Danby 5.5 cu. ft. / 156 liter Chest Freezer Millenium DCF550W Logo
Posted on Nov 13, 2010
Freezer green light not on and freezer will only work when dail put to highiest point
1helpful
My chest freezer bush cf143gb works ok but the green light does not show it is
Good day James.
There must be a loose cable for the green light to come on. Your thermostat might need replacement especially if doesn't go on defost which happens automatically.
There are 3 lights on the front of the Zanussi Freezone. The green one on the left doesn't light up. What does that indicate? The red light on the right is on constantly. Does this mean that the freezer is...
Starting the Appliance
Insert the plug into the wall socket. The green pilot light will illuminate to show that the appliance is switched on. The red alarm light will also illuminate until the freezer reaches the correct temperature.
Alarm Light
The red alarm light will illuminate when the temperature in the freezer is higher than the thermostat setting. This alarm light will illuminate if:
- The appliance has just been started.
- Fresh food has been put in the freezer.
- The lid has been left open, opened frequently or open for too long.
The red light will go out when the freezer has returned to the correct temperature
Dado
The green light is on but the freezer is not runnimg
you read your freeze catalouge you should be find your problem.
Mar 14, 2013 • Freezers
Magic Chef Chest Freezer MCCF5WBX is not getting power, green light not on
Check your outlet with something else that will work, like a radio. If the green light does not come on, then check the wiring. The green light should be on even if the freezer has reached it's temperature. That is simply a light to indicate that power is at the receptacle.
1helpful
2answers
Does the green light come on after freezer is turned back on?
if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
Jan 23, 2013 • Freezers
Red light on bosh classixx fridge freezer
sounds like compressor has failed to start and overload is triggered(red light) it could be start capacitor fault or overload itself faulty .
If both of these items ok and compressor has power to it then compressor will require replacing.when you switch of refrigeration equipement the oil in the system will drain down to the lowest point and thats normally compressor and if its filled up the suction side of compressor it will cause compressor to lock up (hydraulic)
1helpful
The red light is on my freezer also the green one the door has not been left open can you help
This means the sensor has determined that the temperature is rising. This can happen if the door was left open (which doesn't appear to be the case with your green light) or an unusual amount of warm food was put into it. If this is not the case you may have a cooling problem. If you can put a thermometer in there and check the temperature, working properly the freezer should be around 0 F. If you have trouble please send the model number from the tag on the freezer. That will help with trouble shooting.
Haier freezer chest not cooling. Green light is
Do not put a towel on your freezer or anything that could prevent a good seal from top of freezer.
jim
Green light
could be a possible short in the electrical
Top Danby Freezers Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Thomas Perkins
Thomas Perkins
Are you a Danby Freezer Expert? Answer questions, earn points and help others
