Question about Craftsman Saws
Can't figure how to replace tire belt - Craftsman Saws
  • 32 Answers
When I replaced mine I had to go and get two tire bars from the local bicycle shop and they worked real slick. I'm not sure which ones you are putting on mine were the orange Poly tires.
Posted on Nov 15, 2010
My 2004 gmc savanna 3500 shakes from the steering wheel after going 60mph
I'm guesing you have had your tires balanced and wheels aligned. If this does not help, then you have a broken belt in one of your front tires.
Nov 04, 2014 | Cars & Trucks
I cant figure out how to raise the rear seat to get the tire iron out
There is a small loop right next to the rear seat belt attachments. See if the little loop of fabric is hiding inside the hole where the seat belt come out of in the seat.
Oct 16, 2009 | 2004 Isuzu Rodeo
I cant figure out how the ac belt goes on....94 civic vtech
You have to support the engine with a floorjack and then disconnect the left motor mount. The belt slides through the gap and then you reconnect the motor mount. You probably have to remove the left front tire.
Aug 15, 2009 | 1990 Honda Civic
2003 Dodge Neon: P0016 (already replaced sensors, belt, tensioner
the computer may need to be reflashed. if it is running then it is not a bad sensor. either of those being bad would cause it not to run.
Jun 20, 2009 | 2003 Dodge Neon
Squeeky belt and front wheel vibration after having belts replaced
I would guess your two issues are separate. The squealing belt could be an adjustment problem or a wet or damaged belt. Belts can vary, how long they last. I have replaced them the next year on some cars and others could 3 or 4 years. The tire vibration could be related to the tire tread or some type of tire defect(a bubble in the side wall), may be an alignment problem. Check the steering components, tie-rods, ball joints, and wheel bearings.
May 25, 2009 | 2002 Honda Accord
Inflating tires on kettcar nitro extreme
Sometimes the best thing to do is cinch a belt around the tire until you can get the bead to seal or get it close then add air. A small ratchet strap works really well.
Apr 08, 2009 | Toys
I need to replace the drive belt to the transmission
On the side of the deck there is a metal rod running along between the tires. Push it back then pull it forward when it releases from the catch it will move the pulley and release the belt. Hope you can figure it out I believe it is on the side with the brake pedal.
Mar 22, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
2002 stratus vibration between 50 and 60 mph
Most shop today follow a cut and dried system. They don't find anything, they tell ya "Sorry"
Here's what I've had. Two of my tires had broken belts. Easy way to check. First be somewhere where air is available. Jack up car to get tire off the ground. Let all the air out of that tire. Now, look real close for a "Flat" spot or for the tire, not the wheel, to be out of round. That is a broken belt. The fix? Replace it.
Other time, I had bought a used car and the owner used the "Fix A Flat". This puts fluid into the tire and can give you a fit trying to figure out why it vibs and sometimes it doesn't.
Good luck
Feb 20, 2009 | 2001 Dodge Stratus
2002 Timing Belt Change
The timing chain on the H6 does not need to be replaced. We ran into a vapor lock (can you believe it!) situation a couple of weeks ago and I did some reading. In the maintenance booklet for our 3.0H6 states that the camshaft drive belt (timing belt) on the 2.5 ltr 4 cyl. needs to be inspected and replaced. On the 3.0ltr engine there is a footnote that states "Periodic inspection and replacement of the camshaft drive chains on the 3.0 Liter models are not required."
Hope that helps.
Jan 06, 2009 | 2004 Subaru Outback
Saws Logo
64 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
