Question about GE Q Series GSS25QGT Side by Side Refrigerator
Freezer temperature unstable - GE Q Series GSS25QGT Side by Side Refrigerator
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Nov 14, 2010
My magic chef mini fridge jumps from 55 to 49 degrees and it's set at 41. What can the problem be?
The first and simplest cause of unstable temperature readings occurs whenever people open the door, which almost immediately causes a change in your refrigerator/freezer's internal temperature. In this case, the temperature recorded by the electronic monitoring system is often comparable to a conventional thermometer located in the cabinet. What personnel often don't realize is that typical mercury thermometers have response times measured in minutes, meaning that it can take 5-10 minutes for the temperature shown on the thermometer to stabilize at the new value after a rapid temperature change.
A second source of temperature variation arises from the normal cycling of the compressor used to cool the refrigerator/freezer. Again, if the temperature displayed by your thermometer is being compared to the temperature reported by your electronic monitoring system, the response time of the thermometer may be masking the actual temperature fluctuations in the cabinet.
The final cause is due to electrical noise in the temperature monitoring system. This can often be identified from the temperature data in the form of random jumps in temperature from 0.5 to 5 degrees or more happening over a very short time period (such as seconds). The most common cause of electrical noise is the placement of wires from the sensor.
Sep 29, 2016 | Magic Chef Refrigerators
Miele KFN8993SDN Freezer temperature to high
Temperature displays
During normal operation, the temperature display shows the temperature in the middle of the refrigerator section and the temperature in the warmest part of the freezer section.
Aug 20, 2015 | Miele KFN12923 SD-2 Stainless Steel 369 l...
How can you keep a idylis chest freezer in garage during winter? temp below freezing
20 years ago guys used to put a 50 watt bulb down in the compressor area BUT the freezers today have been designed with the condenser in the freezer wall and don't retain any heat in the cold weather. Generally what you will experience is the temperature in the surrounding area drops to 10 degrees the freezer goes off and when the area begins to warm up the compressor tries to start with syrup for oil in its crankcase and cycles on its protector until it gets hot enough to warm the oil and allow it to run. Compressor life is shortened and the freezer temp is unstable. A self regulating crankcase heater could be purchased at a local supply house and wrapped around the compressor but I don't know if its ever been tried on a compressor that small or if you might overheat the compressor. ............Can you say garage heater? Its a matter of system design. All of the components for a commercial conversion are out there but a system that small is never considered. Sorry wish I could help more. Hope this helps and good luck.
Sep 30, 2014 | Freezers
Unstable fridge and freezer temperature
What is the make and model number of your unit?
Nov 05, 2012 | Refrigerators
Why do pharmaceutical companies use freeze-drying?
Pharmaceutical companies often use freeze-drying in order to increase the shelf life of their own products like different kinds of medicines that should be store in low degree temperature.
Aug 09, 2012 | Camping, Backpacking & Hiking
Freezer of F/P E411T not cold enough
It is the Thermostat of the Refridgeator which needs replacing, i have too had this problem before! Should be an easy fix.
Apr 26, 2012 | Fisher and Paykel Refrigerators
Whirlpool ED25RFXRWFreezer/Fridge temps unstable...either too hot
check the defrost timer but the cold control could be bad
Mar 01, 2010 | Whirlpool Freezers
Samsung SR S2028CSS Fridge Freezer - Fridge temperature problems
Try setting it to lower temperature. If that don't work the thermostat is bad.
Jun 28, 2009 | Refrigerators
Freezer temp
No, these fluctuations are a sign of a unstable control unit. test the control unit for its operational value and , replace the thermostats as well.
May 22, 2009 | Kenmore 64722 Top Freezer Refrigerator
FREEZER TEMPERATURE UNSTABLE
if assited check air circulation within cabinet.
check condenser if air assited, clear and clean if necessary.
failing that air probe might be dodgey
condenser fan ?
or thermal over load on compressor
Feb 19, 2008 | Freezers
Open Questions:
GE Q Series GSS25QGT Side by Side Refrigerator Logo
193 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
