Question about HP NetServer LP1000r
Netserver LP1000r Chassis Fan ?
Hi
I am looking for 2 chassis fan for Netserver LP1000r.
Do you know where to go to find it ?
Rdgs
Eric
epopp@gari.fr
  • 20 Answers
There are 4 fans on this unit. A Power Supply fan, a CPU fan, and two chassis fans. The chassis fans are 40mm with a 3 wire cable (with 100mm to 120mm cables ). Generic fans should work well. Cost is about $2, but shipping is $18! Look around. you might find some cheap on eBay ( OEM Replacement fans are $56 ). I just bought my LP1000r for $35.
Posted on Oct 01, 2009
    Scholar:
  • 174 Answers
Posted on Jul 02, 2008
Usb boot on lp1000r ?
go into the bios on startup
Nov 24, 2013 | HP NetServer LP1000r
What makes 511-cpu fan not detected and 512-chassis not detected
Are you seeing this error on a system you built or a pre-built system? If it is a pre-built system, check that the fans are running. Next check where the fans are plugged in, the CPU fan must be connected to the CPU fan connector on your motherboard. The chassis (rear case fan) only needs to be connected to the motherboard if you want the monitoring/PWM (modulated fan speed) option. If your CPU fan is powered directly from the power supply, change this.
If this is a system you built or recently updated the case, check your fan power connections, as above. Next check the fan speed. My ASUS board will give the "CPU fan not detected" error if the CPU fan speed is too slow. A different CPU fan will solve the problem. (I got my fan with the CPU; it works fine.)
I hope this helps. Please add a comment with more information about your system for more assistance.
May 12, 2013 | Computers & Internet
What size case fan for HP Compaq dc7600?
What size case fan? Dunno.
1) How to measure the fan? Across the fan's shroud. (Surrounding Cage) Fan stood up, measure the Height, and Width.
2) Look at the label on the fan's center hub. Write the number down.
Now which of these CHASSIS fan numbers match?
http://www.sparepartswarehouse.com/HP-Compaq,Business-Desktop-dc7100-dc7600-dc7700,Computer,Fans.aspx
A) 3777791-001
Chassis Fan - 70mm x 70mm x 15mm.
70mm x 70mm is the height and width of the fan's shroud. (Surrounding cage) [ Chassis fan stood up ]
15mm is the Thickness of the fan shroud.
Nope, not that one.
B) 451144-001 Chassis Fan - 92mm x 25mm
Could be.
C) 455310-001 Chassis Fan - 92mm x 25mm.
Could be.
Regards,
joecoolvette
Jun 11, 2012 | HP Compaq dc7600 Small Form Factor PC...
Hi i just bought 3 chassis fan and i installed 2 on top and 1 rear... there is already one installed in the front when i bought the case....i want to know wich direction i have to put my 3 chassis fans (2...
Case fans tend to blow in the air out of the side of the fan which has the four plastic bars and normally the sticker. The fan may also have a set of arrows describing direction of rotation and flow of air.
May 18, 2011 | Computers & Internet
I have a fan piece left over from reassembly. the fan is mounted on a bent 90 degree piece of metal that is perforated and probably goes on the chassis somewhere. I am stumped. Here is the piece
HI Joe, The piece you are referring to slides into the top of the chassis. if you are sitting in back of the television and the chassis is removed, the piece with the fan slides in from the top. The perforated piece slides in between the left support bracket and signal board. The fan will cover the top of the signal board, DM module and Fmt board. Once it is in place you will then plug in the usb and firewire cable at the top of the chassis. The connector for that fan is connected to the wire harness that is coming from the chassis near the dvi connection. Does this help?
Aug 01, 2010 | Televison & Video
I would like to know hao to get the manual on a fedder aeqo72bg. My ac started aknocking noise 2 days ago. it sounds like a fan belt is going and I would like to know if they even have belts?
The blower is direct drive. What has happened most likely is the blower fan center hub has most likely cracked. That results in the fan tipping as it rotates and starts dragging on the Styro-foam ait ducting... or the rear condensor fan fails (very rare) and is dragging on the plastic air shroud.
To gain access to the blower fan you must remove the AC from its mounting by removing the center bottom earthquake mount and sliding the unit out of the outer chassis.
Unless you want to make a mess you should use a wet or dry vac and remove all of the water and debris from the chassis tray.
Set 2 blocks of wood equal size at least 18 inches long about 24 inches apart on the ground and rest the airconditioner on the wood.
To gain access to the blower fan you must remove the UPPER Styro-foam air shroud. This is accomplished by removing the 2 screws and bracket between the fan motor chassis bulkhead and the condenser air shroud. Some models also have 1 more screw and bracket on the top right front of the upper Styro-foam shroud.
Now check to see if the front blower fan teeters on the motor shaft or feels loose onthe motor shaft. (my bet is yes)
To change the blower you will need to follow the steps below.
You will have to remove the 4 screws in the condensor fan air shroud on the fan motor side of the condenser. Next you will need to remove the control box and disconnect both the compressor and the fan motor from the control assy. There are at least 3 screws in the control box enclosure and you must remove them all. One of the screws has the power ground attached to the chassis. MAKE A personalized DIAGRAM especially if there are terminals vs connector plugs. Also make sure to ground the run capacitor with a screw driver several times to remove any residual charge BEFORE removing termnals. (Diagram Capacitor also!) Then remove all of the screws for the air box chassis including the rear screw under the motor. There should be at least 5 screws on the rear bottom of air box metal chassis with one of them having the blower motor ground under the head. Remove the 4 screws on the sides (2 per side) of the air box chassis. WAIT... there are 4 more screws on the left side of the evaporator coils that need removed. 2 on the air shroud chassis and 2 on the evaporator assy. Then slide out the metal piece between the air shroud and the evaporator. NOW you can lift out the blower motor with both fans attached.
Removal of either fan is accomplished by squeezing the mounting clamp and sliding the fan off the motor shaft.
If you so any coil cleaning DO NOT spray the coils from an angle it will bend the coil fins. Spray straight on with a semi diffused spray pattern. It will take much longer than you would think to clean the coils.
Reassemble in reverse order.
Thanks for using Fixya.
Kelly
Jun 19, 2010 | Fedders AEQ07F2BG Air Conditioner
WD52725 not coming on
it is not a common problem with this set. are you able to tell the pattern of the blinks.? is it (a)1 long 1 short, or (b) 1 long 2 short, or (c) 1 long 3 short. this will let you know which fan is blocked or has failed.a=Chassis Fan (above chassis) b=Ballast or Exhaust Fan
. exhaust fan is easy to see. ballast fan is hidden between ballast and vent tunnel.c= lamp fan, this is under the lamp. you can measure the yellow wire voltage on the suspected fan, if it is more then 1 volt the fan is bad or jammedlet me know whic one and i will post the part number
Dec 26, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Need to open acer aspire 3620 to replace fan
I believe that the 4020 and 3620 have the same chassis. See if this helps
To the left of the battery there is an I/O cover with 2 screws, then the heat sink cover has 2 screws. There you should see the Thermal Unit (fan). It has 4 screws. Take those out and lift the unit out.
Let me know , curious to see if they are indeed the same chassis.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 16, 2008 | Acer Computers & Internet
HP NetServer LP1000r Logo
195 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
