Question about Dishwashers
Dishwasher won't work after electrical outage
Good morning,
I have a maytag Jetcleaner EQ Plus that has been working just fine. Yesterday, we had a power outage that lasted approximately 19 hours before the electric was restored. When the lights came on, the dishwasher did not. I flipped the breaker and when the dishwasher came on, all of the lights were lit and I was unable to clear the display (almost like it was frozen and needed to be re-set). I asked Maytag if there was a re-set button and they said I need service. Is there an easy fix for this or have you heard of this problem before?
5 Suggested Answers
SOURCE: Dishwasher
if you installed a new garbadge disposal at the same time have you popped the factory drain plug on the disposal where the dishwasher drain tube connects to the disposal. The plug is inside the disposal dishwasher connection tube . You cant see it . Just drive a screw driver through it with a hammer.Itt will pop out and then the dishwasher will drain.Just a thought.I forgot to do this to mine.
Posted on Mar 17, 2008
SOURCE: maytag dishwasher jet clean eq plus water not filling
My Maytag Jetclean Flexiload is 4 years old. Upon choosing a program the timer counts down but little action is heard. Near the end of the cycle an Error message comes up. The dishes are stiil uncleaned.
Posted on Apr 24, 2008
SOURCE: Maytag jetclean eq plus dishwasher: soap problem
clean the filters
Posted on Jun 19, 2008
iwillfixforu
  • 619 Answers
SOURCE: Maytag Jetclean Dishwasher EQ Plus, Model
You have debris down in the pump area. To get to the problem you will work from inside the dish washer and start by removing the spray arm and then using torx driver you will need to remove upper components of the pump/motro assembly to get to the debris. good luck
Posted on Feb 28, 2010
SOURCE: Maytag Jetclean Dishwasher EQ Plus - Lights flashing
either the control board or the control panel needs replacement. Most likely the latter. There is a possibility that both parts failed also. Usually water gets inside the touchpad, corroding and shorting the touchpad. Good luck
Posted on Mar 03, 2010
Users manual showing how to operate maytag jet clean dishwasher quiet plus
Good Morning Marion!
You can find installation and user guides for the Maytag Jetclean here
Maytag Jetclean Dishwasher (it's the Maytag site, and the page has several links to PDF files. The specific owners manual is at
http://www.maytag.com/digitalassets/MDB5000AWB/Use%20and%20Care_EN.pdf
Hope this helps, and good luck!
D
Nov 19, 2015 | Maytag Dishwashers
Maytag jetclean dishwasher eq plus
The best dishwasher soap we have found is Finish Quantum and they have good rinse aid too
Jan 24, 2014 | Dishwashers
Maytag eq plus dishwasher- how to disassemble bottom spray arm?
its probably leaving water in it and is clogged in the elecric pum or drain hose. somethins the pump has a rubber flap that will become lodged in the outlet port. this will cause dirty water to be left in the machine because of a slow drain. start by looking at the volume of water coming into garbage disposal where drain hose hooks up.
Aug 01, 2010 | Maytag Dishwashers
Mar 03, 2010 | Dishwashers
Maytag Jetclean Dishwasher EQ Plus, Model MD87100AWW making grinding noises 20 minutes into wash cycle.
Feb 28, 2010 | Maytag Dishwashers
Maytag eq plus, not cleaning properly, seems the
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
h
Feb 28, 2010 | Maytag MDB7100AWB Dishwasher
We lost power last night and this morning the maytag jet clean dishwasher is not working, does not appear to have any power. Is there an internal circuit or something?
there are internal thermostats or even an internal type fuse kit..... it is also common after power outages when you regain power that , that sudden jolt of electricity enters or circuits again it blows out electronics.... if u have an electronic control you might have blown that control board as well hope this helps
Jan 31, 2010 | Maytag MDB9600A Jetclean II Built-in...
Maytag dependably quiet plus not starting
check connections to the door switch.
Nov 04, 2008 | Dishwashers
No power to control panel after power surge
Try turning the curcuit breaker off for a few minutes. Turn it back on and see if it resets itself. If not, the outage may have shorted out the main control panel.
Sep 30, 2007 | Maytag MDB7100AWB Dishwasher
Maytag jetclean EQ plus dishwasher
I had the exact same problem. When the service tech came to look, my husband watched him. There was a disconnected wire to the motherboard which my husband asked can't the tech just reconnect it. The tech stated no, we needed a new motherboard. My husband reconnected the wire using tape for now & the dishwasher is working perfect. My husband is going to get somekind of calk/glue that will work permanently. This should save us from replacing the motherboard for a while. The dishwasher is only about 5 years old! My previous dishwasher was over 20 years old with no repair problems the over 10 years that I owned & used it.
I am looking for the self check test, does anyone know where I can find the instructions how to do it myself? Thank you
Sep 20, 2007 | Dishwashers
Dishwashers Logo
88 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
