Question about Stoves Heating & Cooling
I have a dimplex sbn20 i put a new switch on the right hand side but now the wires have all come out can someone tell me what wire goes where,there are 3 switches with 6 contacts
hotkanni
  • 13 Answers
SOURCE: hp dv 2000 power switch wires 3
To know exact locations of the notebook inner parts, you can try the below manuals of DV2000. Hope this will resolve the issue.
http://h10032.www1.hp.com/ctg/Manual/c00729555.pdf
It is Service Manuals of your notebook model.
Posted on Sep 09, 2008
SOURCE: Broken light switch on a Nutone
The Black 120vac Line In wire goes into "L". The Black wire goes into "2". The Red Wire goes into "3". When you install the switch, the Red and Black wires will be on top of the switch.
Posted on Dec 25, 2008
  • 92 Answers
SOURCE: dimplex baseboard heater wiring
no does not matter but you must have a ground leg
Posted on Feb 24, 2009
  • 12173 Answers
SOURCE: I need to wire a 3 gang switches in a 3 gang box
before u start make sure power is off before working with electrical lines ---start with the 12/2 coming into box black [power] white [ground-neutral] and u will have 3 separate lines for the lights so u will have 4 lines total coming in the box== with the 3 light lines take the white and strip back the plastic and connect [wire nut] all 3 to the 12/2 white line --now take the 12/2 black line and connect it to the first switch gold color screw- bottom screw -now take some wire about 2-3 inch strip both ends and connect from the 12/2 black wire connection on the switch and connect to the gold /bottom of switch 2 than do the same for switch 3 connecting the wire from switch 2 so u will have power feeding all 3 switches-- now connect the black lines for the lights to the other side of each switch and ur done
Posted on Feb 14, 2010
  • 12173 Answers
SOURCE: I'm using a Leviton 1755 combo 3 switch for a bath
remove white switch one and connect to incoming white ground--all whites should be connected [hooked] together these are grounds-- switch 1 black from fan ,leave switch 2 red from fan ,switch 3 vanity black
Posted on Feb 22, 2010
Dimplex DS3311 switch is overheating and melting. What to do?
How long does it take before the switch melts?
You could try retrofitting a switch from the hardware store that has a higher watt/amp rating...
Jan 16, 2013 | Dimplex Heating & Cooling
Power window goes up but not down
That tells me the switch is faulty. The switch uses the same power and ground wires in, and reverses the connection out depending on which way the switch is pushed.
Sep 23, 2012 | Cars & Trucks
I need a new flame generator drive motor / spinner for my Dimplex Model No. 6901050100
what kind of on off switch do i need ,has one black wire and one white wire?
Oct 14, 2010 | Dimplex DS5598 Mid-Size Heater
I have a jeep that was converted to a 12 volt system., and a solenoid switch. 1. I have one wire going from the Alt. through the cable to the battery. 2. The battery cable goes to the right side of...
What you have doesn't sound quite right, nor does the advice you are getting, though I don't think it would cause a short either.
I think the right way depends on what you want the amp gage to measure. If you want it to read the total output of the generator, you have to connect everything in the car to the other side (opposite from the generator wire). On the other hand, if you just want it to measure what current is going to the battery, then you put the accessory wires on the same side as the wire from the generator. I have made 2 diagram below. A volt meter is easy, and you can have both, if you like. A voltmeter just goes straight to the battery terminals if you want to know for sure that you are charging. You can use plain ground and the alternator wire, but then if there is a fusible link from there to the battery you are not always sure the voltage is getting to the battery. Does this all make sense?4603398.jpge9d6f29.jpg
Sep 28, 2010 | Jeep CJ Cars & Trucks
I want to jump the drivers side window to make it roll up for my friend who can't afford the new switch right now but I cant find a drawing of the quick connect plugs that have the wires labled. With out...
It is real simple, You don't need anything fancy, Take the switch out of the arm rest, it should pop right out, You have in your hand the hot wire for the window, which should be hot, and the switch, and the lead to the window motor. If you take the switch apart, you can usually get them working with a little scrubbing, most of them get wet from the window being open and the corrode. I got all mine working just by cleaning them. But, if you just take the wires off the switch at the connection, you should be able to see what is the driver's window, you can run a hot wire to it and it should go up, or down, If it goes the wrong way, reverse the wire. The hot wire is coming into the switch, should be 2 wires in and about 10 out. Hope this helps.
Aug 27, 2010 | Ford F-150 Cars & Trucks
Have hand control wireing problem ,,,, need to know what color wire does what ,,,, got the left hand control to wire up on a older bike,,,,, hooking up trun sigals and head light control,,,,what color...
This information applies to the vast majority of Honda motorcycles. Colors for the right handlebar switch are: Grey sends power to the turn signal switch. Light Blue goes from the turn signal switch, to the right turn signals. Orange goes to the left turn signals. Light Green goes to the horn button.
The left handlebar switch: Yellow With Red stripe goes to the starter button. Black wires take power to the headlight switch and the kill switch. White goes to the headlight low beam, Blue to the high beam. Brown / White goes to the tail light, running and instrument lighting. Black / White comes from the kill switch and delivers power to the ignition coils.
I hope this helps.
Nov 06, 2009 | 1982 Honda VF 750 S
Hi, I have a connex 4600 turbo and I have a problem with the talkback on/off switch wiring. Can you tell me were the white wire attaches to from the switch? Thanks
The white wire coming from the Talkback switch goes to The middle of TR30. This location is towrd the back of the radio on the right hand side by the transformer with the radio facing at you!!
Jun 06, 2009 | Magnum 257 CB Radio
Help
Dimplex has a number for you to call: 1-800-668-6663 ext# 358 TELL THEM YOUR PROBLEM AND THEY WILL PUT YOU IN THE RIGHT DEPARTMENT. I had problems with the main switch and they sent me a new one.
Nov 05, 2008 | Dimplex Compact Electric Flame Stove...
Display screen upside down
It's broken wires to a switch inside the rotating mechanism. If you take the screws off of the screen and the rotating mechanism and remove the grey plastic covers you'll see a black switch inside a white plastic mounting that is anchored around the bundle of black wires going to the screen.
You'll be able to see the metal tab that rotates down to activate the switch when you swivel the screen (do this carefully with the covers off so you don't wreck the screen by asserting too much stress on it).
If you know someone that can solder tiny stuff, take it to them. It doesn't matter which wire goes to which terminal on the switch. You should see two broken wires in the black bundle - those are the ones that need to get reconnected to the switch. I used transformer wire to fix mine, as the insulation on transformer wire is painted on (and will need to be removed from the ends with a small file) instead of having plastic/rubber insulation that can melt when soldering.
Once the wires are reconnected, insulate them using liquid electrical tape, then put the wires gently back into the bundle, and make sure that the stress points don't land right on your solder connections. After that you should be good to go.
It's not a job for someone who hasn't soldered before... better left to someone with steady hands and the necessary equipment.
Hope that helps!
May 15, 2008 | Canon PowerShot S2 IS Digital Camera
Dimplex DS5598
Disconnect power to unit before attempting to repair unit.
1.With the front door closed,gently place the stove, door side up on a flat surface.
2.Remove the heater assembly retaining screws located on the bottom of the stove with a screwdriver.
3.Lower the heater assembly off of the bottom of the stove being careful not to damage any of the wiring.
4.Disconnect the wiring clips and connections noting their original location.
5.Remove the heater assembly mounting screw and remove the heater assembly.
6.Properly orienate the new heater assembly and connect all of the wiring clips and connections.
7.Reassemble in the reverse order as above.
Pleas note, if you are not comfortable to do this please call your local dealer on Dimplex or go to the Dimplex website and they can locate someone for you.
Apr 06, 2008 | Dimplex DS5598 Mid-Size Heater
Heating & Cooling Logo
Top Stoves Heating & Cooling Experts
paulcarew
Carter Glass
Level 1 Expert
Are you a Stoves Heating and Cooling Expert? Answer questions, earn points and help others
