Question about Toshiba Satellite M305D-S4828 NoteBook AMD Turion X2 Ultra ZM-80 14.1' Wide XGA 3GB Memory ...
Hello, i have a Toshiba M305D S4828 and one day i try to turn it on and it just showed a black screen, nothing loads, the fan turns on but then turns right off, the only things that are on are the power light and the wifi swich. i dont know whats to do please help
Jack_Dawson
  • 287 Answers
SOURCE: hello
1. uninstall the wireless/wi-fi driver
2. restart the system
3. try to connect wi-fi
Posted on Dec 30, 2009
  • 2567 Answers
SOURCE: hi, my toahiba satellite m305d s4828 backlight
The problem might not be with the LCD inverter. There is a possibility that you have a faulty LCD screen cable. The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board.
Please check this possibility.
Posted on Aug 29, 2010
Testimonial: "thanks ill go see if thats the problem i think that is it screen use to kinda turn on and off thank you"
  • 2567 Answers
SOURCE: My Tohsiba Sattilite keeps turning off too AND I
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
Posted on Dec 07, 2010
  • 308 Answers
SOURCE: toshiba satellite m305d power light
Either your motherboard, CPU, or GPU have fried. You can try to re-seat your ram but if there is no beep/beeps and nothing but a power light, and fan running for a couple seconds those are the only options. If your handy you might get lucky and get it to work for a little (as long as you have thermal paste) Remove heatsink, & fan, then the CPU blow out the connections with compressed air (to go the extra mile electronic cleaner) then let dry for a few hours reassemble, hoping for the best the whole time mind you.
Posted on Jun 21, 2011
SOURCE: My toshiba Satellite M305D-S4828 won't turn on after it goes into sleep mode or after resart?
What do you do to try to wake it up? Try to push the power button
Posted on Mar 18, 2012
Toshiba satellite m305d-s4828 no bios post, no beep and display I tried to connect to external monitor and still blank I have check the video cable connected from system board to LCD they are good....
remove the ram from the board and turn it on you should hear a beep for no memory detected if no beep then either the motherboard, the processor, or both are shot
Jun 30, 2011 | Computers & Internet
Hi! I have a Toshiba Satellite M305D S4829 that won 't turn on. I can hear the fans starting but the screen remain black. I tried taking out the battery and just using the adapter but still nothing.
You need to plug it into an external screen to see if windows is loading. That way you will know if it the laptop screen it self or t something to do with the computer hardware.
If the fans am starting then you are getting power to the laptop however it may be shorting out just before bios as time to load so you will not get any display.
The best bet is to try and isolate the problem. Try attaching another montior to it and see if you get a display, this test is not always reliable because some laptops requires external monitors to be enabled using windows, so if your getting no output on the laptop screen it cant be done.
If you can get output using an external monitor then the monitor of the laptop may be broke or as become discounted from the motherboard.
May 07, 2011 | Computers & Internet
Hi, my toahiba satellite m305d s4828 backlight isn't working, i already replaced the lcd inverter but it still didn't work, i dont know what to do anymore
Aug 27, 2010 | Toshiba Satellite M305D Notebook
My toshiba doesn't start anymore
Try removing the battery from the notebook and starting it just from the power. If it operates, you need a new battery.
Mar 05, 2010 | Toshiba Satellite M305D Notebook
Toshiba M305D S4830 laptop wont start
"I have M305D S4830 laptop. I put it to sleep in the night. In the morning when i tried to turn it on, it wouldnt start. The light on the switch turns on and it charges the battery fine, but no HDD activity(but it does spin up and stay), no screen, nothing. The fan turns on and then turns off in 1 sec and then just the power indicator lights stay on... i also checked cmos battery, removed it and put it back.its voltage is also fine..."
Hello PPL! Maybe this WILL HELP you! I HAD absolutely the same problem >> 3 months of god **** stress, didn't find any solution, till one day i found on my Recovery CDs one note!! >> It sounds like:
"BEFORE pressing power button, HOLD 'C' button and while Holding 'C' button push POWER Button ONCE!! to start Laptop, KEEP Holding 'C' button!!! untill appears TOSHIBA screen!" then release 'C'. After that, it will appear "Operating System not Found">>then just do a restart by pushing Power Button and Start again! For me, It Worked!! and i'm god **** happy now)...let me know if it Helped you, Good Luck!
Feb 04, 2010 | Toshiba Satellite Laptop with AMD Turion...
Blank screen
Take a flashlight and shine it on the screen. If you can see an image, you probably need to replace the power inverter board. It supplies power to the backlight.
Jan 23, 2010 | Toshiba Satellite M305D Notebook
My Toshiba Satellite M305D-S4830's screen will flicker black randomly with no aggrevating and occasionally will fade to white or black completly.
I recommend you to reinstall the display drivers of your laptop as the issue may occur due to the corrupted display drivers.
Uninstall the display drivers from Device Manager.
Expand Display devices.
Right click on the display device and select Uninstall.
On restarting the laptop, windows will detect the device and reinstall the display drivers.
You can even install the display drivers from your notebook support website:
www.csd.toshiba.com
Jun 29, 2009 | Toshiba Satellite M305D-S4828 NoteBook AMD...
Toshiba Satellite M305D-S4828 NoteBook AMD Turion X2 Ultra ZM-80 14.1' Wide XGA 3GB Memory ... Logo
57 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
