Question about Toshiba Gigabeat F40 40 GB MP3 Player
I tried to load the software on a new computer with Windows 7. IT DOESN'T WORK
  • jondash1 Nov 16, 2010
    Rec'd your e-mail message. However, the website you noted won't open. Unable to download the driver.
    John Ondash
  • jondash1 Nov 22, 2010
    I TRIED YOU'RE SOLUTION AND IT DOESN'T WORK. . MEANING,: IT'S NOT A SOLUTION TO M Y PROBLEM. WHERE DO WE GO FROM HERE?
  • 10,319 Answers
Try this driver down load to get your to operate correctly
http://news.driversdown.com/Mp3-MP4/200904/15-8777_2.html
Posted on Nov 13, 2010
Plustek Optipro 9636T - working under Windows 7.
If you scanner only has Win XP drivers, then you have only two choices as those drivers wont work on WIN 7. One is to buy a new scanner, as you have already suggested. The other is to create a virtual machine, load WIN XP onto it, and then install the scanner drivers on the virtual machine. This should work fine as I do it for a piece of software that only works on WIN XP, however it is a bit of a inconvenience to use.
Aug 20, 2017 | Plustek OpticPro 9636T Flatbed Scanner
Doesn't recognice drive
In my limited experience such things are caused by software conflicts where substandard software replaces parts of the operating system or approved programmes with other versions. The displaced software might be lost or deleted but the operating system tries to repair things and fails.
Nero burning software seems particularly bad, working fine when first loaded but deteriorating after every restart until finally it stops working altogether but deleting it doesn't fully restore previous functionality.
Nov 12, 2017 | LG SuperMulti Portable Slim DVD Rewriter...
My Evoluent 4 mouse doesn't work with WIndows 7
win 7 driver has stopped working
uninstal the driver for the mouse , find the web site for the manufacturer of the mouse , get the download for that model and compatibility with win 7 , down load and run
win 7 os is no longer supported by Microsoft so driver bugs and other glitches are not being fixed
Jan 22, 2018 | Evoluent (VM2-LBB) Mouse
OCR doesn't work with WINDOWS 7 and my Lexmark X5650es printer
Try this approach:1. Uninstall your existing printer driver. On your computer, go to Start menu > Programs > Lexmark X5600 Series folder > Tools > Uninstall. After the uninstall process, reboot your pc when prompted.2. When your pc turns on, check if your Windows 7 is running on 32-bit or 64-bit operating system. On your computer, go to Start menu > right-click on Computer > click on Properties. Take note of the System Type.3. Use the link below to download and re-install the corresponding printer driver for your operating system:- Lexmark X5650 Printer Driver for Windows 7 32-bit- Lexmark X5650 Printer Driver for Windows 7 64-bitSimply follow the instructions on your computer screen to complete the installation.4. To re-install the Lexmark OCR scan software, insert the printer software installation CD in your pc CD-ROM drive.5. Click on Install > Install Additional Software > select the Lexmark OCR Scan Software > continue with normal installation steps.
Then try to create a PDF or Scan and Edit text (OCR) to verify that the problem is fixed.
If that doesn't help, please contact Lexmark Technical Support Center at 1-800-539-6275 for additional assistance.
Feb 13, 2012 | Lexmark X Office Equipment & Supplies
Software will not load on windows 7
Your best option is to start with the software supplier.
I have used some of the older versions of this software and I was not all that impressed as i too had some issues but more to do with printing and the C&P functions.
You dont say which version of windows 7 home basic,home, pro etc.
BUT windows 7 does have a compatibility mode that does allow you to run a program as if it was running under XP, Vista etc. you may want to explore that option
Go to the windows HELP option and type in "program compatability"
From there you should be able to get along and see if the program needs anything else or will run under a particular mode.
Note that you may have to try more than one mode until you find one that works.
Nov 25, 2011 | Punch Professional Home Design Platinum...
Windows 7 will not recognise vdr-m70 dvd camcorder
Panasonic supplied software for the VDR-M70 for Windows 98 through XP on the CD. Due to changes in the OS over time, the installer can't run under Windows 7. Panasonic has not updated the drivers for Windows 7 and Microsoft indicates that it is not compatible with any version of Windows 7.
There are work-arounds depending on your version of Windows 7. If you have the 32-bit OS, try using the compatibility mode. To find out which version of Win7 that you have, click Start > Control Panel > System and Security > System. If the name of the OS ends with x64, then you have the 64-bit version of the software. Otherwise, you have the 32-bit version.
For the compatibility mode, right click on the installer on the CD (browse Computer). Choose Properties and then click on the Compatibility tab. Select Always Run this program as and an older version of Windows (XP). Apply and Save your changes. Then right click again on the installer and choose Run as Administrator.
This may not work (and won't work for the 64-bit Windows 7). If it doesn't work, you need a machine with an older version of Windows. This can be a second computer, a dual boot computer or a virtual computer (if your hardware supports virtual computing). For most options, you will need a licensed copy of the older version of Windows.
If you have Windows 7 Pro or Ultimate or upgrade to one of them, you can have a virtual version of XP for free. Download and install Virtual PC and XP mode from Microsoft in order. Then install the software for the camcorder in XP mode as if it were your only computer. (Of course this doesn't help if your hardware doesn't support the Virtual PC.) Other virtual computer programs are VMWare and Parallels.
Note: you can not directly share files or hardware between the Win7 and the virtual computer. You have to put files on an external drive (optical, flash drive or other external hardware) to share them.
I hope this helps.
Nov 12, 2011 | Panasonic Palmcorder VDR-M70 DVD Camcorder
Machine will not work on windows 7 64 bit computer will not load singer discs bought new computer old system was X P
First, there's a Windows 7 update available atwww.Futura-support.com. Click on the lefthand side, then on CE100/150/250/350,etc, etc. Follow the directions CAREFULLY. First, be sure the uninstall ALLFutura software you've attempted to install and reboot your PC.
If for some reason this doesn't solve you're problem, I've posted a set ofinstructions athttp://www.fixya.com/support/r8955271-use_machine_windows_7_or_vista that willallow you to run the software under XP on your Windows 7 machine. This is a bitmore complicated a solution, but if you follow the instructions carefully, youshould be fine. Try the Futura update first, though.
I hope this solves you're problem. Happy embroidery!
Apr 26, 2011 | Singer CE-100 Futura Computerized Sewing...
I have recently bought a new computer and i installed the software, but the machine will not recognise the computer, can it be installed on computer with the new windows 7 or do i need an update??
Yes, it can be installed on Windows 7. Check the Futura support sight at www.Futura-support.com and look on the right hand side under downloads. There's a download listed for CE150/250/350, etc, that applies to XP 32 & 64 bit, Vista and Windows 7 32 & 64 bit. Follow the directions CAREFULLY! If this doesn't work for you, I've posted a set of instructions under CE100 solutions for running the CE100 software on Windows Vista/7 by installing a Virtual Machine software on Windows 7 that works regardless of the situation.
The update should work for you perfectly, however. Just make sure you uninstall the Futura software and reboot your machine BEFORE you do anything else and follow the instructions from the website carefully! Good luck!
Jul 29, 2010 | Singer CE350
Toshiba Gigabeat F40 40 GB MP3 Player Logo
102 people viewed this question
Top Toshiba Audio Players & Recorders Experts
James DuPont Jr
James DuPont Jr
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
