Question about Refrigerators
How to recharge refrigerant - Refrigerators
    Guru:
  • 1,524 Answers
Must be EPA certified to perform this task. Also equipment needed ie vacuum pump, torch, gauges,scale.
Posted on Nov 13, 2010
Can a compact refridgerator be recharged
Yes, but you have to understand that if it needs recharged, it has a leak and must be found, repaired, evacuated then properly recharged. Most compact reefers only hold a few ounces of refrigerant, so it does not take much of a leak to affect its ability to cool....Your issue could be something other than refrigerant if its just not cooling.
Jul 14, 2014 | GE SFR03BAZBB 3.2 Cu. Ft. Compact...
Freon leak recharge
Video how to replace evaporator 1 door refrigerator.
Mar 30, 2014 | Danby DKC645BLS Compact Beverage Cooler
On the dashboard of my 99 deville it says a/c off low refrigerant. how do I turn the ac back on to recharge ? thank you ...
You will need to recharge it to get it to come back on, it has a pressure switch that will prevent operation until the level is brought back up to normal.
Jun 26, 2011 | 1999 Cadillac DeVille
Can I recharge the refrigerant myself? or do I really need to call a pro?
You need a pro; unlike a car AC, there is no nipple provided for recharging the system, it must be cut open and soldered shut. Probably $100-150 US.
Mar 20, 2011 | Maytag MSD2756G Side by Side Refrigerator
What weight of freon i need for recharge hot point refrigerator compressor
Here is a tip that I wrote about recharging refrigeration or air conditioning...
How to add Freon to a Air Conditioner or Refrigeration System
heatman101
Sep 03, 2010 | Refrigerators
How I can recharge the gas for this refrigator ?
Here is a tip about recharging refrigeration units that you need to read...
http://www.fixya.com/support/r5638346-add_freon_air_conditioner_or
heatman101
Aug 19, 2010 | Sanyo SR-3660S Compact Refrigerator
Has leaked out all 'gas' from the cannister to the down tube. Can this be repaired and recharged?
If by 'gas' you mean refrigerant, then yes, it can be recharged. However, in order to legally recharge a refrigeration unit with refrigerant you need a special certification from the EPA. I recommend you get a certified technician to take a look at your refrigerator
Mar 23, 2010 | Dometic RM2620 Refrigerator
Same problem
I had the same problem. The thing is you need to have the air on while you're recharging it and the compressor won't turn on. I was able to recharge the air by disconnecting the positive battery cable and reconnecting to reset the computer and immediately have someone inside the vehicle turn the air on before the computer can recognize that the refrigerant is too low and disable the compressor again. This will allow for the compressor to turn on and for you to recharge the air. Make sure that you have the replacement refrigerant connected before you turn the ac on so the refrigerant goes in and keeps the compressor on before the computer catches it again.
Jun 23, 2009 | 1997 Cadillac Seville
How to recharge refrigerant, can a car refrigerant canister be used?
There is an information tag probably on the back of the unit that tells you model number, serial number, manufacturer, etc. On the same tag it will tell you the refrigerant and the amount of refrigerant in the unit. If it is R-134a ( which is probably is) then yes it is the same refrigerant used in vehicles. However, legally you must repair the leak before you recharge the unit. You can buy the cans and adapters at an auto parts store.
May 02, 2009 | Heating & Cooling
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
