Question about Kenmore Dishwashers
Kenmore 16209, "clean" lite won't
  • jayerbes Nov 15, 2010
    Worked like a champ -Thanxabunch Daniel!
    Jay
  • 4,323 Answers
Hi
You can reset it by pressing these buttons 3-4 times in sequence: HIGH TEMP. WASH-HEATED DRY Hope this helps...please post back for further questions.
Daniel
Posted on Nov 13, 2010
OK- my Kenmore He2 won't spin fast enough to drain when there is a heavy load involved. This is what I've done- emptied the filter- lots of change and other gunk, cleaned out attached hoses and the p
Check the shocks on the drum to make sure they are ok. if they wear out the drum spins out of balance and the computer wont allow it spine because it would WALK and damage itself.
Apr 19, 2017 | Kenmore HE2 Plus Front Load Washer
My HE2 front loader has a problem draining. It will be "locked" after washing. It is either full of water still, or needs to go through an extra "rinse and spin" cycle to drain the...
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely, if the issue returns then it is time for a new pump. Hope this helps... Please post back for any further assistance.
Daniel
Aug 28, 2011 | Kenmore HE2 Plus Front Load Washer
Dishwasher will not run. Air Dry/Lock on light blinks and unable to turn off even if held for 4 seconds. If you press Start, "Quick Rinse" light comes on and blinks along with the Air Dry Light....
Sound like you might have a fallty drain pump. When you turn the power off and started again, did you hear noise of pump draining the leftover water. If not , then you have a pump problem. Need a service man. Good luck !
Feb 11, 2011 | Kenmore 16602 / 16604 / 16609 Built-in...
I have a Kenmore Elite HE3 washing machine that stops running and flashes "F" and then "02" on the display. Can you tell me what is wrong?
The fault code indicates a draining problem and the display can be cleared by pressing the Pause/Cancel button twice. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working.
Disconnect power and
remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Jan 07, 2011 | Kenmore Washing Machines
My Kenmore elite he3t is giving me a problem in the spin cycle. Even thought the spin setting is set on high or extra high, the drum turns very slowly and will eventually stop and the washer starts...
The machine will not advance to the high-speed spin cycle unless the water is drained first. The F02 error code manifests this condition as it means draining problem. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working. The display can be cleared by pressing the Pause/Cancel button twice.
Disconnect power and remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Dec 20, 2010 | Kenmore Elite 45986 Front Load Washer
Yes, probably a slow drain. F2 can indicate a long drain time. Press pause/cancel twice to clear. Disconnect the power to your washer, and clean the strainer. It is located behind the kick panel, between the drum and the pump. Remove the debris and clean. Caution, you will get water! Have something ready to catch it. Reassemble. Put the washer on the hottest setting available and run an empty, extended load with bleach. It may be necessary to do it more than once, but perservere, you'll get it. Run a last, empty load with just plain water, to flush the remainder out. This should do it.
Best regards, --W/D--. Please feel free to rate this solution!
Jul 26, 2009 | Maytag EPIC MFW9700S Front Load Washer
Washer problem
is there water in it .it may be that it cant drain so wont cancel because you would open door and water would spill out.if no drain check an clean pump.also so times pump seams as tho working[makes noise/voltage presant,but under a load wont work.use my advise and explore.God bless,tom
Dec 31, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite HE 3T front load washer
Hope this helps ...... F09 is a Overflow Condition If the Overflow contact on the pressure switch is Closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service. Potential Causes ? Check the drain hose and make sure it is not plugged or kinked ? Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU) ? Check/ Clean Drain Pump Filter of foreign objects ? Check for Drain Pump Failure ? Check the Inlet Valve for proper shut off ? Check the Pressure switch for proper operation PLEASE rate my solution
Oct 04, 2007 | Kenmore 44832 Front Load Washer
Dishwashers Logo
199 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
