Question about Ryobi Garden
I have a Ryobi SS30 and everytime I start it up it starts making this rattleing sound. Is there any way to fix this?
  • 29 Answers
That rattling noise is the spindle inside the shaft the olny way of i know to fix is to replace the shaft
Posted on Nov 13, 2010
Fuel mixture ratio for Ryobi SS300 weed eater
Are you sure about the model number? I see several 30CC engine string trimmers by Ryobi. Two are the Ryobi RY30040B (SS30) and a RY30544 (SS30).
For both of these models, mix a high quality 2-cycle engine oil at 2.6 oz. per gallon of gasoline to pour into the gas tank. This ratio is used in several other Ryobi string trimmer models. Many Ryobi product manuals are available here: https://www.ryobitools.com/power-tools/support/manuals . Most Ryobi gas powered and 40V battery-powered tools will have a model number that starts with RY. The 18 V battery powered models often start with a P.
I hope this helps. If you add a comment with the actual model number, I may be able to provide more information.
May 20, 2016 | Ryobi Garden
How do I remove the carburaetor locks on Ryobi ss30 seedeater I am a beginner lady learning to fix my own stuff
Remove carb mounting bolts. Carb obsolete not available. This may help: http://www.ereplacementparts.com/ryobi-ss30-ry30002a-string-trimmer-parts-c-7931_15633_15652.html
Dec 22, 2015 | Ryobi Garden
My Ryobi SS30 does not start
check to make sure the plug has good fire if not change the plug
Dec 21, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
When first started my ryobi ss30 runs like a charm, the problem, it won't start again till it cools dwn, why ??
your problem is simple as the engine gets warm the coil heats up and breaksdown you will need to replace the coil
Aug 19, 2009 | Garden
Ryobi SS30 Carburetor Problems
Replace thecarb screen, make sure you can see through the screen
Aug 18, 2009 | Ryobi Garden
Need to find how to get to caurb. RYOBI SS30
remove the 2 hex nuts or screws holding the cover assembly on and the carb should come off ( maybe stuck to gasket so tap lightly)
Jul 24, 2009 | Ryobi Garden
Weed eater shut down once I began to trim
Youwill need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to seedaylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Jul 01, 2009 | Ryobi Garden
Ryobi SS30 starts great, runs fine, quits
the engine is getting to hot & shutting down either not the right fuel mix or not enough oil in engine sometimes the mixture screws need to be adjusted
Jun 14, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Ryobi SS30 trimmer starts fine and runs at when in full choke position to about half choke position. But when I put the choke lever to the full run position, it stalls out. Ryobi ss30 same problem of...
You need to rebuild the carburetor. You will need to go to an outdoor power & equipment store of some kind to get a carburetor kit for your specific trimmer. It will come with various gaskets, (some of which you won't use), a needle valve, and a small screen that goes in the carb. Replace all old parts with new. New primer bulb is sold seperately. When you have the carb. apart, you will also need to clean the small ports with a Den Tek Brush (used for cleaning teeth). Use carb. cleaner when cleaning.
Jim
May 29, 2009 | Ryobi Garden
Ryobi SS30 Problem, please help
Hello:
Are you Sire you Used the Correct Fuel Mix Ratio?
Remove the Muffler and Look Into the Exhaust Port.
Is the Piston Scratched and Gouged or is it Smooth like Glass?
If Smooth like Glass, then Check the Carburetor for Trash.
If Scratched and Gouged, then the Wrong Mixture was Used and the Engine is Trashed and will Require a New Piston and Jug (Cylinder) Assembly (a new unit will be cheaper than the parts to repair this unit) for the Unit to Run again.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
343 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
