I can't find my manual for the washing machine ( new house ), waterline wm-001, but need to know the program settings. can you describe them ?
SOURCE: Hoover Quattro AS110 001 - no settings info!!
http://service.hoover.co.uk/manuals/pdfs/AS110.pdf
Posted on Jun 30, 2009
SOURCE: need to find a manual for Onix WM 3011 washing
IF IT'S THE SAME AS THE ALDI WM3011, i have the booklet. what did you want to know?
Posted on Sep 28, 2009
SOURCE: LG wash machine # wm 2277 hb front loader display flashes LE wont
We had the OE message come up and did the above procedures...that didn't fix it. I removed the dual pump modules (they come off in one piece...one is the recirculating pump, the other is the drain pump). Turns out, the drain pump impeller design sucks. Even though it turned when I put power to the pump, that doesn't mean your pump isn't bad. Once it is under load pumping water, the impeller can slip where the pin connects to it from the motor. We replaced the motor for $60 and that fixed the problem. Our unit is at least three years old and we have a family of four, so it does get used quite often. Nobody told us about the filter at the bottom of the unit and I figure if we knew this ahead of time, we probably could have avoided the impeller issue...but it is still a sub-par designed motor/impeller. The new one I ordered looks like an updated design so I don't see this happening again. It is quite easy to remove and replace the pump, btw.
Posted on Feb 21, 2010
blueextc3221
  • 15935 Answers
SOURCE: the program dial keeps turning and turning, and the WM does not seem to start
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
TheMobilian
  • 8220 Answers
SOURCE: I need a manual for
LG service manual and more HERE
Posted on Jan 09, 2011
Testimonial: "Great advice, Thank you!"
My LG WM 2010CW washing machine is showing this error "OE".
You have some drain problem, check drain pump, drain house, filter
Good Luck
Mar 15, 2013 | Facebook Apps
I want to run just a spin cycle with my LG wm2277hw washer
Hi dear.Your machine does not have "only spin cycle".That's why you won't have much to do with that.You can try "rinse & spin cycle" but I know it's waste of water & time.I hope that helps.Thanks.
May 24, 2010 | LG WM-2277HW Front Load Washer
How do you change drum bearing on lg wm-1290fhb washing machine
It is a difficult job in terms of handling! You require spanners and bearing puller. You require one extra assistance to hold the drum and pull from the front.
You have to change the full set of Bearings with same type and design. Check the bearing housing and the shaft before fixing new ones! Replace the water seals if any
Apr 05, 2010 | LG WM-1290FHB Front Load Washer
LG front leader washing machine;high pitch vibration during spin, the house is vibrating with it, we can feel it at the other end of the house, any fix?
You can buy rubber pads at the home center that damper the vibrations.
The high pitch noise could be an object stuck between tubs.
WM2277 service manual
Mar 08, 2010 | LG WM-2277HW Front Load Washer
I have a hp pavilion dv9000. and i need the screw for it.
Check out page 86 for the display schematics. Page 120 outlines the dis-assembly. Page 154 actually describes the screws of which you speak. You may be able to purchase them locally.
http://h10032.www1.hp.com/ctg/Manual/c01311536.pdf
Jun 06, 2009 | HP Pavilion dv9000t Notebook
INSTUCTION MANUAL REQUIRED
This online company list all Indesit WM manual:
http://www.unbeatable.co.uk/manuals/Indesit-Washing-Machines/27916330.html
From them:
Read & download instructions & manuals for your Indesit Washing Machines product, to help you install or troubleshoot any problems. Check out these manuals to help you set up & get the most out of your Indesit Washing Machines product.
no_image_large.jpg Read & download instructions & manuals for your Indesit Washing Machines product, to help you install or troubleshoot any problems. Check out these manuals to help you set up & get the most out of your Indesit Washing Machines product.
May 26, 2009 | Indesit Washing Machines
LG WM1832CW
hi linda from what you describe? the machine does wash cycle? but won't spin cycle? if the machine is a couple of yrs old ? it may well be the motor that runs machine is in need of some new brushes fitting ? they are not expensive and may be worn too low to activate the higher revolutions needed for spin cycle it is not a difficult job to drop motor off and check/replace if you have a good male/ friend? with elec competence ? have found this problem on other machines and most recent zanusi cost £5 for 2x new brushes as apposed to the £££££s the lady was estimated for a timer ? by plumber so why not check it out b4 you part with money ? best wishes/luck
Oct 16, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
82 people viewed this question
Top Washing Machines Experts
