Question about Vector Vec143 Bright Bar Work Light
NEED REPLACEMENT BATTERIES pack has UT-1500aa 3.6 volt on batt and also UNITECH 01C06599-MH28230
    Problem Solver:
  • 6 Answers
Just re engineered a BT-905 phone battery -moved one battery and a drop of solder- Works great
Posted on May 30, 2013
I want to connect these batteries to form battery pack for prepper use. How can I do ie
conect a lead to the negative side of one battery, join the positive and the negative of the other battery conect a lead to the positive of the second battery, lead from 1st batt. is negative and lead from 2nd is posive to produce 3.volts
Apr 10, 2013 | Electronics - Others
Jet 3 Ultra, batteries 1 yr old, charge voltage only 26.3 volts output from onboard charger when batts drained after extended use. After charging overnight, batts are 12 volts each, but chair goes 1.5...
Mark Batteries your charger is putting our enuf 13.15 volts for each battery so after charging all night you should be reading about 13 volts on each. If your batts are only 12 volts after all night charge then batteries are weak Hope this helps
Oct 30, 2010 | Jet 3 Ultra Power Chair
Flashing red light batt. fully charged
Flashing red light usually means low batteries. Check the batteries after charging all night with a volt meter through the charger port you should read 26-24 volts dc. If you get a lower reading and you are sure the charger is working correctly then you will need to replace both batteries Hope this helps
Aug 21, 2010 | Jet 3 Ultra Power Chair
Typ of battery
Mine has 2 12 volt 12 ah agm batteries model ub12120 if that helps>
Jul 12, 2010 | Pride Mobility Products Go Go Ultra X 3...
Battery Packs for Powerware 9355 UPS
The Batts can be charged externally, then refitted, usually I extend the DC cables so I can work with the batt outside the unit. This is ONLY to be done if you understand the risk and what may happen if you get it wrong.
Batts are always live and can cause fire/explosion/severe burns if shorted!
IF YOU ARE NOT SURE THEN GET SOME EXPERIENCED HELP!
OK so the UPS will not normally recognise a very low batt pack, that is the reason you can not start the test, this test will back of the rectifier so the batt pack takes the load for a short period.
If the batt pack is out of range then this will make the load go off, so the UPS is designed not to allow the test,unless the batt is at the right level.
If you can get the batt pack up close to normal then the unit will recharge it to full.,Wait until it is fully charged before testing.
If this is sucessful the cyle the batt a few times allowing it to reach around low batt warning before recharging. This will assist the batt in recovery. During this process if possible monitor with a test intrument(fluke 123 or 43B will do) the batt pack discharge curve , once the batt pack has dropped to its charge level from float, it should be a smooth decay.
depending on the state of the batts you may be ok, if there are weak ones in the string then you may have to replace all of them depending on the age of the batt pack.
MAKE SURE YOU ARE VERY CAREFUL WITH BATTERIES, THEY ARE VERY DANGEROUS, AND ALWAYS LIVE!
Check you manual for safety procedures, BEFORE working on Batteries.
hope this helps
thanks for using Fixya
Feb 03, 2010 | Powerware 9355 UPS System
My apc ups do not charge batteries it is su 3000 working wel but do not charge batteries
Your battery lifespan is probably over, (3-5 Years) or the battery could have a dead cell in it, my suggestion is to replace the battery. it should be a 12 volt 7 amp hr battery or a 24 volt pack that you will have to get from the manufacturer
Oct 22, 2009 | APC Smart-UPSĀ® UPS System
We have managed to lose the rechargeable battery pack. Where can I get another one?
Oh my, not good. Well, you do need a battery pack. Contact the MFR for replacement pack via customer support, or check the voltage on the side, if using 9V, get a battery holder that uses 8 batteries[2 Xtra cells are used to disable the shutting off at too high a voltage due to the missing battery pack]go to battery space.com, and go to wires/connectors, and get the laptop connectors to make an external battery pack. Therte is a battery pack charger/I recommend accupower evolution. You have to google and go to other sites to get the rechargeable batteries and battery holder. You can get by with alkaline, but they would go rather fast due to the large screen size. You need that good brand name so they can be evenly charged due to the batteries being able to be run down further. You wont be wasting much voltage with alkaline due to the lower cutoff voltage, but 1st try contacting the mfr or googling to get that battery pack!!!I Hint: if using battery pack and you still want to add more battery life, drop the batteries to 6 on a 9V circuit. with original battery pack on, a 9V circuit would use 6 D cells on an external pack, 8 for a 12 volt.
Aug 17, 2009 | kawasaki PVS-10921 Portable DVD Player
Shure Wireless Mike no Output
Check the battery with a volt meter. If the battery measures lower than 8 volts on a volt meter, replace the battery. I have seen entire cases of brand new batteries that are defective. Make certain to check it with a volt meter. If the battery tests fine, then send the bodypack to Shure for repairs. www.shure.com/service
Dec 18, 2008 | Shure ULX1 Body-Pack Transmitter...
18 volt ryobi batteries wont hold charge
NiCads stop taking a charge because microscopic crystals build between the individual battery cells (inside the pack) and the leads between them. here is what i have done for my craftsmen NiCad 18 volt batteries to get them to once again hold a charge:
you'll need ~2 to 3 times the voltage that you are using. for instance, if you've got a 14v drill battery that has stopped working, then you'll need 28-42 volts, 18v will need 36-54 volts. i have found 3 car (or motorcycle or lawn tractor) batteries work fine. so i have 2 motorcycle batteries and 1 tractor battery.
i hook these car/motorcycle/tractor batteries up in series. positive from one batt to the negative of the next and so on until i have one positive lead not connected and one negative lead not connected.
something like this: --(batt)+_--(batt)+_--(batt)+
then with safety glasses on i touch the positive lead from the motorcycle battery to the positive tab of the NiCad drill battery with one hand and the negative lead of the tractor battery to the negative tab of the NiCad drill battery (at the same time) and count to 3. i remove and wait a few seconds (5-7) and repeat 2 more times.
once the last ZAP is done, place the NiCad drill battery into the charger and see if the charge light illuminates. if it does, then you have just saved a battery from the land fill and some $$ from your pocket. if it doesn't, then try to repeat it once more, but no more after that.
some word of caution. do not let the the + & - leads of the car/motorcycle/tractor batteries touch each other. that's 36 volts you've got there and will spark/explode.
also, if during the zapping of the dead NiCad battery you hear a "pop", one NiCad cell inside the battery pack has given up the ghost and now the battery is trash for sure. take it to radio shack for recycling. do NOT attempt to zap it again.
use at least 14-16 guage wire (or larger which is a smaller number) to connect the batteries in series and also to zap the NiCad drill batteries.
one final note: do NOT use this method on Lithium Ion batteries. it will not work and may cause injury!!!
good luck.
Oct 20, 2008 | Drills
Vector Vec143 Bright Bar Work Light Logo
815 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Barry_IA
Level 1 Expert
Jim London
Jim London
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
