Question about Sanyo Televison & Video
I have a dp15657 19" sanyo it doesnot have the 15
  • Sanyo Master
  • 5,427 Answers
Possibly. If your video card has a TV-out capability, you can do it directly with the appropriate connector. This adapter may have shipped with the video card. Check the specs, only some cards do this.
Otherwise you need a VGA to composite video, VGA to S-video or VGA to component video converter. See http://www.svideo.com/vga2video2.html for some samples. Do not just use a VGA to component video cable; those are for connecting to a projector that interprets VGA RGB signals.
If you want to use the TV speakers you will also need a 3.5 mm stereo (male) to RCA stereo (2 male plugs red/white) adapter unless you get a converter that includes this in the unit.
I hope this helps.
Posted on Nov 13, 2010
Need to connect a 6 cannel 9 pin audio cable subwoofer to a standard audio receiver. is there an adapter to make it plug into rca javks?
Nothing commercially available as the pin-outs are all different and 9 pin din is a non standard connector. Contact the manufacturer directly and ask tech support for pin out diagram.
Oct 27, 2011 | Sanyo Micro Shelf System AWM 3500 Shelf...
Vizio VZ42L. HDTV has stereo speakers connected by what appears to be 5 pin DINS to the television. I would like to use one of the two speakers as my "center" speaker for the surround sound. Is...
Hello
Your Vizio has a 5 pin din connector to take the speaker connection out. There is a 'noch' in the din socket from which count towards left; the first is pin number [1] second is pin number [4]; third is pin number [3]; fourth is pin number [5]; and fifth is pin number [2]. Out of these, pin numbers [2.4&5] has no connections from inside, that is [NC]; not connected. Pin numberes 1&3 are two speaker positve terminals, and the body of the 5pin din pin will act as negative to both channels, that is common.
The company has provided only two channel stereo sound from it to out. There is no provision to get a center speaker out of it. OK.
Feb 12, 2011 | Vizio 42 in. LCD TV
Need to locae he audio outputjcks on my 32 in LG
Here is the list from the spec. sheet of all of the connections available on your TV
1.0 x HDMI ( RCA phono x 3 ) - Rear , 1.0 x Composite video/audio output ( RCA phono x 3 ) - Rear , 1.0 x VGA input ( RCA phono x 2 ) - Rear , 1.0 x Remote control ( 4 pin mini-DIN ) - Rear , 1.0 x S-Video input ( 19 pin HDMI Type A ) - Rear , 1.0 x Serial ( 4 pin mini-DIN ) - Rear , 1.0 x Composite video/audio input ( RCA phono x 3 ) - Rear , 2.0 x Composite video/audio input ( Mini-phone stereo 3.5 mm ) - Side , 1.0 x Audio line-in ( 15 pin HD D-Sub (HD-15) ) - Rear , 1.0 x S-Video input ( RCA phono x 3 ) - Side , 1.0 x Audio line-in ( TOSLINK ) - Rear , 2.0 x Digital audio output (optical) ( 9 pin D-Sub ) - Rear , 1.0 x HD component input - Rear
Nov 20, 2009 | LG 42LC2D 42 in. LCD HDTV
Does my dell dimension 2350 have a dvi port?
No, it does not.
Check the specs of your desktop PC here:
Ports and Connectors
Externally accessible:
Serial
9-pin connector; 16550C-compatible
Parallel
25-hole connector (bidirectional)
Video
15-hole connector
Keyboard
6-pin mini-DIN connector
Mouse
USB
two front-panel and four back-panel USB 2.0–compliant connectors
Network
RJ-45 connector
Audio
three back miniature connectors for line-in, line-out, and microphone
Headphone
one front miniature connector for line-out
Serial
Parallel
Video
15-hole connector
Keyboard
Mouse
USB
Network
RJ-45 connector
Audio
Headphone
http://support.dell.com/support/edocs/systems/dim2350/specs.htm#1107078
Jul 26, 2009 | Dell Dimension 2350 PC Desktop
What are the pin conections for external usb on an asus a7v400-mx board
USB mouse/keyboard to 5-Pin DIN or 6-Pin Mini-DIN adaptor USB Function 5 Pin DIN 6 Pin ps/2
Pin 1 +5V Pin 5 Pin 4
Pin 2 -Data Pin 2 Pin 1
Pin 3 +Data/clock Pin 1 Pin 5
Pin 4 Ground Pin 4 Pin 3
shield shield shield
Apr 16, 2008 | Computers & Internet
How do i connect my projecter with my pc
Your Sharp XR-10X will only allow video inputs through the:
1. RGB/ component input (15-pin HD)
2. composite video input (RCA phono color yellow)
2. S-Video input ( 4 pin mini-DIN )
Depending on the output(s) available from your PC, you can use any of the following:
a. the yellow RCA female
b. S-Video output (4 pin mini-DIN )
c. VGA (which normally goes to the monitor) but would require a VGA/HD to HDMI Format Converter such as the one here
Should this be not enough information, please post back with what PC brand/model that you have. Additionally please specify what Video Card are you using if your PC is a desktop.
Good luck and kind regards.
Dec 03, 2007 | Sharp XR-10X Multimedia Projector
Televison & Video Logo
80 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
