Question about Samsung Refrigerators
The fridge won't stop beeping. Temperature is at 9 which I think might be the reason...
    Guru:
  • 1,524 Answers
Thermostat numbers usually 1-9 1 the warmest 9 the coldest.
Posted on Nov 13, 2010
Why is it beeping?
if temperature is rising, you will get a beep. you need to find why the temp rising. Clean condenser coils and make sure that condenser motor is running art full speed.
Sep 01, 2015 | Samsung RS275AC Refrigerator
My Westinghouse freezer has an alarm beep that goes off every now and then and the only way to stop it is to turn off the fridge completely. In the fridge section the temperature panel flashes the...
Often these have door alarms. If the door isn't completely sealed shut then it will alarm and cause the temperature/thermostat to blink to warn of "warm" temperature inside the fridge
Mar 04, 2015 | Westinghouse Refrigerators
Left door of F/P fridge part for a week. Now red light is flashing, beep stopped but fridge not cold enough.
Hello Jennifer;
My name is Peter. I am a retired field service refrigeration technician.
No. Your problem is not defrost.
The normal temperature setting for a freezer is -2 to +2 degrees F. or -18.8 to -16.7 degrees C. The fresh food section should be set at 35-40 Degrees F. or 1.6 to 4.4 degrees C.
Reset your temperature controls to the recommended settings.
Up plug your unit for 10 minute to power down. Plug your refrigerator in.
Jan 01, 2015 | Refrigerators
Frigidaire fgf379wjca wont stop beeping and diaplays door on control panel
When a cooling device starts beeping, see it as a warning it can't hold the temperature you selected. Could be the compressor does not work correct, could be it lost cooling fluid. If it keeps beeping, save the food by putting it in another fridge and start (or let someone start) finding out what is wrong. The door symbol is indicating the fridge thinks the temp rise is caused by an open door.
Jul 13, 2014 | Electrolux Dishwashers
Hi, I have a Bosch undercounter freezer and it won't stop beeping!!! All the lights flash whilst beeping, the lights are under the super freeze button, mute button and the temperatures. If I hold...
The beeping is a signal that the fridge has not got down to, or holding temperature... You may have a thermostat or gas system fault. Check and see that the fridge has actually got cold.
Jul 31, 2011 | 2007 Harley Davidson FLHX Street Glide
My westinghouse viruoso fridge keeps on beeping due to temperature drop - why is the temperature dropping. The fridge and freezer is not overloaded - there is good circulation in both. The fridge is barely...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Mar 30, 2011 | Westinghouse Refrigerators
Fisher & Paykel active smart fridge keeps beeping for no apparent reason, while door closed
press the select button ( the button that you choose the temperature on the fridge and freezer) and check that the fan on both fridge and freezer are working.
Nov 04, 2009 | Fisher and Paykel Active Smart® E522BR...
Fridge Temperature wont stop blinking
I had the same prob, you need to defrost it until No MORE water drips out of the drain pipes located at the back ( there should be 2 of them one for fridge one for the frezzer, make sure the rubber thing at the top of the pipe is not closed up- if it is cut it open ) when you think its defrosted place a cup under these pipes and leave it for a few more hours, if there is ANY more water in there your not defrosted yet and it wont work--- Leave the doors open of course, mine took almost three days and i live in a hot climate.
ok once you have done that, take the cover off for the main circuit board ( top of the fridge ) on the circuit board there should be a little black button with "test" on it hold that in and turn the fridge on. it should beep at you ( wait 5 sec ) then push it again ( beeps again, wait 5 sec ) push it again, you have to do it about 3-4 time before it stops beeping, when its stopped, just leave it, it should start up after a couple a mins.
the fridge will take much longer to get cold so be patient, if you find it flashing again push that test button, i just played round with mine and it came right, good luck, because the only other way round the prob is to turn it off at the wall and turn it back on.
Sep 28, 2008 | Samsung CoolTech Plus / Basic Bottom Mount...
Freezer temperature display keeps flashing
on the main circuit board on top of the fridge is a button with "test" on it. hold that in for a few sec, it should start beeping at you. push it again and it will beep again, do this about 4 time till it goes quite. this may fix it but the reason for it is prob your sensor is covered in ice, you need to leave it off with the doors open. there are 2 drain pipes at the back of the fridge ( bottom ) defrost it till no more water comes out of these, when you think its done, leave it for a few more hours and if any water comes out your not defrosted yet--- mine took almost 3 days.
Jul 29, 2008 | Samsung CoolTech Plus / Basic Bottom Mount...
Refrigerators Logo
95 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
