Question about Sony LMD-1410 14" LCD Monitor
Sony Monitor LMD 1410 has a small light and can not adjust brightness! If you can send me an schematics diagram for this product! Thank you very much!
3 Suggested Answers
  • 156 Answers
SOURCE: How do I adjust brightness on Dell E152FP monitor
Have you tried all the buttons? Dell says that there is an adjustment for this.
Posted on Jul 03, 2009
budmrtn
  • 11361 Answers
SOURCE: how to restore default settings
Here is the user manual:
http://pro.sony.com/bbsccms/assets/files/mkt/med/manuals/lmd1420.pdf
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Dec 31, 2010
I need the block diagram or schematic for a monitor.
N Peabody,
Unfortunately, Dell does not have the schematics for the monitors that can be sent to customers.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
#iwork4dell
Sep 24, 2014 | Dell ST2410B 24" LCD Monitor - 16:9 - 5 ms...
Lmd 9050 menu button doesn't work
you will need to remove the back cover to access the button panel board. then check for a loose connector, if ok check for an stuck up switch in the button panel.
Nov 15, 2012 | Sony LMD-9050 Monitor
My Sony Projection Television KP-53HS30 which is about 9 years old has a problem with the Convergence, the Flash Focus will not fix it. I think I can fix it if I have the schematic.
Hello
I've the schematic diagram of Sony KP seris chasis. But I can't send it to you by this site as it exceeds the uploading capacity, and also prevent me from sending Adobe Reader files and the file capacity comes upto 10MB. If you send your email address to me by Fixya, I'll send it to you by Yahoo. OK.
Apr 12, 2011 | Sony KP-53HS30 53" Rear Projection...
I have a Sony 1410 LCD monitor, when it is powered up the screen displays vertical coloured lines on the left hand side for about 60 ml wide and the remainder of the the screen displays grey and black...
In most cases, this could be due to two factors. One - Your video card is losing life. Two - Your Sony monitor is almost dead. Simple way to trace the root cause is - borrow a monitor from your friend or someone and check. If the borrowed monitor works fine - it is the video card, that should be changed. Else, go for a new monitor.
Lastly, often people forget to check the cables. Sometimes broken pins or bent pin at the connectors could cause the problem too.
Mar 04, 2011 | Sony LMD-1410 14" LCD Monitor
Is this dell compatible
If your video card outputs Analog Composite, Y/C, Analog RGB and Analog Component Signals, then yes.
These are more like monitors you would find at a TV station for monitoring video feeds and the such, not so much for gaming or PC use.
Jun 27, 2010 | Sony LMD-1410 14" LCD Monitor
Monitor problem
Appreciate the "Ask Me".
I am assuming that you have more than just familiarity with electronic components and circuitry, the use of a DVM and a soldering iron. Further, that you have access to a service manual.
Width problem is basically insufficient horizontal deflection, then analysis would have to be in the horizontal section. Areas to initially focus on:
  1. 12V line and pin 29 of IC401;
  2. 110 V peak to peak at collector of Q403, if yes check Q 402 & 404 as well as T401;
  3. other components that affect the horizontal size are:
  • IC201
  • Q 405, 406, 407 & 408;
  • D409
  • L401
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 06, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
CRT monitor too bright
I have/had same problem. I have ATI Radeon display adapter and in driver settings there was adjustment for brightness. I adjusted that to minimum and now the brightness is pretty good (still little bit too bright, monitor setting 0%). Other succestions welcome...
Sep 28, 2006 | Keytec Sony Multiscan E500 21 in. CRT...
Sony LMD-1410 14" LCD Monitor Logo
48 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
