Question about Turbo Air MSR-49NM Refrigerator Commercial
What is the HP and BTU rating of the SK1A1C-L2W COMPRESSOR
    Guru:
  • 1,524 Answers
This unit uses a 1/2HP compressor. 12,000 BTU's to a horsepower, therefore it has 6,00 BTU's
Posted on Nov 13, 2010
  • 1 more comment
  • Robert Moller
    Robert Moller Nov 13, 2010
    Their web site is nuts says compressor is 1/2 HP for this model number. However their service manual says 1/3 for the compressor number you gave and the accompanying photo compressor looks small.
  • Doran Yount Jan 14, 2014
    So is it truly a 1/2 or a 1/3.
  • Robert Moller
    Robert Moller Jan 14, 2014
    1/3 HP R134A Compressor manufactured by Samsung Korea
Can a Fujitsu compressor unit be connected to multiple inside evaporator units that have different tonnage ratings. 18,000 BTU compressor and 9,000 & 12,000 BTU evaporator units inside.
call fujitsu engineering division direct and ask them about what is connected and if it works ok
logically as each evaporator has it's own tx valve as long as the compressor is large enough to run all together it should work but get the right information from the fujitsu experts
Oct 11, 2016 | Fujitsu Heating & Cooling
Compressor hot, draws 9amp tried hard start kit with no joy. used external 120vac windings not grounded, windings ~3 ohms ~ 8 ohms,
Dear Robert,
  • I am assuming you clean the coil.
  • Compressor may test out good electrically but has a mechanical failure inside.
  • Check the Run Cap.
  • Here is a link to the Service Manual.
http://www.manualslib.com/download/446846/Samsung-Rb215bssb.html
  • Click on it or paste to your browser.
Let me know the turn out.
Good Luck,
JP
Jun 08, 2015 | Samsung RS2530BSH (25 cu ft) Side by Side...
SK1A1CL2W WHAT THE H/P
SK1A1C-L2W compressor is 1/3 HP, 134 A, 1300 BTU for freezer, 4000 on a refrigerator application.
Nov 21, 2013 | Turbo Air MSR-49NM Refrigerator Commercial
What is L.R.A. for a samsung SK1A1C-L2W ?
A rule of thumb for lock rotor amps is 5 times the running load amps. That unit probably draws 3-4 amps max when running so lock rotor probably 15- 20. If its drawing lock rotor amps try a hard start, if that wont do it unit is bad
Jun 22, 2011 | Refrigerators
What is the HP rating if a 3 ton air conditioner?
Hi, this depends on the compressor that is installed in this unit. It may be a Copeland scroll, a Tecumseh, its hard to say. Most compressors are around 2 hp for a 3 ton unit. On the data plate it will tell you the h.p. of the blower and condenser fan motors such as 1/4 h.p., or 1/3. If you can get the name and model numbers from the top of your compressor, you can call a a/c, Refrigeration parts house, wholesale and they will have it in there manuals. The B.T.U. rating for your compressor is 36,000. There are 12,000 BTU's per ton of cooling, this is something that almost no one knows, but now you do. If it were a smaller unit such as a 2 and 1/2 ton, it would be 30,000 B.T.U.'s. You can look at the model number of a unit and you will see numbers like this, 024, 2-ton, 030, 21/2 ton, and 036 a 3 ton unit and so on. Your compressor alone will be in the range of a 2 horse unit, which ever the brand of compressor they installed in it. Please don't forget to rate me on this as I know you will be kind. I will be here if you ever need help on repairs or trouble-shooting your unit in the future, just use my user name below.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Sep 04, 2010 | Heating & Cooling
Frigidaire r134a compressor.how can i know the horse power
It depends the model number, 452 BTU are 1/6 HP, R134a 776 BTU are 1/5 HP.
Dec 20, 2009 | Matsushita DD73C14GAU6 1/4 HP R134...
I am looking at buying one but how do i tell what the hp is if not stated and how to find out the BTU thanks Jenine
With air conditioning, you want to go by BTU ratings, not horsepower. If you can get number straight off the compressor, an a/c supplies could get you an approximate BTU rating.
In most cases, the "Tonage" is in the model number.
Remember, 1 ton of cooling is 12K BTU's per hour.
Hope this helps.
Nov 21, 2009 | Refrigerators
Need help in AC compressor replacement. The existing compressor number is C-SB351H6B and its a SANYO.? What is the BTU rating for this compressor and what would be the replacement with a copeland scroll...
This compressor has a rating of 56700 BTU at 45 deg. F Evap and 130 deg. F Cond.
Your supplier will match a copeland scroll using this rating
Fuji
Aug 03, 2009 | Heating & Cooling
Compressor
Just have a local refrigeration store to match the numbers on the top of the compressor. It will go by BTU more than HP. Standard refrigerator uses 800 BTU's while side by sides use 1000 to 1200 BTU's..Sea Breeze
Jun 22, 2009 | Frigidaire FRS-26DR7D Side by Side...
Turbo Air MSR-49NM Refrigerator Commercial Logo
2,205 people viewed this question
Top Turbo Air Refrigerators Experts
Dennis Boxerman
ray gallant
John Tripp
John Tripp
Are you a Turbo Air Refrigerator Expert? Answer questions, earn points and help others
