Question about Panasonic PanaFax UF-8000 Laser Fax
Sending an International Fax
We have tried several times to send a fax to our parent company in Japan, and we keep getting "Busy" on our fax confirmation print out. I've called the fax number from my desk and it rings and then their fax machine picks up, but for some reason our fax machine is unable to connect/talk to their fax machine. Is there a setting or a function we need to change? I've looked at all of the Fax Parameters and they don't seem to be the cause. Is there a setting/parameter which limits the number of digits the fax machine will dial (the Japanese fax # is 15 digits long, and US fax #'s are only 10)? Please help! Our owner is getting frustrated!
Thank you!
Kristen
  • 1 more comment
  • Knorthcott Jun 19, 2008
    Ok... but what setting is it? Where & how do I find it and change it to allow the fax machine to send international faxes to Japan?
    We don't beleive it's due to Network Issues or due to issued on the receiving fax machine. They receive multiple faxes each day for other companies in the US with out a problem, and when we send it, normally the Japanese office is closed so there would be minimal traffic. We've tried to send it for our other 2 UF-8000 fax machines (we have 3 in total) and the faxes are never successfully sent. We've had our phone system look a the fax lines and they don't have any filters installed on those phone numbers either.
    Also when we do a off hook dial so that we can here the fax machine dial the Japanese fax number, it dials it, it doesn't even ring it automatically gives a busy signal. But when we dial the fax number from our desk, it will ring 3 times and then the fax machine will pick up. We've called the fax machine seconds after the fax machine got a busy signal and it rings and the fax machine picks up.
    Sergeant:
    Champion:
  • 248 Answers
If your sure that your fax machine is working then the problem would be with the one you are sending a fax with or if not there might be some network problems.
Posted on Jun 20, 2008
  • 2,071 Answers
Just directly go to reset it out, or factory default try this option maybe of help...
  • 4,889 Answers
I have some questions for you.. Is this problem there since you installed the machine?If yes then it probably means a bad line... If you can try connecting it to another line or connect a different machine at the same slot.. Hope this helps..Let me know how it went so that i can provide further assistance...
Posted on Jun 19, 2008
  • 818 Answers
Http://www.seejapan.co.uk/visitor/general/telephones.html
see this
Sergio
    Genius:
  • 3,422 Answers
You can do a factory reset of this and then give it a try:
  1. "Function" key + "7" +"monitor" key 4 times +"* " to enter service mode by pressing key one by one.
  2. Select "Ram Initialize" by using "up arrow" and "¯ " and "set" key.
  3. Select "Flash memory clear"
Please don't forget to rate or accept the solution.
Goodluck..
    President:
  • 1,257 Answers
Just use the correct no to enter while you enter
for eg if your fax no is 23245678 then first add 00 and then country code for eg 97 then add the no to which you want to send the fax..so it will as 009723245678.
I hope this works .
Thanks for using fixya.
    Genius:
  • 1,036 Answers
If your phone number was 08-9999-9999
Then they would need fax to 0011-81-8-9999-9999
The machine should be able to cope with this. It may be due to the delay, and it presumes there is no response.
Try using unkook & dial from the fax machine itself if it allows this. Then send manually.
Failing that Panasonic customer support may know something we don't.
    Sergeant:
  • 275 Answers
I think may be the problem might be on the reciever side because you have mention that when you call from your desk it pick up which means that from your side its working. try after sometimes may be the problem is due to network traffic. it may also due to your fax machine problem. try to send it from another fax machine.
  • Gandhi Khwairakpam
    Gandhi Khwairakpam Jun 19, 2008
    just see the manual . if you don't have the manual then go to this link
    http://www.fixya.com/support/p202463-pan...
    check the settings
    manual for Panasonic PanaFax UF-8000 Laser Fax
    use the above words in the google search engine
    www.google.com
    Master:
  • 848 Answers
Definitely there is a setting which should be changed in order to send fax
  • 1 more comment
  • gopinath pasupathy Jun 19, 2008
    try this steps
    FAX CED Detect Enable: YES (Declare the call a fax call when it detects the CED - the 2100Hz high pitched long tone after CNG)
    FAX CNG Detect Enable: YES (Declare the call a fax call when it detects the CNG signal - the initial 1100Hz short beeping tone that is repeated every second, like a polling signal)
    FAX Passthru Codec: G711a (I've used G.711a instead of G.711u because G.711a has a slightly more dynamic audio range* See notes below)
    FAX Codec Symmetric: YES
    FAX Passthru Method: Re-INVITE
    FAX Process NSE: YES
    FAX Disable ECAN: YES (Enables Echo Cancel if FAX call is detected - dependant on above two CED & CNG detect settings)
    FAX Enable T38: NO (Had to take my VSP's T.38 out of service)
    FAX T38 Redundancy: 0
    FAX Tone Detect Mode: Caller or Callee
    Re: the G711a Vs G711u - G711u is a US/Japan standard for use over T1 trunks, G711a is a "rest of the world" standard for use over E1 trunks. Being that Australia is not the US or Japan, you find that E1s are used in circuit switched networks, as such the G711a codec is better compatible fit, as carriers do use G711a instead of G711u.
    Here are my results using T.38 and then not using T.38:
    Tests to Telstra TestFax Plus yielded these results (before / after)
    Overall performance: POOR / EXCELLENT
    Transmission Level: POOR / EXCELLENT
    Training Signal Quality: EXCELLENT / EXCELLENT
    Transmission Speed: FAIR / EXCELLENT
    Facsimile Image Transmission: POOR / EXCELLENT
    Recommendation: "Your facsimile service REQUIRES ATTENTION - Your facsimile transmission level is 7.3dB TOO HIGH" / "Your facsimile service is READY FOR USE"
    Image Resolution: FINE / FINE
    Image, percentage error free: 0.00% / 99.91%
    Short Image lines: 14 / 0
    Unknown G3 code lines: 52 / 0
    Image lines exceeding 32K pels: 226 / 0
    Long image lines: 10 / 0
    Transsmission level: -10.7dBm TOO LOUD / -17.7dBm EXCELLENT
    Line Noise Level - 54.8dBm EXCELLENT / -54.6dBm EXCELLENT
    Error Rate: 0 bits per 100,000 EXCELLENT / 0 bits per 100,000 EXCELLENT
    Sending speed: 7200 bits.sec V.29 / 14400bits.sec V.17
  • gopinath pasupathy Jun 25, 2008
    have you tried above steps
    if the problem is not solved better take to near by techician to solve it at earliest
Why won't the fax work?
My recommendation would be to hit the speaker button when sending a fax to hear why your fax wont go through.
When you hit speaker you should have a clean dial tone, then when you start dialing and the tone stops make sure you don't have any static or noise on the line.
There are several reasons you might get a NG error. One is the fax line you're trying to send to is busy. Maybe it's a phone line not a fax you're trying to send to. Maybe you need to dial a 1 or 0 for long distance, maybe your fax line has noise on it.
Using the speaker can help troubleshoot what the problem is.
Skelton Business Equipment Houston Copiers
May 08, 2014 | Sharp MX2610N Printer
How do you send a Fax?
1 Load the document face up into the Document Tray.
2 Dial the receiving party's fax number.
3 Press [Start/Copy].
The fax begins sending.
Note
If an error occurs during sending, the fax beeps intermittently for a few seconds and an error
message appears on the LCD. If this happens, correct the problem and then press [Stop], then
try sending the document again.
The fax automatically redials if the receiving party does not answer or if the line is busy.
Feb 21, 2011 | Canon FAX-JX200
When sending a fax I keep getting back a result "BUSY". I've tried a couple different numbers and always get the same thing. Faxes are coming in just fine.
The only thing that could stop you from sending a fax or not get a dial tone, would be the connection to the phone line. Make sure the telephone wire is plugged into the line jack and not ext jack of the machine, and should go straight to the wall, without splitters or extensions.
If you still cannot send a fax, try another wire or jack
Apr 05, 2010 | Brother MFC-7340 All-In-One Laser Printer
Difficulty sending a fax
Hello. Please make sure your telephone line is plugged into the correct outlet.
Most fax machines typically allow you to plug the line (the cord that goes from the fax machine to the wall jack) and and a telephone (the telephone connects to the fax machine).
In order to fax correctly, you must plug the line into the jack with a block (looks like a 'T') marked on it. Do not plug the line into the jack marked with a phone hand set marked on it.
http://gdlp01.c-wss.com/gds/0900002546/PIXMA_MP780_750_Easy_Setup_Instructions_EN.pdf
This shoulds in detail how to connect the line properly. For this printer the line cord must be plugged into the jack labelled "L"
http://gdlp01.c-wss.com/gds/0900002542/PIXMA_MP750_780_Quick_Start_Guide_EN.pdf
This will show you how to actually send the fax. On your PDF View select page 42.
Feb 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Error 401 & 634
error 634 is an indication that the line was either busy, or there was no answer on the receiving end.
Jul 23, 2008 | Panasonic Panafax UF-550 Plain Paper Laser...
Receiving error
Ok...so I fixed my own problem. I had printed out a system data sheet on my fax machine and found out that the "error" was in under sending confirn, so I went into my menu to the sending confirm section and turned it off. Then my boss tried sending the fax and it came through like nothing was ever wrong...I think the other day when my Iguana got in my office, he must have done something, as I found him perched on my fax machine....hmmmm. Thanks for the follow-up email.
Apr 09, 2008 | HP 1040 Plain Paper Inkjet Fax
Canon FaxPhone L 80 Busy
1-you must confirm that your phone line is clean and stable-and this is easy by test the phone line with another good fax if the problem exist.sure your phone line is bad and you connect with the phone company to get help.if the problem goen your fax is guilty.first try to opposite the phone wire from the outlet and change the phone connection with new one.if all above does not work you must send it to nearest workshop.
Mar 03, 2008 | Canon FAXPHONE L80 Laser
We can't send or received faxes
Just a suggestion. This effect can happen if you have plugged the line cord into the tel jack instead of line jack.
Oct 30, 2007 | Brother IntelliFAX 2800 Laser Fax
Panasonic PanaFax UF-8000 Laser Fax Logo
114 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
