Question about Nintendo Wii Console
Our game does not start when we install a disc. It also seems like our remote is not communicating with the system. The light comes on the disc slot when we insert it. You can not turn the system on with the remote. the light also comes on, on the remote.
  • 40 Answers
Try moving the sensor. also your disc mabe damaggedy
Posted on Nov 13, 2010
My Wii is all plugged in but the light is out like its unplugged. we keep unplugging and plugging it back in but it is still not working, how do I fix this?
I think you are asking about the slot illumination for the wii this is how you change it:
  1. Access the Wii System Settings.
  2. Move the cursor over the blue arrow on the right and and select it once to reach System Settings 2.
  3. Choose "WiiConnect24."
The following options will be available:
  • WiiConnect24
  • Standby Connection
  • Slot Illumination
Choose Slot Illumination
Slot Illumination (Bright, Dim, and Off)
WiiConnect24 can let you know when it has received data by making the Wii console's Disc Slot illuminate. Select the option you want, then confirm your selection.
Bright: The Wii's Disc Slot will display a bright blue light when WiiConnect24 has received new data.
Dim: The Wii's Disc Slot will display a dim blue light when WiiConnect24 has received new data.
Off: The Wii's Disc Slot will not blink when WiiConnect24 has received new data.
Feb 27, 2011 | Nintendo Wii Console
When sychronizing the wii balance board we held the sychronize button down to long and now the wii remote control won't work how do we fix this
1. Insert a Wii Balance Board compatible game disc in the Wii console.
2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
3. Open the small SD Card slot cover on the front of the Wii console.
4. Remove the Battery Cover on the bottom of the Wii Balance Board.
5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
7. The blue light will stop blinking and stay on steady once the synchronization is complete
Click here to download repair guide
Jan 05, 2011 | Nintendo Wii Console
I can not re start my nintendo balance board,
7. The blue light will stop blinking and stay on steady once the syncronization is complete
Dec 20, 2010 | Nintendo Wii Fit - Balance Board + Game...
MY WII BALANCE BOARD IS CHARGED BUT THE BLUE LIGHT WONT STAY ON.
  7. The blue light will stop blinking and stay on steady once the syncronization is complete.
click here to download repair guide if u want
Dec 15, 2010 | Nintendo Wii Fit - Balance Board + Game...
My WII remotes are not working, they are charged but nothing
open the wii remote (battery slot) and the wii slot (SDslot) there are a connect button, you need to press both button to make them communicate.
Jun 02, 2010 | Nintendo Wii Remote Controller
Bought 2nd hand wii fit, have just loaded disc and replaced batteries in board but power light not staying on board, flashes for about 30 seconds and then switches off. Does it need to be synchronised with...
    Hope this helps
    Try these steps!
  7. The blue light will stop blinking and stay on steady once the synchronization is complete.
please leave a good rating and testimonial if you appreciate my help. THNX
Mar 27, 2010 | Nintendo Wii Fit for Wii
Every time i try yo open up the disc slot to
send it in my xbox had the same problem i dont know how they fixed it but they did
Dec 28, 2009 | Microsoft Xbox Console
We used our wii fit on another wii system. After
    Try these steps!
Fore more detailed information (including pictures) on how to sync the Wii Balance Board, click here.
If you are still unable to sync your Wii Balance Board, please call 1-800-255-3700 so that they may assist you further.
Hope it helped.
Nov 22, 2009 | Nintendo Wii Fit for Wii
Wii fit
are you able to get any of your controllers to connect? if not it could be a issue with your sensor bar. please provide a bit more info
but try this first
Synchronizing the Wii Balance Board with your Wii Console
IMPORTANT: To operate correctly, the Wii Balance Board must be synchronized with the Wii console using Standard Mode Synchronization. Follow the steps below to synchronize the board to the console.
  • This procedure must be followed for each Wii Balance Board compatible Game Disc.
  • These synchronization settings will be saved even if the console is turned off.
  • This procedure can be completed only if a compatible Game Disc is running in the console.
  1. Press the EJECT Button on the front of the Wii console and remove any
    game disc if necessary. Insert a Wii Balance Board compatible Game Disc.
  2. Use the Wii Remote to select the Disc Channel on the Wii Menu screen and select START.
  3. Open the SD Card slot cover on the front of the Wii console.
    NOTE: Close the SD Card slot cover when you are finished with the synchronization procedure.
    NOTE: Replace the Battery Cover when you are finished with the aynchronization procedure.
  5. Press the SYNCHRO Button (SYNC.) on the Wii Balance Board. The Power LED on the board will start blinking (for up to about 20 seconds).
Press the SYNCHRO Button (SYNC.) on the console while the Power LED on the board is blinking.
  1. IMPORTANT: Do not press and hold the SYNCHRO Button on the Wii console down for more than 10 seconds. This will delete all of the Standard Mode synchronization information for all Wii Remotes that you use with that console.
  2. The Power LED will stop blinking and light steadily once the synchronization is
    complete. You are now ready to play the Wii Balance Board compatible Game Disc. Please refer to the instruction booklet for the Game Disc you are using for further information on gameplay.
  • Only one Wii Balance Board can be synchronized to a Wii console at a time. Up to a total of 10 Wii Remotes and accessories can be synchronized to a console at any time with the Standard Mode procedure. If additional synchronizations are made, the oldest existing ones will be overwritten.
  • The Wii Balance Board can only be synchronized to one console at a time using the Standard Mode procedure. If you change the console you are using the board with, you will have to repeat the synchronization procedure each time.
  • The Wii Balance Board uses the Player 4 (P4) connection. If a Wii Remote is actively using P4, that remote will be disconnected while the board is being used.
Aug 01, 2008 | Nintendo Wii Console
Handset goes off as soon as I press A to start a game
Make sure that the batteries that you have are good. Sometimes even newly charged batteries will not have enough juice to run the wii controller because the batteries themselves are defective.
Nov 30, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
19 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
