Question about Gaggia Syncrony Compact Digital Espresso Machine
The machine will brew one coffee and on the next attempt, will trip the GFI.
  • 1,089 Answers
HI
You probably have an internal leak that is hitting a power wire and tripping the GFI. It needs to be fixed before it shorts something and burns up the board.
Posted on Nov 13, 2010
Coffee maker trips gfi
Try it in a different outlet (one that is not a GFI). It could be the GFI is bad
Jan 28, 2013 | Solis Master 5000 Espresso Machine
Seacoast magic plus keeps tripping gfi breaker
try in different GFI outlet, if it trips the new one, the coffee maker is dangerous and you should return/replace it, it has a short.
if it doesn't, replace the GFI outlet, it is old.
Apr 16, 2012 | Philips Coffee Makers & Espresso Machines
Gfci trips. Hi - I have had my Saeco for 10 years now. Since earlier today the gfci trips whenever I am trying to use it. Any ideas? Thank you!
GFI safety trips whenever it detects moisture. Normally this happens when water splashes over when filling or brewing coffee. This has happened to me several times. You must dry the machine out totally inside and out. I have used a hair dryer successfully both times. It is possible that you have a short circuit. If you want to veryif that it is moisture and not a short circuit, plug your unit into an outlet that is not GFI protected. If it kicks the breaker, then you definately have a short circuit in the machine. This would require dismantling the machine to find where hot wires have come into contact with bare gound.
Sep 13, 2010 | Saeco Vienna De Luxe Espresso Machine
Turned on, heard clicking, now keeps blowing GFI and won't work
Hello Rightorl...
Everythig made by man is repairable... and to
MERCILESSLY drive the point home... even
AMAZON carries part for your "B70"... (eBay too).
Just the slightest amount of conductivity
is enough to trip a GROUND FAULT... So
you are not necessarily looking for NAIGRA Falls.
Amazon...
1 16 of 291 results for keurig parts
I believe if you search online
You can even find a KEURIG Company PART supplier:
Keurig Parts Keurig Coffee Maker Replacement Parts
- Frankly...
I love coffee ... (excessively strong)
((life is short... and I am old))... Not withstanding
my POT- FILLER... CHEMEX... smart-home daily
automatic brewing capability...
I have reverted to the camp-fire brewing method...
BOILING water, removed from heat, IMMEDIATELY
gets a mega dose of freshly/finely ground PETE's
(never to see heat again it is COLD filtered through
a Melitta #6 and stored in the refrigerator...
Drained into a three quart carafe...
Grounds are immediately distributed to the redwoods...
When my sisty wants hot coffee... Microwave 90 seconds
(taste is ALWAYS AWESOME)...
Else the BOSS (she who must be obeyed) & I enjoy
our iced LATTE Coffees in the morning...
If it is too cold... we build a FIRE first.
Life is good (12 cups at a time).
Carnac the Magnificent
Oct 22, 2017 | Keurig Platinum B70 Coffee Maker
Solis Master 5000 trips GFI outlet during brewing.
It sounds like the power filter(capacitor) located under the pump is damaged.
Oct 23, 2009 | Coffee Makers & Espresso Machines
When i plug it in it trips my gfi and it is not on
This can be caused by one of two things. (1) The GFI plug has a problem: it could be broken behind the face plate, or some of the wires in the box are so close that when you push a plug into the outlet, they touch and trip the GFI. (2) The other source is due to a defect in the appliance between the cord and the power switch. That is why the GFI faults even before it the coffee maker is turned on.
Have the outlet checked thoroughly and make any needed adjustments / repair /replacement and reconnect the coffee maker again. If it trips, the coffee maker will need to be serviced. DO NOT use the coffee maker in another non-GFI outlet until it has been checked out. The chances of electrical shock or burns is significant until the problem is found and corrected.
Oct 02, 2009 | Bunn Coffee Makers & Espresso Machines
I have a model 50 Keurig that started tripping the 15 amp GFI in the kitchen. I went to the opposite counter with out the GFI and had no further problems with power.This a.m. the machine was trying to heat...
most Keurig cofee makers will trip 15amp GFI'S .
So you should unplug the machine take all the water out wait about 1/2 hour . Then plug it into an outlet that has at least 115volts and 20 amp breaker or fuse . You can purchase plu in testers at radio shack or electrical supply store.
let me know.
Jun 27, 2009 | Keurig B50 Coffee Maker
GFi breaker blows
There is an electrical problem with the brewer. If you will please get the model and date code located on the bottom of the machine, and call customer service, we will be happy to assist you with this. The machine has a 3 year warranty and if the machine is 3 years old or less, it will be replaced at no cost. If it is over 3 years old, it will be replaced at a reduced price.
Apr 23, 2009 | Bunn BTX-B ThermoFresh 10-Cup Home Thermal...
Keeps tripping GFI outlets
The key here is to identify the problem as being either the coffee maker or the GFI receptacle... a simple test can be done as follows...
Try plugging the Coffee Maker into another GFI receptacle .. you may have one in the bathroom? If it trips that too, then you have an internal wiring problem with your coffee maker.. if it doesn;t ..then your GFI receptacle may be bad or on the verge of going bad .. either way..this should narrow the problem down to one or the other.. hope this helps..
Aug 30, 2008 | Keurig B60 Coffee Maker
Gaggia Syncrony Compact Digital Espresso Machine Logo
90 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
