Question about Black & Decker Cmm1200 24v 19" Cordless Mulching Mower
I have a Black and Decker CM1200 Type 1 electric mower. I opened up the housing where the orange switch lever resides to replace the plastic pin that breaks as we all know. Anyway, for some dumb reason I unplugged the two black wires and the one white wire and now I don't know which goes where....any help?
I had the same problem with the plastic post breaking, but opted to go the upgrade route. I just took a look at the old clamshell a minute ago and the black wires go on posts 1 & 3 and the white wire goes on the 4th post. There should be a red wire on the second post. The black wires are different lengths which I assume prevents someone from attaching the wrong black wire to the wrong post.
Hopes this helps.
Bill
Posted on Mar 03, 2011
Black and decker electric mower wont start
Check and see if the battery is actually charged. If the battery sits run down all winter they have a habit of not holding a charge. and needs replacing.
May 22, 2013 | Black and Decker USA Black & Decker 36V...
Mm850switch for black decker wher do wiring go
Here is a picture of where the wires go on the switch.
Jul 06, 2010 | Black & Decker 19" Electric Lawnhog...
Black and Decker Electric mower #M2370 lever
you could just try drilling the case out where the lever pivots and put a long nut and bolt to hold the lever in place
Mar 31, 2010 | Black & Decker Garden
The on/off switch (handle) does not work. How can I get it fixed?
As many others have noted, the orange switch lever pivots on a plastic pin which breaks off within two years of normal use. I found a 3/16" steel rod at my local home center in the same bin where threaded rod and angle iron are kept. I'm sure brass or alumium rod would work as well. I cut off a 1.7" length of the rod using a hacksaw and deburred the end by rubbing it on a flat file.
Before working on the mower, take off the cover, disconnect one battery lead, and secure it so it can't reach the battery terminal. You don't want the mower to start up while you are working on it.
Now diassemble the switch housing. On the part of the housing where the switch is located, find where the original plastic pin broke off. If the pin didn't break off cleanly, trim it flush with a file or sharp knife, then drill a 3/16" hole to a depth of 0.45". Be careful to center the hole. I started with a small pilot bit, then enlarged the hole to 3/16". Put some tape on your bit to keep from going too deep. The plastic drills easily.
The rest is easy. Insert your replacement metal pin, reassemble everything, and test. Give the rest of the rod to a friend who owns the same mower.
Mar 27, 2010 | Black & Decker 19" Electric Lawnhog...
Have a black and decker 19in electric mower. was
The "wedge" of the plastic lever wears, so you need to replace the lever or build up that section of the lever. Some cyanoacrylate (Super Glue / Krazy Glue) and a piece of a zip tie will work.
Sep 23, 2009 | Black & Decker 19" Electric Lawnhog...
Black & Decker MM850 switch and arm pivot failure
Sep 15, 2009 | Black & Decker 19" Electric Lawnhog...
Black and decker mower switch wiring
I have a Black and Decker Electric mower #M2370, which I would like to use this year before moving to a condo. Last year, the mower was stopping and starting depending on how the lever was positioned. I suspected the wiring so I removed the on-off switch lever. The wiring appears intact. Part of plastic inside the lever maybe broken. Can i use the mower without the lever by just pushing the black button?
Aug 18, 2008 | Black & Decker 19" Electric Lawnhog...
Electric lawnmower handle is hard press which starts the lawnmover
switch problem also checked the pin housing that holds the orange lever if not worn out. if is worn replaced both.
Jun 17, 2008 | Black & Decker 19" Electric Lawnhog...
B & D flip handle electric corded mower
do you mean the orange lever came off. if thats the case you need the switch housing assy & a spring. the lever was held by the plastic housing pin or pig. some times the plastic pin worn out before it breaks.
Jun 13, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker Cmm1200 24v 19" Cordless Mulching Mower Logo
251 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
