Question about Freecom 80 GB USB 2.0 Hard Drive
I need to intall a freecom usb external hard disk to an old computer uses windows 98 an i havent a drive Any help please? How can download s driver for this disk?
  • 5,384 Answers
Unfortunately, the company only supported: OS: Windows 2000 / XP / Vista / Mac OS X v10.3 or higher and Time Machine (OS X v 10.5 Leopard) compatible, for their USB hard drives.
You would need someone to write a driver for you or to connect to a computer with a supported OS.
I wish that I could be of more help.
Posted on Nov 13, 2010
  • Cindy Wells Nov 13, 2010
    You're welcome. I wish that I had better information for you.
Need the driver for a SMARTDISK model FDUSB-B2 external floppy disk drive unit for a old Gateway Windows 98 computer
Since it is a USB device, does Windows 98 automatically load the device-driver when it is connected? If not, connect to the Internet, and run Windows Update (http://windowsupdate.microsoft.com) and let it scan for updates. When it completes, look at the "optional" updates -- there may be a device-driver that can be downloaded.
Jul 18, 2014 | SmartDisk Fdusb-b2 Usb External Floppy...
My eclipse 180 mp3 player is not being recognized by my computer
Hi wfowler05...
This is for an external hard drive, but the same applies to your MP3 player
The problem is being caused by the Logical Disk Manager
Administrative service and possibly the logical Disk Manager service
not being started or the services might be disabled. to solve the
problem, click on the "Start" menu, click the "Run" command, and then type
in the box: services.msc , scroll down until you see both the above services.
right click on each of the services about and select properties, on the
general tab, change the startup type to "automatic" and click the start
button under the service status. do this for both of the services, and
that should will fix your problem."
For Windows 2000 and XP:
Right click on My Computer.
Choose Manage (This will open the Computer Management window).
Go to the Storage category and select Disk Management
Right click the new drive (usually listed as Hard Disk 1) and "initialize"
You now have the option to partition and format the drive.
The default settings of Primary Partition and NTFS- Quick Format are recommended for most users.
External hard drive can not be recognized, are more common on computer
failures, what's the reason caused this failure?
1, Setting the CMOS parameters
If you never used the USB external device, there may occur the case:
The system can not detect USB hard drive even if the driver is properly
installed, which was mainly due to the motherboard CMOS default port is closed, if not set to
open state, it naturally Windows can not detect the external hard drive. In order to solve this
problem, we can re-boot into the CMOS settings, and set "Assign IRQ For USB" to "Enable" in
"PNP / PCI CONFIGURATION" column, now the system can be assigned to the USB port available
interrupt address.
2, Power shortage
As the USB drive need to consume some power when it at work, if directly through the USB interface
to take power, the power supply may be not enough. Thus, almost all of the external hard drive
comes with a separate external power supply or a PS2 keyboard to take power transfer interface,
at this time you should connect external power supply or through the transfer cable ps2 connected
to keyboard to ensure that it have provided adequate power to the external hard disk,
recommended that you should ensure the external hard drive have adequate power supply when you
use it, otherwise, the external hard disk is likely to be damaged due to insufficient power
supply.
3, USB extension cable fault
USB interface type does not match the external hard disk interface ,this case caused it can not
be used. For example the standard USB interface of the computer configuration is 1.1, while the
external hard drives purchased are USB 2.0, which requires the cable connected computers and
external hard disk must support USB 2.0 standard. Because high-speed mobile device plug in a
low-speed hub, the device may not be properly installed, and some people use external hard disk
while using USB flash drives, For convenience, they directly used USB 1.1 standard cable that
supplied by USB flash drives, as a result, the USB 2.0 standard hard drive not be recognized
correctly. Just replace it by the USB 2.0 standard cable can solve this problem.
4, Windows version is too low
Pre-Windows 98 operating system does not support USB peripherals, so in any case to install the
driver, set the CMOS parameters are unable to make normal use of external hard disk. In this
case, one solution is to upgrade the operating system up to Windows 98, another way is to
Microsoft's official site, download the appropriate patch to make it can identify mobile hard
disk.
5, The system is set incorrectly
When installed driver, the external hard disk icon will be seen on the Device Manager for some
Windows 98 users, but the Explorer does not include the corresponding letter identification,
which is improper system settings. In the Device Manager, double-click the Hard Drive icon, and
click the pop-up window in the "Properties" button, and you could see disconnect, could be
deleted, synchronous data transmission and Int 13 unit four options, of which "could be deleted "
is no tick in front of the system, and simply check this option to restart your computer, you can
see in the Explorer, the new external hard disk drive letter.
While the failure of the external hard disk does not recognized are more the reasons, but
generally not the USB interface or external hard disk's own fault, so it requiring us to consider
some more from around the association when exclude it, I believe you can successfully use the
external hard disk.
Hi I had the same problem and solved it like this assuming that you are running windows xp
With your external casing powered-up (it does not get power through USB does it?) and your WinXP
PC running, plug in the USB.
You should hear 'chime', what happens then?
If harddisk is recognised here, but does NOT have a drive-letter and cannot be seen in Windows
Explorer, the answer is in Windows Disk Management
Go Administrative Tools > Computer Management > Disk Management. ( on left column)
Maximize this page. Physical Drives appear at the bottom; Logical Drives at the top.
Hopefully your drive will appear at the bottom (physically), you must then 'import' it into the
Windows installation
; Windows will put its 'signature' on the drive and assign it a logical drive letter :^)
you can try to format it here if it is new and has no info on it , check back to My computer and see if present.
Please take time to rate me
Aug 30, 2011 | Mach Speed Eclipse 180 MP3 Player
Hi i have just tryed to connect my FREECOM 160GB EXTERNAL HARD DRIVE to my imac and nothing happens at all, the light on the front of the hard drive is on but it does not show on the imac desktop, i went...
you have to download the driver for the hard drive
go to the hard drive manufacturer web site , find the down load for you model hard drive and the imac operating system
download and run
Dec 03, 2017 | Freecom (24358) 160 GB Network Hard Drive
I need to remove some photos from an old computer. Windows 98;. Is not able to be connected to wireless internet. I bought a Cruzer Blade USB Flash Drive 4 gb. Will not work. As I cannot download a...
If the Windows 98 computer does not have a USB port and you cannot copy the photos onto a floppy disk or burn the photos to a CD then the only option is the following.
Remove the hard disk and connect it to a USB hard drive adapter and then plug this into a USB port of a working computer. This computer will see this as an external storage device, you can then open the various folders and copy your photos to this computer or to a USB flash drive.
Oct 07, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Windows 7 NexStar drivers and installation needed
No device-drivers are needed. Just connect this USB device, and Windows will recognize it. If there is a "one-touch-backup" button, it won't work, but you can still use drag-and-drop to copy files from your internal disk-drive to this external disk-drive.
Jan 01, 2010 | Vantec NexStar-3 External 3.5inch...
Connect external hard disk IBM travel star 80GB USB port 2
Unless it's windows 98 you don't need a driver. If your computer can't see it, it's probably broken. Try plugging it in to another computer and see if it can see it
Oct 01, 2009 | IBM TravelStar 40GN 40 GB Hard Drive
Hard Drive not detected
If you are sure that the disk is okay, then I do suspect it is a power problem. Laptop USB ports often can not provide as much power as desktop USB ports. If possible try using an external power adapter with the disk and see if that works.
You can try some other external hard disk troubleshooting ideas, but probably it is the power.
Jules
Jun 10, 2009 | Freecom (24358) 160 GB Network Hard Drive
Freecom external hard drive classic 2.5
Have a look here>
http://www.freecom.com/ecDrivers.asp
I can't see any Mac drivers for the drive...
I found this page>
http://freecom-usb-osx.sourceforge.net/
You might be able to get some help here...
Jan 03, 2009 | Freecom (24358) 160 GB Network Hard Drive
Freecom 400GB Hard drive not recognized.its a Freecom mobile drive xxs 400gb , my pc just cant recgnize the hard drive
I'll assume your using Windows.
I'll assume it's a USB drive.
I'll assume it is an external drive.
And I'll assume it's formatted as NTFS.
Try using the USB (or FireWire) port for anouther drive to see if that is the problem, if it is then reinstall the driver for the port, through the Computer Managment Concole (assuming yur using windows).
If you formatted the drive as FAT, re-format it as NTFS.
Jan 02, 2009 | Computers & Internet
External hard drive
ya yiu can do it only you need is to download the drivers from the homesite of teh type of hard drive u r using
u hav not mentioned the name her so just simply try by searching google for the driver
Jul 28, 2008 | SimpleTech SimpleDrive 160 GB External USB...
Freecom  80 GB USB 2.0 Hard Drive Logo
307 people viewed this question
Top Freecom Computers & Internet Experts
Greg Ulan
Mithilesh Kumar
Are you a Freecom Computer and Internet Expert? Answer questions, earn points and help others
