Question about Panasonic SD-YD250 Bread Maker
Panasonic bread maker container
The mixing blade will not turn and seems to be "frozen" in position. What is the solution as it cannot be turned by hand either.
Soak in in hot, hot water. Grab blade and under part and wiggle in different directions. It shoyuld come loose.
Posted on Aug 06, 2008
I have had a Panasonic breadmaker from Jan 2009 and it has been in regular use without problems. Recently on several occasions (not consecutive) the dough paddle has become detached during the mixing...
The kneading blade on the Panasonic bread makers is designed to fit loosely. If the dough is 'stiff' the kneading blade may stay in the bread when the loaf is removed from the pan. Allow the bread to cool completely before removing the blade carefully. Some types of flour absorb more water than others, so you can try adding an extra 10 - 20ml of water next time to see if this results in a slightly less 'stiff' dough.
This problem can also be caused if crust has built up underneath the blade. Make sure to wash the blade and its spindle after each use.
Trust this is helpful. Thank you for using FixYa!
Oct 19, 2011 | Panasonic Kitchen Appliances - Others
I have SD-YD150 Panasonic bread maker,but missing the mixing blade. Where can I get one?
ioffer is a good place to look. Just go to the internet and find them and begin searching.
Aug 11, 2011 | Panasonic SD-YD250 Bread Maker
My Toastmaster TBR2 bread machine does not knead when started. It makes a tick-tock noise and the timer counts down but no mixing. The bread pan is positioned correctly. Why?
Make sure you are programming your machine correctly.
The Instruction Manual indicates three possible problems, none of which would seem to be your problem. Not plugged in, error message or kneading blade missing.
Suggest you review the Instruction Manual for programming your bread maker. Unplug your machine to reset and then plug in and program as directed.
TRB2 Instruction Manual:
http://dl.owneriq.net/4/4ae504be-4834-4845-a8f8-7a6df62c1033.pdf
Jan 22, 2011 | Toastmaster TBR2 Bread Maker
The dough doesn't seem to be mixed properly. I can see the yeast particles, the dough is tough and not-elastic. Doesn't seem to have risen. When I put it in a warm place to rise, it seems to rise a...
Hi, It could be that the paddle is sticking or the belt is slipping. This would cause the ingredients not to be mixed properly. Take the empty pan and paddle out of the machine and see if you can spin it freely by hand. It shouldn't stick. If it does stick then the sealed bearing is frozen and a new bread pan is needed. If everytrhing is fine, then check the belts. Belts and motor are located in base of the machine. Unplug machine before working on the belts. Hank
Nov 11, 2010 | Panasonic SD-YD250 Bread Maker
Why did the kneading paddle on my 1148X bread machine quit working. This happened the third time it was used. It did the initial mixing and resting. When it started the kneading process again, the blade...
Hi, If this is the third time using it, it could be defective. Return it for service. If not under warranty, try a few things. 1) Make sure the pan is inserted in the machine correctly. 2) Make sure that the paddle is not sticking, or the sealed bearing on the bottom of the bread pan is not broken or frozen. (Take pan out and see if you can turn the paddle freely by hand). Or finally, the belt may be loose and slipping, especially when it takes more power to knead the dough the second time. Good luck...Hank
Jun 12, 2010 | Toastmaster 1148X FastBake Bread Maker
I have a panasonic breadmaker SD 207 and Icannot
I think the best place to try is Ebay.UK I found this one there...maybe it will fit. Seems they all look alike. Good Luck, Hank
http://cgi.ebay.com/PANASONIC-BREAD-MAKER-PAN-KNEADING-BLADE-SD206-SD200_W0QQitemZ310127333030QQcmdZViewItemQQptZUK_HGKitchen_SmallApp_RL?hash=item4835078ea6
Jan 28, 2010 | Panasonic Kitchen Appliances - Others
Mixing paddle won't turn.
The mixing paddle is supposed to turn by means of a lubricated bearing. This bearing is broken or stuck so the blade will not turn.
Try soaking it overnight in soapy water. If that does not work it's time for a replacement pan if you can find one.
Hank
Oct 04, 2009 | Sunbeam 5833 ExpressBake Bread Maker
Rotating Shaft of Hitachi HB 101 frozen and won't move blade.
It can't be repaired. If machine is under warranty try to get a new bread pan. If not, try calling manufacturer to see if you can buy a new one.
May 27, 2009 | Zojirushi BBCC-X20 Home Bakery Supreme...
B&D Bread maker all in one
I think the problem is that the bushing - the tubing that the paddle passes through - wears down (corrosion) and jams after a few years. I took mine apart and found that was the case. So a new pan has to be ordered. I'm trying that out now via the B&D 1-800 number.
Jun 12, 2008 | Black & Decker B1561 Bread Maker
Panasonic SD-YD250 Bread Maker Logo
129 people viewed this question
Top Panasonic Kitchen Appliances - Others Experts
Irene Tulloch
Oloyede Monsuru
Are you a Panasonic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
