Question about Weedeater Featherlite Blower 18 Cc 150 Mph 300 Cfm Model No Fl1500 Reconditioned
Will not fire after replacing spak plug - Weedeater Featherlite Blower 18 Cc 150 Mph 300 Cfm Model No Fl1500 Reconditioned
  • 29 Answers
If it will not spark after the plug change, then you need to go deeper to the coil, and the magneto, alot of times the magneto plate just needs to be sanded or wire brushed.
Posted on Nov 13, 2010
1997 slk does not have power. the highst speed is 80kph.
Check fuel filter if engine runs rough or feels it is mis firing the injecters are the problem. Put some cleaner and some 98 petrol in the tank. Spak plugs might need changing
Aug 19, 2013 | Cars & Trucks
Enngine does not fire up. no spak at plug
remove the top cover from the engine then the small wire to the coil crank it and check for spark if you have spark with the wire off check your safety switch on the brake/brake pedal it is a dual switch so it can crank and still not fire if there is no spark with the small wire off the coil is bad
Sep 03, 2012 | Poulan Pro 46Inch 22 HP Yard Tractor with...
Spark plugs
replace one at a time to keep the firing order if hard to turn. going back in .check you are on the correct thread .as can damage the threads if on wrong.
Aug 31, 2012 | Ford Vehicle Parts & Accessories
Need to know spak plug firing order for a 1996 pontiac grand am
4-cylinder:
Firing Order: 1-3-4-2
3.1 liter:
Firing Order: 1-2-3-4-5-6
Sep 04, 2011 | 1996 Pontiac Grand Am
Will not accelerate fast without popping and sputtering, but will accelerated slow just fine
you have a miss fire under load the most common cause is a bad spak plug wire, if you give it a good old tune up it should take care of the problem.
spark plugs, spark plug wires, distabutor cap and rotor, air filter, fuel filter, and PCV valve.....good luck
Jul 26, 2011 | 1990 Honda Accord
Won't start when engine is warm, starts fine when cold and at normal operating temp
You might want to make sure the vehicle is not overheating. If all checks out, it may be in the ignitions, spak plugs/coils, wires. It could be a leaking injector. Keep in mind, it needs air, fuel, and fire to start.
Mar 21, 2011 | 1997 Oldsmobile 88
Not enough spak-new magneto-plug-all gaps ok
Be sure you have set the magneto at the correct clearance. Make darn sure that the elements for an engine to start and run good are fuel, good air , and a good spark..That clearance by the way should be .010 to .012/ Good luck. don
Mar 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Weedeater Featherlite Blower 18 Cc 150 Mph 300 Cfm Model No Fl1500 Reconditioned Logo
469 people viewed this question
Top Weedeater Garden Experts
Matt Olenzek
Matt Olenzek
willy15
 steve
steve
Are you a Weedeater Garden Expert? Answer questions, earn points and help others
