Question about Buffalo Tools Rotary Tool Kit 41 Piece
I have a Durabuilt Rotary Tool with Flex Shaft (model 085-06-0614) and I am missing the driver cap needed to hook up the flex shaft. I've looked around and can't find a replacement; is it possible to order a replacement driver cap? If not, I'd be interested in buying a new flex shaft attachment; I bought a Dremel flex shaft but it didn't fit. Thanks in advance for any advice.
Have Dremel MOD 395 motor runs and speed control works bot shaft won't turn--worth fixing ??? and how
Hi Larry, The tool that you require parts for was discontinued many years ago. Limited parts are available from Dremel. Inside the tool is a flex coupling and spline driver. The flex coupling is # 2615294309 and the price is about $ 1.25. This is the hollow plastic sleeve about 1" long with grooves on the inside, that goes between the motor shaft and the output shaft. The spline driver is # 2615294308 for about $ 1.00. Spline driver sits on the direct end of the motor shaft. The flex coupling sits over the spline driver. Spline driver is about 1/4", hard plastic with grooves on the outside. Total shipping for orders under $ 5.00 is $ 2.50. Orders over $5.00 is $ 4.00. There could be a tax charge depending on which state you live in. Here is how to order: Call Dremel Customer Service at 1-800-437-3635 , Monday-Friday from 7 am to 6 pm central time. VISA, MasterCard or Discover to place a Visa, MasterCard or Discover order. To order by mail: Dremel 4915 21st Street Racine, WI 53406 USA 1-800-437-3635 ext. 3636
Feb 14, 2013 | Dremel Variable - Speed Multipro Rotary...
Flex shaft attachment won't work
find the little square attachment and place on the end of the dremel tool. I didid the same thing. Worked fine after I put the other part on.
Nov 06, 2012 | Dremel Variable - Speed Multipro Rotary...
Where can I get a flex shaft attachment (Model 225 T2)?
Check w/ Home Depot and/or Lowes. If they don't stock they can get quickly
Jan 04, 2011 | Dremel Variable - Speed Multipro Rotary...
My Dremel tool motor still works but shaft won't turn?
Here's the email from I got from Dremel (in my case the flex coupling broke):
The flex coupling is # 2615294309 and the price is $ 1.25.
The spline driver is # 2615294308 at $ 1.00.
5.00 is $ 4.00.
I have provided ordering instructions below.
To order by phone: 1-800-437-3635, Monday-Friday from 7 am to 6 pm
central time. VISA, MasterCard or Discover is accepted.
To order by mail:
Dremel
4915 21st Street
Racine WI 53406
Dec 06, 2009 | Dremel Variable - Speed Multipro Rotary...
Flex shaft becoming hot during use, this hasn't always happened. with just a minute or less of use it is heating up to the point it can't be held
remove the flex shaft from the tool and check to see if it turns freely .. if not then try lubing the end bearigs .. use light machine oil ..not wd40 ...
Nov 05, 2009 | Dremel 400 Xpr Rotary Tool
Kawasaki Rotary Tool is missing the square collet nut
I am working on getting a website for this company, but you can try Alltradetools.com and see if they have anything, they distribute them.
Oct 02, 2009 | kawasaki 840168 Green 150 Pc Rotary Tool...
Flexible shaft not working all-in-one rotary tool
check and see if you have the right collet insert in the chuck if it is too big it wont lock the shaft. does the chuck turn? if so your collet is not locking the flex shaft
Jul 09, 2009 | Dremel 400 Series Xpr Rotary Tool Kit with...
Broken flex shaft on Dremel model 232 broke
You can go to Dremel.com and find assistance or call their toll free number at 1-800-437-3635 and speak with their tech assistance. Let me know if you still need more help. Also I tried using the model number provided and it came up empty that is why I am directing you to this site yourself.
Feb 15, 2009 | Dremel Variable - Speed Multipro Rotary...
Dremel Flex shaft attachment model 225
Dremel has an exchange program for the 225 Flex Shaft. Send your flex shaft and 17.90 and they will exchange it for you. Send it to DREMEL 4631 E. Sunny Dunes Rd. Palm Springs, CA 92264 Their phone number is 1-800-275-2052. Hope this helps. Dave
Nov 09, 2008 | Dremel Variable - Speed Multipro Rotary...
Using the flex shaft attachement.
I dont think it should get that hot. Dremel has a program for the 225 Flex Shaft and for 17.90 they will exchange it for you. Send it to DREMEL 4631 E. Sunny Dunes Rd. Palm Springs, CA 92264. Their phone number is 1-800-275-2052. Hope this helps. Dave
Nov 02, 2008 | Dremel Variable - Speed Multipro Rotary...
Buffalo Tools Rotary Tool Kit 41 Piece Logo
399 people viewed this question
Top Buffalo Tools Tools & Hardware - Others Experts
Are you a Buffalo Tools Tool and Hardware - Other Expert? Answer questions, earn points and help others
