Question about Toshiba TDP-T90 Multimedia Projector
How do i open the Toshiba TDP-T90 projector to change the fan? i took off all the screws and the case is not opening.please help Thank you
3 Suggested Answers
  • 4 Answers
SOURCE: turns more green
apart from the lamp (which ive had several times) we did have a DLP chip cause this.
Posted on Dec 03, 2008
SOURCE: toshiba tdp-t90 projector. I rplaced the lamp on
set the beamer off, unplug the power line, press -on-/input/menue at the same time and plug the beamer to the power line again thereafter you can remove your fingers from the below mentioned buttons. now the lamp counter should be reseted to 0 hope this helps it works on a TDP-T100
Posted on Jul 22, 2010
What cable do I need to connect my PS3 to Toshiba TDP-T90?
You'll need a converter similar to the following, http://bit.ly/1hAPiMY
Oct 12, 2015 | Toshiba TDP-T90 Multimedia Projector
JUST PUT NEW BULB IN A TOSHIBA TDP-S20 ON 2/18/11 . BOUGHT PROJECTOR IN 2004 USED UNTIL THE BULB HRS RAN OUT . BULB NEVER BROKE / BURST. ON START UP WITH THE NEW BULB IN MACHINE BOTH FAN AND LAMP LIGHTS...
Your new bulb is not lighting.
Check the connections are correct.
Have you also tried putting back old bulb to see if it works.
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Toshiba TDP-S20U Multimedia Projector
Toshiba tdp-t90 projector. I rplaced the lamp on
Aug 02, 2009 | Toshiba TDP-T90 Multimedia Projector
My projector makes a really annoying noise
It is also possible that the bearing is going bad on the fan. I'd look into getting a replacement fan if that's the case. It is probably cheaper than a replacement bulb that would be needed if the fan failed entirely.
Jul 09, 2009 | Toshiba TDP-P5 DLP Projector
Problem with power point
These devices get hot when they work. they need cooling. if the cooling system get dirty and fan cant turn clearly then it stops itself for protection.  it need to be cleaned.
hope it works
May 28, 2009 | Toshiba TDP-T90 Multimedia Projector
How to change toshiba TDP-S35 lens
i got a problem with my projector, the colored break up into pieces, i want to know if how much is the price to repair it.
Mar 19, 2009 | Toshiba TDP-S35 DLP Projector
No power
please give the board to any nearer HCL'soa division office they clear the problem
May 29, 2008 | Toshiba TDP-T90 Multimedia Projector
My Toshiba TDP-ET20U Multimedia DVD Projector will not play a DVD. I can hear it reading and reading it, but it will not play. The same DVD will play immediately on another DVD player.
Hi jennydority
Have you tried cleaning the DVD player's lens with a CD/DVD cleaning disc yet ?
Give it a go , it normally solves the problem.
May 06, 2008 | Toshiba TDP-T90 Multimedia Projector
Toshiba TDP-T90 projector, lamp
is lamp cover closed firmly-is power cord good(try with another cable)-is power fuse ok!!!-is power supply ok.and gives normal rating output voltage as a the book say.all previous will check first befor lamp and fan.
Feb 16, 2008 | Toshiba TDP-T90 Multimedia Projector
COLOUR MISMATCHING
befor going anywhere change vga cable between pc and projector.-and run video source from anywhere and check colour mismatch.if you got mismatch from both pc and video go to menu and make some correction to colour . if all failed you have to pass it to service center.
Jan 29, 2008 | Toshiba TDP-T90 Multimedia Projector
Toshiba TDP-T90 Multimedia Projector Logo
85 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
