Question about Cobra 25 LTD 40-Channels Base CB Radio
Need the power cord Corbra 25 LTD - Cobra 25 LTD 40-Channels Base CB Radio
    Genius:
  • 1,274 Answers
Hi, my name is John. Welcome to FixYa. You can get it at any Radio Shack or your local road side CB shack for about $4.00. Thanks for choosing FixYa, cheers...John
Posted on Nov 14, 2010
How do I turn up the the dead key power on a crobra 25 ltd cb radio
There is no adjustment to turn up the carrier power in a Cobra 25 LTD. The AM Cobra's are not like the Galaxy's in that respect. All you can do is tune the output section for maximum on a meter.
Jun 21, 2014 | Radio Communications
How do i adjust dead key on a cobra 25 ltd classic cb
The only "adjustment" is the AM POWER trimmer. Lowering this will lower your dead key but will also lower your "swing" power. the TX circuit must be modified to lower the dead key and maintain full output. there are many articles on the web for such modification.
Apr 12, 2013 | Cobra 25 LTD 40-Channels Base CB Radio
How to check wiring inside a cobra 25 classic to determine if its made propperly
Yes, if you have a meter check resistance (like reading a fuse) with the radio off and power cord removed.
Only two of the three pins (look at power cord to see only two have metal in them) are used.
With power switch on front in off position there should be no reading across the + to - pins on the back of the radio.
If a short there the protect diode is shorted--likely first time it got hooked up backwards--easy to do.
Follow in this case the + pin on back just inside the radio and it goes directly to a diode. cut the diode if a short there and read again at the plug--if short gone replace the diode--radio will work without it but you will have no protection in that case.
Jun 02, 2012 | Cobra 29 LTD CB Radio
I don't know how I copied and pasted so much sorry about that. But my question is I have orange and red wires with fuses and black wire without do I hook both red and orange to hot and black to ground?
it depends on what radio if you have a cobra 18wx style or maxon's, or a radioshack type the red is constant power 12v, orange is a switched 12v.. IE key like a stereo, and black is ground. if you have a 25 or 29 ltd types or exports they only have 2 wires red 12v and black ground. but you do find some power cords that have all three, and the orange on the 25 / exports are not used.
Feb 09, 2011 | Cobra 25 WX-NW-ST 40-Channels Base CB...
I have a cobra 25 ltd classic with a 102" whip. It
hello firstly it would be wise to connect your power lead directly to your battery secondly have you checked the vswr on the antenna make sure it is tuned to your radio i presume you have an swr metre and lastly check all coax connection make sure none are shortening out check pl259 at rear of radio and also check lead goin into antenna you can ajust the antenna by raising or lowering the whip .when you acheive 1.5 or better tighten up it should work ok for then
goodluck
Jan 09, 2011 | Cobra 25 LTD 40-Channels Base CB Radio
When i hooked up my cobra 25 it does not have any power, i tried another power cord I had thinking maybe the one that came with the cb was bad, but still no power
Hi, my name is John. Check your power source, there should be a in-line fuse on the red wire, next to the black wire. It will come apart if you push in and twist it counter clock-wise. Should be a fuse there. Replace it with the same rating, it should be written on the side of the fuse....hope this was very helpful...Rate this solution on the four thumbs-up...Let me know if you have further problems......Always glad to help....John
Sep 10, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 25 ltd wx wont power up
You most likely blew a Diode that is back near the power plug.
It is easy to fix the diode but if you continued to apply power you may have damaged other parts including the audio chip.
Dec 22, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 25 LTD
Russ, go to RadioShack, if they don't have one in stock, they can order one. Or, you can Buy one on EBAY.
Jul 02, 2008 | Cobra 29 LTD CB Radio
No sound
The Cobra 25 requires the mic to be working for any sound to come out. My suggestion is that you first try a new mic. If this doesn't work, look real close at the board on the soldered side ( around the if section, thats the area that right under the waxed area on the component side of the board ) for cold solder joints ( broken lead solder) You may need a magnifing glass. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 17, 2007 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 25 LTD 40-Channels Base CB Radio Logo
67 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
