Question about Samsung Cardo Scala 500 Hands-free Headset for Non-Bluetooth Phones with 2.5 Port Headset
My Scala 500 headset seems as if it won't charge. I plugged it in to the wall and the red light flashes and stops. I don't know if its battery is full or its a bad battery. Also if the battery does work, the headset wont turn on unless its plugged to the wall. How do I fix this?
4 Suggested Answers
SOURCE: Does not turn on
i have 4 headset with the same problem :S
Posted on May 23, 2008
SOURCE: Samsung WEP150MBE not working
whats the answer i have the same problem
Posted on Nov 19, 2009
  • 204 Answers
SOURCE: I plugged in my bluetooth
High voltage damaged your device. You need to check your charger output first.
Posted on Dec 29, 2010
Charge light on scala q3 does not go off when charging
I am more familiar with the G4 and G9 models but usually when the charging light will not go out the battery is beginning to fail. I believe I read that these models contain the same battery as the original classic Ipod. They can be found on ebay or Amazon.
I have batteries for the G4 and G9 models. I can be reached at Chris at RoamingDZ dot com. or 478-227-9445
Apr 12, 2014 | Cardo scala-rider Headset
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
HEADSET NOT TAKING CHARGE?
suspect the internal rechargeable batteries have took the dive . we do not know if they can be replaced or not SORRY
Jan 17, 2018 | TREND MT-BT08 Bluetooth Headset
Bluetooth is plugged into charger but keeps flashing red light, dont know if its charging or not
I had the same issue -- charged it for days and still red light flashing. I was ready to break it open and see if I could replace battery. Then I looked on the opposite end of the charger and seen a little round hole thingy. I put the end of a pen in there and pushed it twice and -- the red light went away . Plugged the charge in and steady red then purple and now blue. Looks like that is a reset ..Try it -- it worked for mine.
Sep 22, 2011 | Motorola Mobility H721 Bluetooth Headset
Hello. My Plantronics 210. My headphones won't come on. I had this problem before, I took it back to the store. They said there wasn't anything wrong but now it's doing the same thing. The red...
I would try deleting the headset from your phone. Do a re pair or subscribe to your phone. I am sending you a Plantronic user guide for the Explorer 220.
Good luck from Headsets Direct!
Jun 28, 2011 | Plantronics Explorer 220 Bluetooth Headset...
How to connect with bluetooh
You need to:
  1. ensure the bluetoothicon1.png setting is turned on on the handset
  2. switch on the scala 500
  3. press and hold the scala 500 power button until the red and blue lights are both flashing (you have to hold the button in for quite a few seconds)
  4. now you can search for new bluetooth devices from your handset and it should find it to enable you to connect
  5. if it asks you for a code/passcode the default is 0000 for this headset
Sep 20, 2009 | Motorola Mobility Cardo Scala 500...
I Can`t switch my headset on, and it stops charging after 20 secs
Move the call control button up or down, the indicator light will flash blue if it's paired or blue and red. If it flashes blue and red you need to pair phone with the headset. the passkey is 0000.
Jun 17, 2009 | Plantronics Explorer 340 Wireless Headset
Can't get existing bluetooth headset to work with new phone
I had that problem when I changed handsets. You need to:
  1. ensure the bluetooth setting is turned on on the handset
Jan 27, 2009 | Cardo scala-500 Wireless Headset
Headphones change batteries
Any luck with that model number??
Apr 06, 2008 | Radio Communications
Radio Communications Logo
47 people viewed this question
Top Samsung Radio Communications Experts
Michael Vincent Cruz
Greg Cann
Greg Cann
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
