Question about General Electric GE SmartWater Household Water Filtration System - GNWH38F
How do I drain my water heater if it has no drain valve.Model number is GE 20p6a
5 Suggested Answers
  • 3600 Answers
SOURCE: Drain Valve on bottom of water heater drips when Water IN turned
If the hot water heater is gas be sure it's turned off same if it's electric so you don't burn out theelements in the tank, I would advise you to buy some plumbers putty and pull the drain scre out and put putty in it then reinstall the screw. all the ones I looked at I could not tell by looking to see where the drain was and if it has like a hose bib on it or not. also pull the screw all theway out and see if you got some sand in the valve and if so use some compressed air in a can to blow the stuff out of the seating area of the screw. Hope this is helpful would be nice to have a picture of the drain.
Posted on Jul 26, 2009
co7196
  • 3433 Answers
SOURCE: GE Smart Water Heater - Model #GE40M06AAG - 40
There should be a faucet on the side . you hook up a garden hose and drain it.
Posted on Nov 18, 2009
  • 494 Answers
SOURCE: MY GE PRESSURE RELIEF VALVE HAS JUST STARTED
You can buy a replacement relief valve at any hardware or home improvement store. It's real name is a T&P valve or temperature and pressure relief valve. It always has a 3/4" inlet and outlet. It is a very easy procedure to replace. You will need a bucket, teflon pipe thread tape, and a 3/4" x 6" black iron or galvanized pipe nipple. To start the valve replacement, turn off the shuttoff valve on the cold water line. Then open the handle on the relief valve and drain water into the bucket, that is, unless you have a pvc pipe coming off of it into a drain floor, then just drain it without the bucket. Be careful, the water is hot! When the water level gets below the relief valve, it will stop draining. Then remove the pvc pipe, if applicable, and thread in the 6" pipe nipple to use as a leverage tool to remove the valve from the water tank. Turn it counter clockwise to remove. Then put teflon tape on the new valve, going from left to right with the valve threads facing downward. Wrap about 3-4 layers all around the threads. Then twist the new valve into the water tank clockwise and using the pipe nipple tighten by hand until very snug and outlet is facing downward, as before. Remove the pipe nipple and install pvc pipe, if applicable. Leave valve handle open and turn on the cold water until the valve starts spitting, then close the relief valve and let it fill up the tank. If you did it correctly, you are now finished! Good luck!
Douglas
Posted on Jun 14, 2010
FixYaSteve
  • 57 Answers
SOURCE: how do i determine the manufacture date for a h w
GE uses MMYY as the first four digits of their serial numbers. That unit was manufactured in August 2001.
FYI, a nice little page on decoding water heater manufacture can be found here.
If this answer was helpful, please give it a vote. Thanks.
Posted on Jun 15, 2010
How do I drain a GE GG40T6A gas hot water tank?
http://waterheatertimer.org/Water-heater-will-not-drain.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Turn power off, turn water off, open tub spout, Connect hose and open drain valve?
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 18, 2014 | Water Heaters
Drain wont stop leaking
1) Copy following link for fixing drain valve on 38 gallon gas water heater with plastic drain valve.
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
2) According to serial number, your GE (Rheem) water heater was made in 3rd month of 2007. No service manuals are available from Rheem. Warranty period is probably 6 year. Unit appears to have reliable White Rodgers gas control valve.
http://waterheatertimer.org/How-to-maintain-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
3) Add comment and say what you discover.
Feb 18, 2013 | Water Heaters
How do you winterize Model GE20P06SAG? There is no drain at the very bottom...?
Thank you for including model number for EZ identification of water heater
To drain tank without drain valve: Remove TP valve at top of tank and siphon out the water. Then reinstall with correct pipe configuration shown in product manual.
Product manual shows drain valve is not supplied with this unit.
http://waterheatertimer.org/pdf/GE20P06SAG-under-counter.pdf
Product manual shows the Installer should add both shut off valve and drain valve on cold water inlet line.
http://waterheatertimer.org/images/GE20P06SAG-under-counter-60.jpg
More resources:
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Sep 30, 2012 | RELIANCE 19.9 Gallon Electric Compact...
Drain valve leaking. Gor replacement part. Cannot get old valve off . Does the whole valve come off , unscrew or pull off? serial number is RN1296A 18392. Will the new part fit the same New...
If valve is dripping, buy garden hose cap and screw onto valve.
Whole valve unscrews counterclockwise.
If valve is plastic, expect it to break off.
If valve is brass, use cheater bar on your pipe wrench.
I don't know that serial number or part number, but drain valves are standard 3/4" pipe thread.
Drain valve can be rusted in place and impossible to remove without draining tank and putting water heater on it's side.
Install new water heater so drain valve is accessible, and buy new water heater with brass valve instead of plastic.
Jun 15, 2011 | Rheem Water Heaters
I have a warrior glass hot water heater.model number 71-305.serial number r 0590822159.wattage 240 volts ac only. 30 gallon.the water pressure is low.drained tank to clean out.still having problems.any...
Buy a pressure gauge at hardware store that screws onto hose connection.
Test pressure on outdoor spigot.
Test pressure on water heater drain valve.
This will tell you if the pressure problem is before -or- after the water heater.
If problem is before the water heater, then the shut-off valve located on cold water line is suspect.
If problem is after water heater, it could be in the hot water outflow pipe on top of water heater, or a nearby elbow.
Nov 11, 2010 | Rheem Water Heaters
How do i determine the manufacture date for a h w heater, serial # GE0801269835 - model # GE 20P6A Thank you Mark Stambach City of Auburn Maine Plumbing Inspector
Jun 15, 2010 | General Electric GE SmartWater Household...
We have a leaking water heater.
As far as a shut off valve on to the water heater, if there is one you should be able to see it on the water line going to the heater. This is not common in mobile homes. If there is not one I would strongly recomend you install one when you replace the heater. If it is going to be a while before you replace the heater you might consider draining it and cutting into the inlet line and installing a shut off valve, so you can turn the house water back on. I hope this helps.
May 12, 2010 | General Electric GE SmartWater Household...
General Electric GE SmartWater Household Water Filtration System - GNWH38F Logo
142 people viewed this question
Top General Electric Water Heaters Experts
Paul Carew
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
