Question about Logitech QuickCam Messenger Web Camera
Need to install with out disk - Logitech QuickCam Messenger Web Camera
It is not formatting., please help me
hi
follow these instructions
Instructions Things You'll Need:
  • Windows installation media (and product key)
  • Manufacturer software
  1. Ensure that the hard disk is installed properly in the laptop. The drive cannot be formatted before it is installed, or if it's not installed correctly.
  2. Gather the required software. The type of media will depend on the hardware in your laptop. Older computers without a CD-ROM drive, will require the use of the operating system floppy disks. Laptops that can run Windows XP require the installation CD and product key. Older versions of Windows also have disk-formatting capability in the installation process, and the installation media is either a CD or floppy disk.
  3. Place the installation disk or manufacturer software in the drive and then boot the computer. Early in the installation process, the Windows installer has a step that will detect any installed hard disks and allow for them to be formatted. The software from the disk manufacturer will also detect the hard disk and give you the option to format the drive.
  4. Determine which file system is to be used. Windows XP will either work on a NTFS file system or an older VFAT file system. Choose the desired file system when prompted.
  5. Decide whether the whole disk should be formatted or if the disk will be partitioned and each partition to be formatted separately. The Windows installer includes a menu-driven utility that will create hard disk partitions before formatting. If the hard disk is being formatted to replace an existing Windows installation, delete the existing partitions and re-create them.
  6. Format the hard disk with the Windows installer when prompted. The Windows installer will let you know when it is time to format the disk and ask for confirmation.
this should help you.
Nov 28, 2010 | Computers & Internet
Installation of XP MCE won't finish
You need to set the pc to boot from the install disk. Then it should detect the failed install. Either select a new location or over write or format the disk and install.
Trying to recover from a failed install is usually far more trouble than its worth. You usually end up with a unreliable install and nothing but headaches.
Mar 23, 2010 | Microsoft Windows XP Media Center Edition...
Hi, trying to install windows xp on an acer 5920g. After the installation cd asks you to hit the enter key to start the installation there is a complaint about not finding a hard drive to install to. I...
You do not need a hard disk controller driver. The hard disk is configured in the BIOS automatically.
If Windows install cannot detect the hard disk then either the hard disk is faulty or the motherboard disk controller is faulty.
Re-seat the hard disk, it may not be making proper electrical connection and then go to the BIOS configuration to see if it detects the hard disk, if not then the hard could be faulty or the disk controller is faulty. In most cases it is the hard disk that is faulty.
To further test the hard disk, remove the hard disk and connect it to an USB hard drive adapter, then plug it into a working computer's USB port. If this computer does not see it as an external hard drive or you cannot open the various folders and files, then the hard disk is definitely faulty.
Then you need to replace the faulty hard drive.
Feb 24, 2010 | Acer (91AD275018) SCSI Controller
How i can format my laptop toshiba L300D can anyone tell me how to do it plz
If you have the windows install disk, just put it in and start a new install..there will be an option come up in the installation to format the drive.
If your laptop has a second hard drive listed that is very small that the recovery partition...go to it and run the recovery program
Aug 27, 2009 | Toshiba Satellite L300D-ST3501 Notebook
Hard drive
You need to use a Windows install disk, or the computer recovery disk.
At startup of new windows installation, chose new installation and then chose the option Format hard drive.
Note: the windows install disk must be bootable, Upgrade install disk (non bootable) does not have the format option.
Regards
Nov 05, 2008 | Toshiba Satellite A135-S4527 Notebook
Need the installation disk..Please help me
go to driverguide.com and request the software it will come either as a download or a link to the manufacturers site
Sep 12, 2008 | Vivitar ViviCam 3610 Digital Camera
Need to download installation disk
Vu Point binocular DB-E130 VP
need download disk
Apr 28, 2008 | Optics
Logitech QuickCam Messenger Web Camera Logo
12 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
