Question about Neff H5470A0 900 Watts Microwave Oven
Hi we have a built in Neff H5574NOGB. It starts but cuts off after 3 seconds. At first this was intermittant, but now it does it all the time. The handbook says if this happens check that the door is closed - but it is. Could this be the door switch?
4 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: glass continually shattering on combination neff oven
That's a huge gap.
You might ask their customer service people to authorize the replacement of the whole door or the glass and the inner door panel where the gap is.
If they won't help you, you could clean it thoroughly, then carefully caulk the gap with high temperature caulk.
Posted on Oct 09, 2009
Testimonial: "Thanks for your help. Customer Services were no help. Can you please advise which type of caulking to use."
SOURCE: microwave starts as normal but cuts out after
This is happening due to either the magnetron, or the Power Diode, or both, is breaking down, under load, then the unit detects the fault condition, & then, for safety reasons, to avoid a fire or explosion, shuts down the system. You need to take it in to be looked at please obtain a "Quote" before proceeding with any work. This way you can decide to repair or replace.
Posted on Mar 24, 2010
Testimonial: "Excellent. Thanks so much for your very quick and valued help! Will do as you suggest and give further feed back on outcome. Again, Many Thanks. "
  • 8909 Answers
SOURCE: hi i have a neff
The magnetron is probably not working and the main board senses that.
Call an authorised repairer to fix it for you. There are no user serviceable parts in that section of the machine.
Posted on Feb 18, 2011
After approx a minute a regular squeak begins, occasionally missing a beat.Heating is fine.
If the "frequency" of the squeaking is a low frequency, the I would suspect the turntable motor or stirrer motor (if so equipped).
If it is a higher frequency, I would suspect the cooling fan or hood fan motor.
Dec 11, 2012 | Neff H7871 Convection/Microwave Oven
Neff h5972n0gb keeps cutting out after 5 seconds, any idea what the problem could be please. Thank you
Is it cutting out while working as oven or microwave or just after 5 seconds of switching on ?
Mar 13, 2011 | Microwave Ovens
Hi i have a neff microwave h5642nogb/02 when i switch it on to heat up food it cuts out after about 10 seconds can you please help
Feb 18, 2011 | Neff H5642 Convection / Microwave Oven
Microwave starts as normal but cuts out after
Mar 24, 2010 | Neff H5642 Convection / Microwave Oven
Neff microwave turns and lights when started but doesn't heat
check on rating plate if fd number starts with a 7 or 8 eg fd 7908 then appliance will need mag leads recrimping they oxidise over time and break connection giving syptoms that you describe, its an easy fix but you need to remove outer casing.
Feb 22, 2010 | Neff H5642 Convection / Microwave Oven
Microwave turns itself oo
it sound like the inverter unit is faulty or the magnetron is gone.the only real way to find out which is to change each one in turn,sorry i cant be any more help.if you have any more questions get back in touch,regards les
Jul 28, 2009 | Neff Microwave Ovens
How do you turn the beep off?
Finally worked out how to do this today! I don't know what model you've got (I don't know what one I've got - it's built in and we've lost the manual) but try pressing the START button for six seconds. This should change the default from 30 beeps to 3 beeps. Bliss.
Apr 16, 2009 | Neff H5470N0GB Microwave Oven
Neff combination microwave oven
We have had NEFF repair man out again and he replaced the door switchs and this time it is OK.He did say if it was a problem again it will be classed as unrepairable because he thinks it is shorting out on an internal rivet on the bodywork which is inaccesable. fingers crossed it was the door switchs and it dosent blow the main fuse again .thanks for your responce. Simon.
Jul 23, 2008 | Microwave Ovens
Neff H5642 1000 Watt Microwave
Sounds like the Magnetron may have collapsed. Probably not worth repairing. Check for burnt/browned components on circuit board/s. Burnt wires, insect or ant damage or soiling. Magnetron is the large-ish square metal object with lots of heat-sink fins on it. Check for discolouration. If nothing obvious, it's probably stuffed, If something is obvious, it's still stuffed, but it may be repairable.:::Spiceweasel.au
Apr 04, 2008 | Neff H5642 Convection / Microwave Oven
Neff H5470A0 900 Watts Microwave Oven Logo
110 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
