Question about Intel Desktop Board D815EEA2 Universal (BOXD815EEA2LU) Motherboard
DATE & TIME changes automaically
Hi all,
I am having P3, 1GHZ, 512 MB SD RAM, with WinXP PC. My problem is DATE & Time setting will changes automatically when I putoff the system & start the system next day & also ACPI will be enabled even if we disable. Sometime system will reboot while at the time of booting ( It will show WindosXP & reboots) then i found in BIOS setup ACPI is enabled after disabling only my system boots.
When i turn off my pc my pc date and time rest i change the battery but the problem is still same.please help me how i can resolve this problem.
thanks
Danya Ali
Posted on Nov 14, 2008
    Problem Solver:
  • 12 Answers
For starters, thanks for the good description of your system!
If you feel up to it, turn off the computer and open its case, somewher on the motherboard you will find what looks like a watch battery, you may want to start with replacing that battery, - take it out and go to your local walmart or general store and find the same model battery, this should help with the computer loosing time and settings, also if the system is rebooting while starting up I would first take a look at the memory in the computer. Has more memory sticks ever been added to the system, if so you may have two or more memory sticks that are not play well with each other, or you may just have a bad stick of ram. I would test this thory by replacing the RAM sticks or try booting by just using 1 stick of ram and see if the problem still occurrs.
Hope this helps.
Posted on Jun 18, 2008
Will Mercury 810e motherboard support 1.0 GB (512 MBX2) SD RAM?
I cannot directly answer that question because you did not supply the motherboard model number. You will have to look this up yourself, here is the url for Mercury support
http://www.mercury-pc.com/downloads.php
The model number is usually printed on the motherboard, find it and you can download the manual, specs and drivers.
Mar 06, 2017 | Q-Lity 810E-T (P3810E-T) Motherboard
I have an MSI all-in-one AE1900 with 1GB RAM memory. Theoretically at least I understand it is upgradable to 2GB. I know there is no extra slot to expand but getting mixed information on whether the...
Hi lchangkee...
If you want to upgrade your ram, all you do is remove the ram that is in the computer, and replace it with compatible ram (same number) an example of that would be if your ram was SODIMM 512MB PC2100 DDR 266 512 MB LAPTOP 200pin MEMORY, then that is the type of ram you will want to replace it with but more like this.
SODIMM 2GB PC2100 DDR 266 512 MB LAPTOP 200pin MEMORY notice the only thing that changed was the amount from 512 mb to 2 gb. Most memory cards can be removed without any problem...refer to your owners manual as to where the ram is located Please take time to rate me
Aug 31, 2011 | MSI Wind Top AE1900-90SUS - Atom 330 1.6...
I have compaq presario 5000 series...and iwant upgrade my ram ...i have 128+128 sd ram so how much i upgrade my ram...can i upgrade 512+512 sd ram OR 256+256 sd ram...thank you
the RAM upgrade will depend on ur motherboard capacity and specification.
u need to check ur MB manual
if ur MB can have only SD RAM then only SD RAM upgrade is possible...DDR will not work....
so be careful while buying ur RAM
intelD845GLLy MB...the following details are from the intel website
http://www.intel.com/support/motherboards/desktop/d845glly/sb/CS-012825.htm
System Memory Features
The D845GLLY board provide the following memory features:
  • Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts
  • Unbuffered non-ECC DIMMs only
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • Serial Presence Detect (SPD) DIMMs only
  • Suspend to RAM
Caution Do not use ECC DIMMs with the Desktop Board. Using ECC DIMMs could damage the Desktop Board.
Integrator's Notes:
  • Registered DIMMs are not supported on the Desktop Board.
  • This Desktop Board has been designed to support DIMMs based on 512 Mbit technology for a maximum onboard capacity of up to 2 GB, but this technology has not been validated on this board.
Note To be fully compliant with all applicable PCI33 SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance.
hope this helps
Reg....bye
Feb 24, 2010 | Intel D845GLLY Motherboard
HP IQ775 will not boot
Hi friend,
As per your comment two reason of this issue,first one is RAM in your system is faulty,if two RAM (512-512 MB) in your system than please remove one RAM vis a versa or you have only one RAM (1 GB or 512 MB)please change it and boot the system,if same issue occur thats means  there was a problem with *********** board,in that condition go to the shop and check where is the exact fault in your motherboard.
Thanks
Dec 21, 2009 | HP iQ775 19" TouchSmart Desktop PC
I have a dimension 4100, and only have 512 in ram because it only has 2 slots, is there any way to use a bigger stick to increase ram?
Yes, if only one slot is being used you can install another 512 MB of ram which will give you 1024 MB or 1GB. If both slots have 256 MB in each one then you will need to just buy a 1GB strip of Ram. Go to the link I am posting and let them scan your computer. They will tell you exactly what you can install and the price. This is a site I use all the time and it is reputable and safe with good prices. This will require a download of the scanning tool which is safe. Allow the download. http://www.crucial.com/
Nov 05, 2009 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Can't access video on a website
  1. Click Start, click Run, type timedate.cpl, and then click OK.
  2. In the Date and Time Properties dialog box, click the Date and Time tab, and then set the correct date and time. To do this, follow these steps:
    1. In the Date box, click the current month in the month list.
    2. In the year list, click the current year.
    3. In the calendar, click the current date.
    4. In the Time box, click to select the hour, and then use the up or down arrow to adjust the hour. Repeat this procedure for the minute and second settings.
    5. Click AM or PM, and then use the up or down arrow to change to AM or PM.
    6. Click the Time Zone tab, and then click the time zone for your current location in the Time Zone list.
  3. Click Apply, and then click OK.
Jan 09, 2009 | Dell Dimension 2400 PC Desktop
Want Compatible Motherboard
I would say you can take a look at ASUS, they have a pretty good rocking line of motherboards that will handle your stuff just fine.
Nov 14, 2008 | Intel Motherboard
Can't Install RAM in DDR2 and DDR3 DIMM slots
You cannot use DDR and DDR2 ram at the same time, because its always been like that (ie, no SD and DDR, or SD and RIMM)
What you should do is switch to all DDR2 sticks.
Jan 09, 2008 | Gigabyte GA-8PE667 Ultra Motherboard
Memory Support
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
88
Nov 17, 2007 | Intel D845GVSR Motherboard
Intel Desktop Board D815EEA2 Universal (BOXD815EEA2LU) Motherboard Logo
76 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
