Question about Telex HR-1 - Single Sided Headset with Boom Mic 300534007 Headset
I want to buy telex key board for a IMT telex machine (model tlx10B) Databyte. where can i get that?
Pressure Control Solenoid C - Coe P1078
06 CR-V
when you hit the dear, things can break. what's surprising there?
id get a car safety inspection, road worthy ness checks.....really.
google is not your friend here, not for P1 codes. (unless very careful)
and the P1078 code only works on Hondas.
Not only that autozonded scans may show the wrong code.
why? because their scan tool is junk, ! (SSDD)
the FSM covers that 100% read that. for all the tests.
ill pretend the scan tool is not junk and reads Honda's correctly.]
P1 codes are factory codes, and reading ford, or chev or ? on that will
all be lies. P1078 is:
DTC P1078:
Intake Manifold Tuning (IMT) System Malfunction (High rpm) Stuck
Long.
DTC P1078:
Long
P1078-0570
General Description
The intake manifold tuning (IMT) valve position sensor is mounted on the diaphragm valve shaft to detect a malfunction in the IMT valve.
The engine control module (ECM) / powertrain control module (PCM)
checks both the IMT solenoid valve command and the IMT valve position sensor output.
If the IMT valve position sensor output is Short (short runners) while the IMT solenoid valve is OFF, a malfunction (IMT remains Short / closed ) is detected and a DTC is stored
(what does this mean)
bar stool answer.
the deer hit my car.
the vacuum line fell of the IMT VSV and now the slave sensor fails.
there are 3 parts to the VSV (PCM command) sends vacuum
to the slave , then slave rod moves, the sensor in the slave
(readback pot) shows that it did move correctly
yours is stuck long.
Feb 24, 2014 | 2006 Honda CR-V LX
Telex HT-100 with TE-10 head pulled off
I realize that this question was asked in December of 2011, but I just now found this question on this website today.
Here's a picture that I took of the Telex HT-100 wireless microphone transmitter that I have showing the wiring on the circuit board.
The green wire gets soldered to the lead of the 10 Megohm resistor that you can see in the picture.
Dec 28, 2011 | Telex Audio Players & Recorders
I have an OLD telex projector. Looks like a box with a tv screen on one side and carousel on top. have no idea how to use it. maybe bulb needs replacing
Telex called those "CaraMate XXXX" (XXXX usually relating to model number ). The old ones projected on the internal screen. Newer models could project both on the internal screen and (by sliding a door on the top panel) on a projection screen for larger audiences.
If it needs a lamp, check with: www.bulbman.com But you may have to search - - it's been a long time since they were manufactured!
Good Luck !!
Jun 21, 2011 | Telex Office Equipment & Supplies
I belong to a local church and they have a TELEX WWT-55 unit which is missing the Belt clip. Any suggestions as to where I can find one. Area is West of Boston Ma. Natick or Framingham. Appreciate any...
Telex is an Electrovoice product, based in Minneapolis MN. Check their website for customer service, and a phone number. They are always happy to help.
If the product is older and has no replacement from the manufacturer, you may need to search online for auction sites that may sell older systems.
God Luck.
Feb 21, 2011 | Telex WT-55 Belt Pack Transmitter (027)...
Telex WT55 wireless lapel mic & FRM70 Receiver
How do I set the squelch on a TELEX FMR-70 receiver?
Jan 27, 2009 | Telex FMR70 VHF Wireless Microphone...
Telex ProStar VR12 VHF needs repair
I've been in contact with Telex and although the Prostar is obsolete they still maintain some repair parts. I would contact them:
http://www.telex.com/Support/
Jan 07, 2009 | Telex FMR-200H Professional Microphone
Furuno 1552
Howdy John;
You might try going online to Ham radio outlet, they carry just about everything for ham radio. your telex kit may not be made any longer but you might be able to use a Terminal Node Controller in its place. Kantronics makes one of the best TNC's around.
Pat N5SLI
Jul 21, 2008 | Furuno FS1503 (199 Channels) 2-Way Radio
DVD Duplicator has taken a crap!
DVD burners only last so long unfortunately! I've replaced many myself and have found that it's also not worth buying any lite-on in my opinion. Have a look around using the link below and you'l get a decent brand at a low price. Once a DVD writer has burned lot's of discs the lens itself becomes burnt out as far as I am aware, sometimes after 200 burns with cheap ones.
Individual drives - the pioneer at £18.99 isd a great buy!
hope this helps
Dec 16, 2007 | Telex SpinWise Seven Drive (301735000)...
Telex Spinwise CD-DVD Duplicator - Source Drive Read Disk Error
i have a telex Spin dupilactor Cat/Model # 301931000*4-16D and i am Looking for a price to insure it. a replacement price
Oct 19, 2007 | Telex SpinWise 7-824D (301689000)...
Radio Communications Logo
Top Telex Radio Communications Experts
Mike Charette
Andrew Taylor
Andrew Taylor
Are you a Telex Radio Communication Expert? Answer questions, earn points and help others
