Question about HP LaserJet 4600dn Color Printer
Hp 4600 no cyan printing
Hi i have an HP 4600 with some strange problems first it is leaking magenta toner after the 10 page is printed and second the most interesting is there is no cyan printing i have cleaned all the contacts and got 2 new cyan cartridges with no change it will see the cyan cartridges and report on there level but not print any cyan. i recently swaped the cyan laser assembly with the magenta one and no change it still wont print cyan but it printed up magenta just fine
  • Anonymous Mar 14, 2014
    I'm getting spots of magenta on my documents with a brand new cartridge. Can I fix this?
    Problem Solver:
  • 14 Answers
Firstoff, if you have tray 1 set to "any size" & "any type" they had problems with it going into calibration to frequently. If you upgrade the firmware this will take care of that. As for no Cyan, check the scanner interlock to insure it is opening the scanner cover. You could also go into diagnostics and disable cartridge check and swap the cartridges around, ie. cyan & magenta, run the print quality pages and see if the problem follows the cartridge. It could also be HV power supply.
Posted on Jun 19, 2008
Printing problem comes after 10 page or 50 pages after ,(cyan,magenta,yellow) color verticals 1and half inch line comes in print .
after printing 10* or 50 pages* at a time then you should off your printer for 15 minutes then restart it again.
*problems comes because your printer goes very hot
Jun 08, 2012 | HP LaserJet CP1215 Color Printer
MY HP LaserJet 2840 has a brand new Toner cartridge. Now it won't print at all and we are getting a "OPC at end of life" prompt. What does this mean?
Imaging drum reach 20,000 (black only) or 5,000 (color), replace the image drum.
Supplies life
The life of the imaging drum depends on the number of black-only or color pages that print jobs
require. Imaging-drum life is also affected each time the device calibrates because calibrating causes the imaging drum to rotate. Imaging-drum life is measured in terms of number of rotations rather than number of pages printed.
The type and length of print jobs also affects drum life. A series of short print jobs uses more drum
life than an equivalent number of pages printed in a single large job. To extend drum life, print
multiple copies of a print job at one time rather than sending the same job to the device multiple times.
The life of a print cartridge depends on the amount of toner that print jobs require. When printing text at 5% coverage, black print cartridges last an average of 5,000 pages and cyan, magenta, and
yellow print cartridges last an average of 2,000 pages. High-capacity cyan, magenta, and yellow print cartridges last an average of 4,000 pages. (A typical business letter has 5% coverage.)
Aug 18, 2011 | HP LaserJet 2840 Printer
My network laserjet 4600 only comes out black not color both when printing and just a information page from the device
Try the above troubleshooting steps for each color page that prints out for test pages.
Try to click on 'magenta' for instance, and follow the leads to a solution for your black only print problem.
Feb 10, 2011 | HP LaserJet 4600 Printer
Excess cyan toner is on electrostatic transfer sheet even after wiping it. All black and white pages are printed with cyan background.I am even using original cartridges.
Since you have Cyan toner in places where it should not be then the only possible cause is a defective Cyan Toner cartridge. I worked on one just last week where the customer complained about Magenta toner on their prints. I also noticed Magenta toner on the Transfer Belt just as you see Cyan toner on the Transfer Belt. I replaced the Magenta Toner Cartridge and everything cleared up nicely. The Transfer Belt Unit can also cause similar problems but it would not be ONLY one color like Cyan. It would be a mixture of all colors. My bet is replace the Cyan toner and you will be fine. If you have an old empty one just shake it up a bit and try it as well. This might allow you to verify before buying a new cartridge.
Good Luck and Thank You for using Fixya.
Wheatland Services
Feb 06, 2011 | HP Color LaserJet 2600n Printer
It leaks. It's all over the inside of machine. We don't use this printer a lot because we do design on-line; so it's not from overuse or worn out parts. It just leaks and then causes the printer to stop...
I have had problems with a number of brand new genuine HP toner cartridges leaking on this printer. Strangely, I have had almost no problems with non-OEM cartridges from Cartridge World.
I can’t explain this...and wouldn’t have believed this if I hadn’t experienced it myself.
Try removing all toner cartridges, and carefully cleaning out the printer with canned air. Then replace the leaky toner cartridges with Cartridge World cartridges. This has been my recipe for success with the HP Laserjet 4600.
Nov 16, 2009 | HP LaserJet 4600 Printer
Newly replaced original magenta toner not printing
Dear this printer is solve this problem just
chnge the magenta toner scaner ok ........after that is working but not any idea about this just call me :+91-09328015664
Jul 14, 2009 | HP Color LaserJet 2600n Printer
HP LaserJet 5550 Dumping Excess Toner...
Are you using HP toner?
Pull out the cartridges and vacuum out the printer. Get a compressor or canned air and blow the printer out. Vacuum again,
Install HP toner and try printing again.
Mar 12, 2009 | HP LaserJet 5500 Printer
HP D7360 prints in magenta instead of black. Both cartridges are
Check your other colours. Anything other than a True Type Font is printed in colour shaded with black, so it sounds like you have a problem with yellow and cyan. Either the ink cartridges are out or the print heads have a blockage.
If the cartridges are not empty or v low, try sitting the print head over a folded paper kitchen towel damped with hot water for 10 minutes. Remove it and try your diagnostic again.
Dec 11, 2017 | HP Photosmart D7160 InkJet Printer
HP LaserJet 4600dn Color Printer Logo
381 people viewed this question
Ben Johnson
