Question about Indesit Dishwashers
Lights 1 and 2 flash together. Come on after 3 minutes or so whatever the programme. No sound of pump emptying machine. Help :O)
  • 13,433 Answers
1+2 is a drain time out error, possible that there is some gunge or something in the drain pump. Pump blockages are common on these machines
Posted on Jun 18, 2008
The washing machine will run a complete cycle perfectly, when i then empty it and refill with dirty washing, i put it onto the programme and press start, the machine sounds like the motor is running to...
On some machines when you start a programe the pump may run for a short while Restart machine and just give it a try for 3/4 minutes first just incase.
Sep 15, 2010 | Washing Machines
The power is on the cycle light is on but on the right the first two lights are flashing together. help zanussi aqua pulse de 6744 s
Hi, the first thing the dishwasher does is fill with water, so this sounds like a Anti Flood water pump problem this is just behind the water pipe that feeds the clean water into your machine, one thing to check is if the machine is empty of water at the moment, if the machine has water in the bottom then it could be the Drain Pump.
Jul 29, 2010 | Zanussi 24 in. DE6744S Free-standing...
When i start my dishwasher it sounds like it is filling normally then error lights 1 &3 (3h&9h) flash rapidly and water begins to drain away
This indicates an error with the pressure switch and indicates that it is jammed on full. First try switching off ther AC power to the washer and letting it stand for 30 minutes. Then switch back on the AC power and see if the error is still present. If it is then the pressure switch will need to be replaced. The pressure switch is how the machine determines how much water there is in the machine and if the switch is indicating the machine is full it will automatically pump and empty as soon as new water enters the machine.
Nov 10, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Jul 27, 2009 | Washing Machines
Shortly after turning my indesit idl530 on a fault code appears
the problem you are getting is a f01 fault,this is water in the base part of the antiflood devise.to check this if you tip the appliance backwards and water comes from the back at the bottom this is the problem,if you do this till it stops and then leave for approx 24hrs to dry out any water that may have gone on to motor,then check by switching on to start a program,if appears to work ok but then goes back to the same fault(draining all the time and light flashing)you will have to remove base and check for leaks.
Jul 04, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
Error code 07 on my Aqualtis AQXXF
Might be a bit complex but this is your problem and solution
REMEMBER TURN THE POWER OFF
F07: Heater relay stuck or element open circuit
This fault is only signalled when pressure switch is in empty position.
Check the efficiency of edge connector J3 on module.
Check wiring to heater and continuity of element (25 ohms approximately).
Check the efficiency of pressure switch connections and correct operation of pressure switch,
and the pressure chamber is not blocked with sludge.
Remove edge connector J3 and check wiring and contacts at positions 2, 3 and 4 on J3.
If all above OK replace pressure switch, module or eeprom as required.
Jun 10, 2009 | Washing Machines
Lights keep flashing
Have you have checked the waste pipe is not kinked and raised to about level with the top of the machine? If you have checked these things it could be the waste pump located at the rear right corner in the base of the unit.
To acess the pump tilt the machine to 45degrees and remove the base plate(6 screws) remove the two wires from the float(brown and pink) and move the plate out of your way.In the rear right corner you will see the waste pump.remove the pump and check the impelor is turning freely.If not dissmantle the pump(3 screws)and carefully remove any debris.Re-assemble.good luck.
Dec 08, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit WIDL 102
almost certainly a new module and eprom. these modules have given a lot of problems.
not really worth doing
Jun 25, 2008 | Indesit W 123 Front Load Washer
Flashing lights indesit wil103
you will need to unplug the machine at the mains, give it two minutes and the auto door lock will release your duvet, however start saving the pennies as your pcb is knackered and you'll be looking at about £200 to fix it
Oct 25, 2007 | Indesit W 123 Front Load Washer
Dishwashers Logo
132 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
