Question about Brother MFC 7840W Printer
I own a brother mfc 7840W and want to scan to a word file then convert it to a pdf how would I do this?
  • 428 Answers
If you already know how to scan ordinarily, you could actually scan and copy it to word and convert it from the word button menu.
If you are using windows xp, go to my Computer and double click on your scanner icon listed there. The scanner dialogue box comes up. Simply follow the on-screen instruction there to complete your scan.
If you are on windows vista go to start/All programs/windows photo gallery. When it opens go to file/import from scanner or camera. The scanner dialogue box comes up and you can select your scanner and follow the on-screen instructions to complete your scan.
When done go to to your pictures folder or your scan folder, depending on your settings, locate your scan, copy it, paste it in Word and convert it to pdf.
Posted on Nov 13, 2010
    Guru:
  • 254 Answers
Hello there
first thing, scan the document and when you typed the filename below that box is option, you can select what extension name you want to that file select pdf and click save. be sure you have pdf reader or acrobat reader etc..
Thanks
4 Suggested Answers
CarlGehrke
  • 169 Answers
SOURCE: Not able to scan to pdf file with Brother MFC-240C
What you seem to want to do is not possible. Let me explain:
A file that has its data in the Adobe company Portable Document Format (or a pdf file) contains various objects that are described to the computer using a superset of the PostScript language, some of them can be images.
A file that comes from the scanner is first a very organized set of pixels and gets put into a more compact form by using a well known process as defined by the Joint Motion Picture Experts group. This is a roundabout way of saying that it has a format that isn't PDF.
What you CAN do:
a) open the jpeg file with a Macintosh, using the Print command from the file menu make a pdf file that has the image in it.
b) buy and install a PDF printer driver on a Windows machine, and then follow the same process as A above.
c) Use your favorite PDF creation program to make a file with the image embedded.
Carl
Posted on Dec 10, 2008
  • 903 Answers
SOURCE: I'm finding that the scanning
Hi, you can reduce the file size by decreasing the DPI (dots per inch) or resolution of the scanned image. This can typically either be done from the scanner's control panel or from the software installed on your computer. The less DPI you set it for, the smaller your file will be.
Some scanners will also allow you to compress files. If the MFC-7840W will let you, the option would be in the software program, and it should say "enable file compression" or "enable image compression" or something similar.
Posted on Sep 14, 2010
SOURCE: Brother MFC-7840W Printerwill only give me Scan To FTP option now
i had the same issue - was previously able to scan to a number of different formats, then switched modems, providers and then only the scan to ftp option came up.
took me about an hour to figure out the solution, but now it works
for windows users: * go to your control panel * go to the scanners & cameras section * your printer/scanner should show up here * right click on it and select 'properties' * select the network settings tab and then -- enter in the correct ip address here OR -- specify your machine by name (enter in name here)
hope this helps!
Posted on Jun 21, 2011
Hello, I have MFC-7840W and it only scans in picture format but I want to scan my files in pdf format. I do not have control center on my computer. I tried to install it. after installing files I got...
I'm not sure what all your printer capabilities are so one way around the problem is to log onto filehippo.com, download and install a program called PDFCreator. Then just use it to convert your scanned files to .PDF docs.
http://www.filehippo.com/download_pdfcreator/
Aug 23, 2011 | Brother MFC 7840W Printer
7840w scan multiple pages to PDF
You need to install a printer driver PDF program on yourcomputer first. There are quite a few freeware PDF writer programs on theInternet you can download one such as CutePDF.
Scan your document then click on File - Print and select the PDF writer as theprinter device. Then name and save the PDF file. http://www.cutepdf.com/
Apr 29, 2011 | Brother MFC 7840W Printer
My Brother MFC-7840W scans into TIF files as individual pages. At my former job, we scanned directly into multi-page PDFs. What am I doing wrong?
You need to install a PDF writer program first. There arequite a few freeware PDF writer programs on the Internet you can download onesuch as CutePDF.
Scan your document the click on File - Print and select the PDF writer as theprinter device. Then name and save the PDF file. http://www.cutepdf.com/
Feb 21, 2011 | Brother MFC 7840W Printer
The manual that comes with my brother MFC-7840W covers all functions ACCEPT scanning! How do I scan multiple pages into ONE file so I can send a single file to someone. Thank you, Jeff Vanskike
Information on the scanning function can be found here:
http://welcome.solutions.brother.com/bsc/public/as/au/en/faq/faq_list.html?reg=as&c=au&lang=en&prod=mfc7840w_all&Cat=107
In order to scan a multi-page document into a single file, you must configure the scan to use a file type that supports multi-page documents. For illustrated instructions of how to scan multiple pages into one file instead of each scan being saved as a separate file go to here:
http://welcome.solutions.brother.com/BSC/public/as/au/en/faq/faq/000000/002500/000078/faq002578_001.html?reg=as&c=au&lang=en&prod=mfc7840w_all&Cat=107
Feb 10, 2011 | Brother MFC 7840W Printer
I'm finding that the scanning on the brother MFC-7840W creates a big file (a two page document is over 2MB). Is there a way to condense the pdf files?
Sep 14, 2010 | Brother MFC 7840W Printer
How do I get the scanner to send as a PDF instead of jpeg?
You will need to open the control center program which is installed when you install the printer on your computer.
Start, all programs, Brother, control center. Click on configuration then scan then file (or which ever you normally scan to). There are two tabs at the top, change the file type at top of each to pdf and press ok.
Jun 30, 2010 | Brother MFC 7840W Printer
Scanning to PDF format.
I know that the Brother MFC-7840W came with a program called PaperPort, which will allow you to scan 1 or more documents into a PDF file. Perhaps your scanner supplied the same program.
Apr 19, 2010 | Microsoft Windows Vista Home Premium with...
I want to Scan and send by email in PDF format all pages !!
Looking at my manual , it tells me you have a software user guide on the cd-rom ....this is where you will find the answer.
Jun 02, 2009 | Brother MFC 7840W Printer
hope this helps!
Jan 18, 2009 | Brother MFC 7840W Printer
Brother MFC 7840W Printer Logo
234 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
