Question about Toshiba Satellite A60 Notebook
Touchpad stopped working when a friend openned the laptop to fix the DC power pin. reinstalled driver, power cycled, disabled and enabled touchpad, still only works with mouse. keyboard works fine
  • 2,567 Answers
Most probably, your friend disconnected the cable connecting the touchpad to the motherboard while disassembling the laptop to fix the DC power pin, & forgot to reconnect it back.
You will need to partially disassemble the laptop again & reconnect the touchpad to the motherboard.
Posted on Nov 13, 2010
My Eeepc 1008ha touchpad have stopped working, even after having reinstall the touchpad driver !!!
Try holding the Fn key and pressing F3. That will toggle the touchpad between enabled and disabled.
Please leave feedback if this was helpful. Thanks.
Feb 22, 2011 | ASUS Eee PC 1000H Laptop
Acer aspire one netbook touchpad wouldnt work could only use with left click - trying to fix managed to disable touchpad by mistake now curser wont work how can i enablei it when cant use curset? please
If possible try to connect a USB mouse and use that to enable the touchpad...
After that reinstall the drivers for the touchpad the issue should be fixed... Even if you still have the issue then call the computer manufacturer.
If you dont get a USB mouse.. Then turn on the computer get into safe modem by tapping F8... Try to check in safe mode whether the touchpad is working.. If its working reinstall the drivers the issue will be fixed
Oct 14, 2010 | Acer Netbook
My mouse pad stopped working on my Compaq Presario 2200.
if this is the touchpad, try to reinstall the touchpad driver. You can uninstall it through the device manager while using an external mouse, then download the latest driver from your system manufacturer's web site. After that, make sure the touchpad is enabled and if this does not work, you may need a replacement touchpad, though you may also try system restore or OS reinstall.
Aug 31, 2010 | Computers & Internet
The touchpad stopped working after a powerpoint presentation i made. A friend helped me set up the laptop to the projector and he did press keys. Did he accidentally press some inactivating key in the...
FN + F9 should enable / disable the touchpad goto control panel - mouse - and see if you can change disable/enable touch pad from there Otherwise post back what windows version you have
Touchpads
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to classic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 10, 2010 | Toshiba Satellite M55-S325 Notebook
My touchpad has stopped working. Device Manager
Comment back with Make and EXACT model
Mar 24, 2010 | Computers & Internet
My touchpad for the 5633 has stopped working
is not a problem, try to activate you pad with FN key + F7 (this is secvence for enable/disable pad).
If this is not work then reinstall you pad drivers.
Feb 28, 2010 | Acer Aspire 5630 Notebook
My acer 5532 touchpad has suddenly stopped working... any ideas? mouse doesnt move and usb wireless mouse doesnt work either.. although it does on myu sister's laptop
Thanks. The Fn F7 idea did not work, the Enable/Disable toggle in Control Panel made no difference BUT the simple pressing of the TINY finger pointing next to the power button DID work. Duh!
Nov 15, 2009 | Acer Computers & Internet
The "mouse" pad on my Acer Aspire 5920 laptop has suddenly stopped working. What can I do to mend it
You can try pressing the Fn + F7 key to activate it, if that does not help you can check in the BIOS if the touchpad is disabled.
Thank you for choosing Fixya
Nov 11, 2009 | Acer Aspire 5920-6727 Notebook
TouchPad not working
if not a software problem then check the hardware...because you restored already the OS right?..it means,the same problem..did you installed the touchapd driver,hotkey or any application driver...if yes...means not a driver problem...it is problem with the cable in touchpad between the board connection...if you try before to open some laptop specially that model,you open and check the cable that link touchpad and mainboard....because i had same problem before..check and try...but focus first in touchpad driver,check some settings,if you cant do nothing, open and check the cable...
Jan 01, 2009 | Acer Aspire 5920-6727 Notebook
Cursor(pointer) cannot be moved by using touchpad but possibe wit
This happens to me also. Check whether the touchpad is enabled (laptops do have an option of enabling / disabling the touchpad). Secondly, you can try reinstalling the touchpad driver. Uninstall and then re-install the driver. Re-boot the system. Try using the touchpad.
Hope this helps., if so, rate me.. thanks - billa
Dec 20, 2008 | Lenovo Thinkpad R61i Notebook PC
Toshiba Satellite A60 Notebook Logo
221 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
