Question about Paragon 4001-00 24-hr Timer Control 120v Ac Cd101
How do you turn off the timer for a amf paragon timer to get the hot water heater working?
  • 520 Answers
There should be a manual lever there that says on/off. or you should be able to turn the dial until you hear a click
Posted on Nov 13, 2010
Paragon model 8141-00 defrost timer wont turn.
Is this a used timer?
8141-00 is 120 volt timer.
Is your 120 volt Hot wire on terminal 3 and Neutral on terminal X?
Test across 3 and x for 120 volt.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
Don't buy used defrost timers... they always look good when you inspect, but never work when connected... that's why the timer was taken out of service and sold as used timer.
Save the old trippers for use on new timer.
Gene
Water Heater Timers Save Money
Mar 28, 2015 | Paragon Hardware & Accessories
Need trippers for older unknown model number amf paragon pool timer. timer is 15 - 20 years old
Paragon no longer makes timers or parts, except defrost timers.
Typically, defrost timers are not used for pools.
Open following link to possibly identify timer and tripper part number.
If you want a new timer for pools, Intermatic makes the T101 120Volt and T104 240Volt:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
If you want T100 series timer with fireman's switch that turns off heater 10 minutes before turning off pump:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#pool
If you have energy-saving 2-speed pool pump, and thermostat and pool light, then buy P1353 digital timer with enclosure. Enclosure and timer sold together as P1353ME.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#P1353
http://waterheatertimer.org/pdf/PE100-series-with-P1353-timer.pdf
P1353 is not easy to wire or program for novice, so you can add a comment or repost question on fixya and I will catch it.
Jul 21, 2011 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
My hot water heater timer must be obsolete... It is paragon model TC2 series A883-20. It looks as though the trippers X2772 would work. Can you advise?
Paragon is no longer making timers and parts, except defrost timers.
I've seen X2772 trippers selling for $50-60
Can I suggest a replacement water heater timer:
Link below shows variety of water heater timers (including Paragon products, Intermatic, Tork, GE, Sylvania, Woods). Page has wiring diagrams and manuals.
http://waterheatertimer.org/Boxtype.html
Look at label on side of tank to see if heater is 120V or 240V
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 18, 2011 | Hardware & Accessories
I have a Paragon model 4004-20 Water Heater Timer and I moved the TIME arrow. Now the water heater is not working at all. I am thinking of just restoring full time power to the water heater. I did not...
You are not supposed to move the time arrow.
4000 series time arrow is pointed at 8:00.
To set current time, lift and rotate dial clockwise until current time lines up with pointer.
Put X2772 trippers on dial at times you want water heater to turn on.
Minimum on-off with Paragon 4000 is 1-1/2 hours because trippers are so fat.
You can replace 4000 timer with electronic timer and control exact on-off down to the minute:
Electric water heater heats about 21 gallons of water per hour.
Shower uses 6-9 gallons hot water.
Bath uses 10-12 gallons hot water.
Average water heater that is not connected to timer, runs about 3 hours a day. You can make timer pay off by keeping time schedule lower than 3 hours.
Following link shows how to figure cost for electric water heater:
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
Following link shows several ways to save with water heater, plus general information to save money long-term:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Nov 21, 2010 | Heating & Cooling
AMF Model No. 7008-00 How do I know if it is working or not. Where can I get more Pins to stop the bld everyday at 5pm.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Paragon 7008-00 timer parts:
http://www.paragontimecontrols.com/parts_accessories.htm
http://www10.shopping.com/-paragon+timer+trippers
Paragon mechanical 7008-00 has 120V clock motor
-8 poles control 1-4 separate 120V loads, with 2 NO Normally Open and 2 NC Normally Closed circuits with max 690 Watts per pole.
Test 120V clock motor:
-Clock motor connects to two far right terminals. Black hot to pole M, White neutral to pole T.
-You should be able to hear clock motor running by putting ear against outside case.
-Clock motor will rotate wheel, if wheel is not rotating, then motor is not running.
Sep 21, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
I'm trying to set the times on a paragon amf 7 day timer
There should be 2 trippers for each day, the trippers slide on the outside of the dial and would point to the time of day you want your lights on and off. The silver trippers may be gone on that aged time clock, but are easily obtainable.
Jan 14, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
Paragon 4001-00 24-hr Timer Control 120v Ac Cd101 Logo
318 people viewed this question
Top Paragon Hardware & Accessories Experts
Gene Haynes
Steve
jdthefixer
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
