?
Since Kodak cartridges have the Print head attached to each cartridge it may be that the cartridge it malfunctioning.
To Test use a lightly damped paper towel and put the cartridge or print head where the ink comes out in top of the paper towel if ink start flowinf to the paper towel then the cartridge is fine, otherwise try to exchange that cartridge for a new one.
Oct 30, 2010 | Kodak ESP 5 Printer
Ok I have a cx8400 all-in-one Epson printer. I was out of black ink so I started using composite black. Also ran out of color ink so I bought the black cartridge and installed it. Now the printer says i...
If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until a cartridge needs replacement. You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expendedI have come across this issue many times and unforunately you have to replace the colour carts in order to continue to use the printer.
Sep 12, 2009 | Epson CX8400 All-In-One InkJet Printer
Print cartridge missing
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier.
Next, try this printer self-test by following the steps given below:
1. Please turn OFF the printer.
2. Press and hold the "Color copy" button.
3. Now, turn ON the printer.
4. Once you see "0" on the display, release the "Color copy" button.
5. Press the Up arrow button until "2"appears on the display.
6. Press the "Black copy" button to start the self test. Once the page has printed, the printer will stop printing.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed by itself. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let me know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Apr 13, 2009 | Lexmark X2650 All-In-One InkJet Printer
How can I print Black only?
Hi
HP Inkjet printers work only if both the cartridges have ink unlike HP Laserjet printers.
If you want the printer to print only in black, Follow the steps
Start --->Control panel -- >Printers and faxes ---->Right click on the printer icon (HP c5100) select printing preferences.
Under printing prefences there u will see an option to print with black or print in gray scale.
Note:HP Inkjet printers like Photosmart C5180 will work only both the cartridges have ink.
Thanks
Riz
Jul 26, 2008 | HP Photosmart C5180 All-In-One InkJet...
Black ink does not print
I have a problem about my printer here. it doesnt print black color even if i replaced it with new cartridge...anyone have solution about this pls help....joy
Feb 16, 2008 | HP Photosmart C3150 Printer
Lexmark X1150 All-In-One InkJet Printer Logo
79 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
