Question about Kitchen Ranges
Am trying to hook my Digitrex CTF2671AQ Tv to a Goodmans GHC35 2.1 Channel Home Cinema System but we are not getting any sound output from the TC...sound is coming thorugh the regular speakers on the tv but not the sound system
  • 3 Answers
SOURCE: home theater system connections
Hi
I have the same tv but my dvd surround is a toshiba, that shouldn't matter though. When I watch a dvd I go to component 2 which is where I have my dvd connected on the input of the tv when I watch tv and want the surround on I go to component 1 which is the tv input then on my dvd player I go to auxillary and I can watch tv in surround. I don't know the LG home theatre system but you should be able to select your inputs like between dvd, tuner, aux. Flip between them and you should get sound. hope this helps.
Posted on Jan 19, 2008
THENTHEREWER
  • 131 Answers
SOURCE: i have a samsung cinema
make sure you have the audio cables connected to the OUTPUT on the tv & the INPUT on the surround sound(from your desciption sounds like you have them reversed)hope this helps,thanx for using fix-ya,please rate all replys
Posted on Nov 18, 2008
SOURCE: Can't get tv sound from home cinema system speakers
you need an optical cable going from the TV to the home cinema for an audio output, it worked for, had the same problem!!
Posted on Dec 26, 2008
ssebata paul
  • 159 Answers
SOURCE: speakers wont play when tv is on
the audio amplifier is gone
Posted on May 30, 2009
  • 85 Answers
SOURCE: I have an LG TV
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Posted on Jan 07, 2011
Panasonic home cinema connection issues
What other audio/video outputs does the TV have? Does it have an HDMI port? If so, connect TV to your home theater using HDMI to HDMI.
Jun 07, 2013 | Panasonic SC-BTT490 5.1 3D Home Theater...
How can i get my surround sound working for my ps3 i have a philips hts3357 home cinema please help
Hook the ps3 into the tv. Hook the T.V out going to the surround sound system and you should get your game sounds out of your surround sound.
Mar 01, 2011 | Philips HTS3357/05 Theater System
I have an LG TV with an LG HOME CINEMA SYSTEM problem is: watch dvd/blue ray - video fine sound fine (through speakers) watch tv / sky -- video fine sound None throughspeakers on...
Hope this helps,
Good Luck.
Jan 07, 2011 | LG Audio Players & Recorders
Have today bought Ferguson FHT1000 5.1 Channel DVD home cinema system can i get surround sound to work on tv or will it only work on dvd
it will work with your tv providing your tv has the correct output and you have the right cables. the programme must also be broadcast in surround, most programmes are only stereo. if you are running sky or sky hd this will be different so repost.
Dec 20, 2009 | Audio Players & Recorders
Help with connecting home cinema to xbox
if your tv supports this. go to ebay type in "hdmi" buy one for around $10.00 plug into xbox. set your tv to which port you have ,(if you have more then one). bingo,bango ,your done.
"no hdmi"? and you have com. on your tv. plug corrosponding color plugs for component ,L&R audio plugs .
change tv to comp.( not video) your done
Jan 30, 2009 | Audio Players & Recorders
No sound through the Panasonic cinema surround sound on TV
Had a similar problem mate. I solved it by connecting the tv to the PT460 system with a scart lead. You then have to have the AV channel selected on the PT460 system to listen to the tv. You will always have to have the AV channel on the PT460 selected to listen to any sound transmitted through the tv - be it playstation/xbox or any other device that you may connect in the future with HDMI leads or otherwise. Hope this helps
Jan 04, 2009 | Panasonic Home Theater System System
Dec 04, 2008 | Panasonic Home Theater System System
No sound on tv but have sound on dvd and radio through my home cinama i wont to listen to the tv through the home cinema but cant get it
What is the source of your TV signal? Cable? Sattellite? Are you using the receiver in your tv or a cable/sattellite receiver box?
Whatever the source of your TV signal - it will probably have several choices of output. Make sure you have that connected to the tv-input on your home cinema. Then make sure that when TV is selected on your home cinema that the audio format specified matches what you hooked up i.e. analog (the red and white cables), optical or coax.
Oct 21, 2008 | Samsung Audio Players & Recorders
CAN ONLY GET THE SURROUND SOUND TO WORK WITH DVD'S NOT WITH NORMAL TV OR SKY?? WHY??
You should have a AUDIO menu in which you can simulate true surround sound. This should be in your owners manual. Your DVD is recorded in dolby surround sound that's why on your set it will be reproduced as recorded. I hope Samsung is using a ATSC tuner in that model?
Apr 04, 2008 | Samsung HT-Q100 System
Trying to install a new 50
a good way to go is to connect the home cinema kit staight to the tv though phono leads, see if your tv has a phono in and out this must not be a av socket. you should then connect it in to your cinema kit so what ever you watch comes though ur cinema system
hope this helps
Feb 09, 2008 | Televison & Video
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
