Question about Samsung SyncMaster 920N 19" LCD Monitor
Vertical adjust hi can i adjust vertical size in samsung 920n? can i change aspect ratio in samsung 920n with vga input? best regards majid bagheri
  • BAGHERI Jun 19, 2008
    if yes , how?
Yes
Posted on Jun 18, 2008
DOES NOT FILL SCREEN HORIZONTALLY
You can change how your tv displays in the video setting menu under display. You will have a choice between 4:3, 16:9, 16:10, cinema or automatic. I think to fill your screen the best you should choose 16:10 but this is not going to guarantee that all channels will fill the screen. It still has to do with how it is being broadcast to you.
Jan 25, 2016 | Televison & Video
Samsung 32 LCD TV; Image horiz size is too large overruns screen L-R; See Details for more info What is the root cause & how can it be corrected? Thanks, Steve
try getting the onscreen menu up and then going to the aspect ratio setting
change that until the picture fits the screen
go -ok then exit
Sep 27, 2015 | Samsung Televison & Video
2 vertical bars on the right side of screen, thay are black, has picture and sound but no thing in the bars
That's because your aspect ratio is 4:3. To get the picture to fill the whole screen change the aspect ratio to 16:9. You can do this by pressing the aspect button on the remote (right above the channel + button) and changing it to different sizes such as cinema, panorama, and full. Try all the options and see which one like best.
May 26, 2011 | JVC PD-42V485 42 in. EDTV-Ready Plasma...
The picture size resets when the tv is turned off then on.
It also resets when you switch to a different Input... IF you have the Auto Aspect Ratio set to On! To set the Picture Size so that it won't change back each time, switch to the Input you wish to change (you'll have to do this for each Input separately), then go to- MENU > Picture > Theater Settings > Auto Aspect Ratio > and set it to Off. Once you've done this, your Picture Size setting will remain, even after powering off, or switching inputs ;)
Oct 23, 2010 | Toshiba 32E200U 32 in. TV
Hi, I was recently given a Samsung Syncmasster 2333sw flat screen monitor that I hooked up to my old Dell Dimension 8200 desktop.The monitor says the optimum resolution is 1920x1080 pixels. The maximum the...
hi bob you should be able to adjust the screen size via the menu on the monitor itself, (Available in Analog mode only) Note When TV signal is input in AV mode ,select “Screen Fit “to adjust vertical position in 0-6 levels. Image Size Note Supplied for the wide models only such as 16:9 or 16:10. You can change the size of the screen displayed on your monitor. PC signals • Auto - The screen is displayed in accordance with the screen aspect ratio of the input signals.• Wide - A full screen is displayed regardless of the screen aspect ratio of the input signals. Note • Signals not available in the standard mode table are not supported.• If the wide screen which is the optimal resolution for the monitor is set on your PC, this function is not performed. AV signals • 4 : 3 - Sets the picture to 4:3 normal mode. • 16 : 9- Sets the picture to 16:9 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • 4 : 3 - Sets the picture to 4:3 normal mode. • Wide-Sets the picture to 16:10 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note • It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • When the panel is of 16:10,the screen size options include “4:3”,”wide “,”Screen fit“.hope this helps
Jun 22, 2010 | Dell Dimension 8200 PC Desktop
27 inch Zenith TV Vertical too big
If you are using a DTV coverter box, you may have changed the aspect ratio with your remote control. look for a button marked "aspect" or "picture size" use that to change size.
If you have a cable box, you may have a similar button.
Or you may find a picture size adjustment on your TV remote.
If you do not have "aspect" button on your remote try going to set up menu and look for picture size.
Older TVs used to have a vertical size adjustment at the back. look in the manual.
If none of the above, you have a biiger problem with the TV internal parts needing attention
Mar 03, 2010 | Zenith C27A24T 27" TV
I need to find the VGA controller for the Dell 2005FPW monitor
you can use on all vga cards(you dont need any special controler), this monitor has a USB hub
and its is detected normaly on winxp or above, and the vga cards detect the monitor auto.
i give you the monitor specs, take form website
Display Type LCD display / TFT active matrix
  • Built-in Devices USB hub
  • Width 18.6 in
  • Depth 9 in
  • Height 15.3 in
  • Weight 17.6 lbs
  • Enclosure Color Midnight gray
  • Image
    • Display (projector) image aspect ratio 16:10
    • Image brightness 300 cd/m2
    • Image Contrast Ratio 600:1
    • Max horizontal view angle +88 / -88
    • Max vertical view angle +88 / -88
    Display
    • Diagonal Size 20.1 in
    • Viewable Size 20.1 in
    • Dot Pitch / Pixel Pitch 0.258 mm
    • Max Resolution 1680 x 1050 / 60 Hz
    • Color Support 24-bit (16.7 million colors)
    • Max Sync Rate (V x H) 75 Hz x 83 KHz
    • Video Bandwidth 146 MHz
    • Response Time 12 ms
    • Controls / Adjustments Zoom , Clock , Phase , Contrast , Sharpness , Brightness , Saturation , H/V position , Color balance
    • Display Positions Adjustments Height
    • OSD Languages French , German , English , Spanish , Japanese
    • Display Screen Coating Anti-glare , Hard coating
    • Video Output None
    • Signal Input DVI-D, VGA
    • Features Picture by picture , Picture in picture
    Video Input
    • Analog Video Signal RGB , S-Video , Composite video
    • Digital Video Standard Digital Visual Interface (DVI)
    Audio Output
    • Type None
    Input Device
    • Type None
    Expansion / Connectivity
    • Interfaces 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x DVI-D - 24 pin digital DVI , 1 x Composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 4 x Hi-Speed USB downstream - 4 pin USB Type A , 1 x Hi-Speed USB upstream - 4 pin USB Type B
    Miscellaneous
    • Flat Panel Mount Interface 100 x 100 mm
    • Features Security lock slot (cable lock sold separately)
    • Compliant Standards CE , CCC , MIC , NOM , PSB , BSMI , GOST , SASO , NEMKO , TUV S , C-Tick , TUV GS , EN55022 , TCO '99 , EN 60950 , ICES-003 , TUV Ergo , UL 60950 , IEC 60950 , EN 61000-3-2 , EN 61000-3-3 , FCC Part 15 B , VCCI Class B ITE
    Power
    • Form Factor External
    • Voltage Required AC 120/230 V
    • Power Consumption Operational 55 Watt
    • Power Consumption Stand by / Sleep 3 Watt
    Environmental Parameters
    • Min operating temperature 41 °F
    • Max operating temperature 95 °F
    • Operating humidity range 10 - 80%
    Sustainability
    • EPA Energy Star Compliant Yes
    Feb 13, 2010 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
    How do I adjust the screens vertical height becausee some of the printing is below the frame?
    You are in the wrong aspect ratio, either press the ratio button on the remote control (if you have this type), or go into the main menu & select the picture mode, then toggle over to aspect & adjust for a different size of picture. It looks like you are currently in the zoom size
    Oct 23, 2009 | LG 37LG30 37 in. LCD HDTV
    I can't get the picture to fully fill the screen on my 46'' TV. Model code ln46a750r1fxza. Used the ''tools'' button on the remote and tried adjusting the picture size, but it did not correct the problem....
    First set your tv to 16:9 aspect ratio. Then go to the source ie: Cable Box or Sat Box. Then go into the User Menu and find the Set Up or HD settings or picture settings. You need to set the Box to the "Stretch" setting. Right now your source box is set ot 4:3 aspect ratio.. If you have difficulty in changing the aspect ratio on the source box, call the Cable or Sat co. They can help you.
    Jul 09, 2009 | Samsung Televison & Video
    Viewing mode will only go from zoom to wide!!!! please help
    Hi!
    Found some relevant info on how to adjust your video settings... You might want to give it a try!
    Thanks! =)
    4.12 PC Input Picture Adjustment
    The Picture Adjust menu operates in the same
    way for the PC Input as for the DTV / TV input in
    section 4.2 for Backlight, Contrast, Brightness and
    Color Temperature.
    4.12.1 Auto Adjust
    When the MENU button is pressed, the On Screen
    Display (OSD) appears on the PICTURE ADJUST
    page. Press the button to highlight the Auto
    Adjust selection.
    Press the button for the LCD HDTV to adjust to
    the PC signal timing automatically.
    4.12.2 H-SIZE
    Press the button to highlight the H-Size selection.
    Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
    the horizontal size.
    4.12.3 Horizontal Shift
    Press the button to highlight the Horizontal Shift selection.
    Press the button to start adjusting the horizontal position of the picture. Use the or button to
    adjust the horizontal position.
    4.12.4 Vertical Shift
    Press the button to highlight the Vertical Shift selection.
    Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
    the vertical position.
    4.12.5 Fine Tune
    Press the button to highlight the Fine Tune selection.
    Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
    4.14.1 Understanding Viewing Features
    Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
    You can switch viewing modes using the remote control.
    4.14.2 Viewing Modes
    Normal Mode
    The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
    added to the left and right of the display image. Standard TV broadcasts are
    displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
    to as pan-and-scan or full frame. These movies were originally filmed in 16:9
    (widescreen), and then modified to fit a traditional TV screen (4:3).
    Wide Mode
    When watching a standard broadcast or full-frame movie in this mode,
    the display image is stretched proportionately to fill the TV screen.
    When watching a widescreen (1.78:1 source) program or movie, the
    display image fills the TV screen. If you are watching a widescreen
    (1.85:1 or 2.35:1 source) program or movie, there will still be black
    bars at the top and bottom.
    Zoom Mode
    When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
    program or movie, the display image is zoomed proportionally to fill the
    width of the screen. The top and bottom are cut off to remove most of
    the source material’s black bars. This mode is good for programs or
    movies with sub-titles.
    Panoramic Mode
    When watching a standard broadcast or full frame movie in this mode,
    the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
    horizontally on the left and right sides to fill the TV screen. The center
    of the image is not stretched.
    Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
    mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
    will return to widescreen.
    Jan 04, 2009 | Televison & Video
    Samsung SyncMaster 920N 19" LCD Monitor Logo
    174 people viewed this question
    Top Samsung Computers & Internet Experts
    Computer Repairing
    Computer Repairing
    Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
