Question about Garmin Approach G5 Handheld GPS Receiver
When I turn on the G5 Approach I get a message that says "This device does not support one of the maps" and then you can not find any courses listed. Under play or preview no courses show up. I have down loaded the course maps 5 or 6 times. Still the same message.
I have the same problem with my G5 Approach. Did you find a solution?
Posted on Dec 26, 2010
    Problem Solver:
  • 6 Answers
Firstly, please connect your device to a computer. You will find a folder in the device called 'Garmin'. In this folder will be multiple files that start with the phrase 'gmap'.
Please delete the files starting with 'gmap'.
Once you have done this, please re-load the courses on your device using the Garmin CourseView updater which can be found here:
http://software.garmin.com/en-GB/courseview_updater.html
Posted on Nov 08, 2013
My sd card is missing on my Garmin Approach G5 Touchscreen Golf GPS. What do I do
You almost certainly do not need it. If your map list is not showing or if it locked try this:
Oct 25, 2013 | Garmin Approach G5 Touchscreen Golf GPS
Nuvi 50lm can't find maps
There are two different things to try.
1. Do a hard reset, that should restore the software and maps to their base condition.
2. Run Garmin Express and apply any updates it shows.
http://www.resettoo.com/hard-reset-garmin-nuvi-50lm
Aug 22, 2017 | Garmin Nuvi 50Lm - Gps Receiver
MY GARMIN APPROACH G5 WILL NOT TURN ON
Check the batteries are fresh and installed correctly.
Connect the unit to your computer and run the Garmin WebUpdater.
download the latest version of WebUpdater software
If the unit is currently up to date, reinstalling the update again will sometimes fix any issues.
Sep 16, 2011 | Garmin Approach G5 Handheld GPS Receiver
When I press the side start button on my G5 Garmin GPS, only the word "GARMIN" appears and remains on the screen. Pressing the start button nor touching the screen will change anything. The...
reydriver,
The G5 user manual says in order to turn the unit off, press and hold the power button. Pretty common to Garmin GPS units. Have you tried that?
Jun 11, 2011 | Garmin Approach G5 Handheld GPS Receiver
Approach G5 screen say cannot unlock maps as soon as you turn it on. Suggestions?
There's information on how to unlock maps on Garmin nuvi satnavs at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing. I don't know if the approach G5 would unlock in the same way but there's a good chance it would since they're both made by garmin. All I can say is have a look at the information on the link, check if the information you need is available on myGarmin and if the same files are on your GPS. If all these are the same it should work.
Apr 13, 2011 | Garmin Approach G5 Handheld GPS Receiver
I put new batteries in , pushed on button, Garmin screen comes on and that's it and then can't turn off. Need to pull the batteries to turn off. Any suggestions. This is on a Approach G5
This sounds like a firmware issue try downloading Garmins WebUpdater Software and giving the unit a firmware update. If your are unable to connect the GPS to the PC you will have to send it in for warranty or repair. Here is a link to the Garmin Software you will require for the updates.
Hope this helps!
Apr 06, 2011 | Garmin Approach G5 Handheld GPS Receiver
Trying to set up TomTom 340 XL TM. downloaded new map, etc but when i want operate it, i get a 'no maps found!' message. At my TomTom Home screen, it doesn't appear that maps are not on my device but the...
It happens when the device doesn't recognize the maps. That's why - in such a case - you have to downgrade the version of the maps.
What Navcore Version do you have on your device? Here's a cart to help you.
[DON'T FORGET TO RATE MY SOLUTION IF HELPFUL! THANK YOU!]
Mar 06, 2011 | Tomtom GPS
How do I reset the date and time on Garmin G5 Approach?
It will reset automatically when you get your first GPS signal, which is very cool. Mike
Nov 27, 2010 | Garmin Approach G5 Handheld GPS Receiver
My gps says "no
Question: What should I do if my Garmin nuvi or zumo displays the message "No Detailed Maps Found That Support Routing" or "No Map Data Available?"
--> Answer: The "No Detailed Maps Found That Support Routing" or "No Map Data Available" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Nov 16, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
When I turn on my nuvi 200 I get the message "no
If you got the unit from somebody they could of used a SD card and its looking for it and the ynever switched back to the regular map... to check try this..
Settings ... Map.... on he bottom of screen you will see Map Info .. press it.... it should now say what map is loaded on the gps...
It should have a checkmark in the City Navigator North American NT, if not put one there
Nov 04, 2010 | Garmin nuvi 200W GPS Receiver
Garmin Approach G5 Handheld GPS Receiver Logo
1,242 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
