Question about NAD 2200 2Channel Amplifier
Hello, I own a NAD 2200 power amplifier. The other day it just went dead; no diode indicators, nothing. I've located the problem to the input voltage selector (110/120/220/240V), so now I want to bypass the voltage selector for 220V use only. I've removed the voltage selector unit and my question is: can you provide me with what cables to connect, with color coding, to run it on 220V? Kind Regards, Hans.
  • 2 more comments
  • HANS-JOHAN ASANDER Nov 14, 2010
    Hello and thank you for your advice!!
    When the amp went dead (no diode indicators) no fuses were blown. I read that a common problem with the NAD 2200 is the input voltage selector. So I opened it up; it was very losely fit and 2 connector blades fell out. I found one 220V cable (among the 6 cables atached to the voltage selector) and soldered it to the cable I assumed was the 220V winding. The diodes then lit up for a fraction of a second and the main fuse (5A) blew. This is what made me convinced that the problem really is in the voltage selector. Do you think I am right about that?
    The input voltage selector can be configured for 110/120/220/240V - 4 states.
    There are 6 cables attached to the voltage selector, where 3 of them measure 220V (when soldered free). The other 3 cables measure around 9-12V AC. I would assume I should have 4 tapping wires, one for each input voltage, and only one 220V feed wire, to attach to one of the four tapping wires. But that doesn't seem to be the case. Or am I wrong?
    I will try to find the direct winding (for reference) on the transformer to do the resistance measurement, as you suggest. But the 6-wire setup of the voltage selector, with 3 of them having 220V with all 6 wires soldered free, makes me a bit confused of the function.
    Kind Regards,
    Hans.
    Hello and thank you for your advice!! When the amp went dead (no diode indicators) no fuses were blown. I read that a common problem with the NAD 2200 is the input voltage selector. So I opened it up; it was very losely fit and 2 connector blades fell out. I found one 220V cable (among the 6 cables atached to the voltage selector) and soldered it to the cable I assumed was the 220V winding. The diodes then lit up for a fraction of a second and the main fuse (5A) blew. This is what made me convinced that the problem really is in the voltage selector. Do you think I am right about that? The input voltage selector can be configured for 110/120/220/240V - 4 states. There are 6 cables attached to the voltage selector, where 3 of them measure 220V (when soldered free). The other 3 cables measure around 9-12V AC. I would assume I should have 4 tapping wires, one for each input voltage, and only one 220V feed wire, to attach to one of the four tapping wires. But that doesn't seem to be the case. Or am I wrong? I will try to find the direct winding (for reference) on the transformer to do the resistance measurement, as you suggest. But the 6-wire setup of the voltage selector, with 3 of them having 220V with all 6 wires soldered free, makes me a bit confused of the function. Kind Regards, Hans.
  • Javier Moreno Nov 05, 2011
    In this thread I found the clue to solve the same problem I had in my NAD 2200 amp. I solved it by bypassing the broken imput voltage selector. I only need 220V so I soldered a small piece of wire between the red and green terminals. These are the connections for the others voltages (as they operate in the imput voltage selector):
    110V: (Brown-Green)-(Red-Blue)
    120V: (Yellow-Brown)-(Orange-Blue)
    220V: Green-Red
    240V: Yellow-Orange
    I have pictures and diagrams of the broken imput voltage selector and the bypass of it, If anybody need them.
    Regards
  • Russ Feb 06, 2013
    I had the same problem- simply bridge the voltage selector. The contacts get burned out.
    Top Expert:
  • NAD Master
  • 74,377 Answers
Hello Hans
Have you checked the continuity of the primary windings of your amp's tranformer?. You have already stated that your amp went dead. If it is so, there must be some fault inside it, a fuse is blown, a shorted rectifier, a shorted filter capacitor, shorted output transitors or so. If so the mains fuse will blow out. have it happened in your amp?
Anyway the colour code cannot be predicted as Nad has different colour codes used for their primary winding input to their transformers. You just do one thing. The transformer primary have tappings in it, to input various voltage inputs, and that tapping are comming out in different colored wires. Measure the resistance of the winings, with a multimeter set to ohms range. One end of the winding will be direct, and the other end is tapped for different voltage inputs. The maximum resistance winding which you gets with respect to the common direct end will be meant for 240V, and next lesser meant for 220V. Leave the other ends free, and insulate its ends without touching each other, or touching in on the chasis. OK.
Posted on Nov 14, 2010
  • The Knight
    The Knight Nov 14, 2010
    Hello Hans
    you dont go for voltage measurments on these leads, as all of them will give you the sam voltage, bacause the there is only a few turns of windings extra to bear in between them. You just insist on resistance measurment. Find out the common lead, and measure the resistance. A digital multimeter is preferred, because the primary winding of your amps transformer will have very low resistance, say Ohms. Set the multimeter to Ohms range and measure the resistance of all the taps, with respect to common. As i stated earlier, the highest resistance showing tap is meant for connecting 240V, to the next less meant for connecting 220v, and you needs this winding only. If you have set the selector tap to lower voltages earlier, when it is connected with selector switch,there is a chance to open the main winding. If so transformer should have to be rewined.Ok
  • The Knight
    Hello Hans
    I'll give you one more clue to get the 220V winding in your Nad Amps' transformer
    Suppose we have a small transformer with 110V,120V, 200V, 220V, 240V tappings in its primary windings. We can get these windings by measuring Ohms [resistance] of the winding. I'll give you a guess, to get value of resistance.
    0V====> 110V = 50 Ohms approx
    0V====>120V = 55 Ohms approx
    0v====> 200v = 60 Ohms approx
    0V====> 220v = 65 Ohms approx
    0V====> 240v = 70 Ohms approx
    Where 0V lead is common, which may be coloured black in most transformers.
    The above said is not exact values, and are given to you for a guess, when you measure the resistance value of the windings of your amps' transformer.
    0V====> 240v - 70 Ohms approx
My NAD C372 integrated amp was working normally everyday. One day, on pushing in the "Power On" button, it did not light up. No response at all.
It could be anything from a blown fuse from a power surge to a shorted capacitor ijn the power supply. There are fuses in all amplifiers. Locate it and test it with an ohmmeter.
Dec 16, 2013 | NAD C372 Amplifier
Sansui A-909 LED indicator(peak power meter)
Check you have 14 volts on pin 3 of the driver chip for the meter.
Apr 05, 2017 | Audio Players & Recorders
How to bridge 2 NAD 2200 amplifiers
See the picture:
http://wired4sound.net.au/systems/nad/nad.htm
Flip the switch to "bridged" and conenct a single speaker to the two red connectors.
Mar 20, 2011 | NAD 2200 2Channel Amplifier
Hello i own NAD 3150, its not working, all the indicator lights ( power, protection and soft clipping glows)
HI...
It's either failed power supply capacitors or one or more power transistors in the output amp have gone bad
Oct 05, 2010 | NAD Audio Players & Recorders
One (right) preamp blow! I've located the problem to the right C160 module. When disconnected everything seems fine. Diodes and transistors are apparantly ok measured onboard as are all resistors and...
hi...
transistors are not ok on the C160 module.
replace all the power transistors and emitter resistors for that channel.
www.bdent.com and www.ceitron.com are good for transistors
Sep 30, 2010 | NAD C370 2-Channel Amplifier
Marantz pm7200 hdam, will not power up, checked internal fuses all ok, over rid the internal power-on rely and power amp powers up but pre amp circuit still dead, any idea, power panel look fine but...
The preamp stage might be dead. Not much you can do but to bring it in. Make sure the input selector is on the right input.
Sometimes there's a "Monitor input" usually Tape2 input that overrides everything
Sep 01, 2010 | Marantz PM7200 2-Channel Amplifier
No power in NAD c350
Hi...
Have you checked the rectifier diodes / bridge rectifier . Most DMMs have setting where you can test for forward voltage drop on a diode
0.300- 0.800v depending on the type. If it reads nothing , swap the meter leads.
Also check the leads coming from the power transformer and see if there's continuity. THey will read low value ohms
Apr 26, 2009 | NAD C350 2-Channel Amplifier
No power at all on NAD C370
User manual here
http://nadelectronics.com/img/manual/NAD-C370.pdf
Read page nine for some simple troubleshooting tips and see if that helps.
It *could* be a fuse but given you've owned it for a while and NAD amps often have capacitor issues in the power supply, chances are it needs some serious work by a good tech. Contact NAD directly and see what they recommend.
Dec 29, 2008 | NAD C370 2-Channel Amplifier
Nad c350 no power at all
check your output stage for bad speakers cable or bare wire of cable touch the body of amp----short circuit speaker cable----bad speaker it self------ bad input cable or defective input device .
disconnect all and check if it is ok---start to connect one by one from input to outputs------if all above failed you must contact service center for help.
Aug 22, 2008 | NAD C320 2-Channel Amplifier
NAD 2200 2Channel Amplifier Logo
604 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
