Question about Culligan Sediment Water Filter
I have a house filter system. It has been cleaning itself or whatever it does for several hours now. The screen shows E1. This has happened before, and I know there's a fairly simple way to fix it, but I don't remember. How do I reset it?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Culligan Expert
  • 306 Answers
Unplug it for 1 minute and plug it back in. You will need to reset the settings after ward. The valve is sticking in position and running to drain. A typical regeneration will take about an hour and forty five minutes. You need to call Culligan it probably needs a new sealpack.
RJ,
Posted on May 20, 2011
My air conditioner showing on the display is E1
The E1 Error Code The most common reason for an E1 error code to be displayed on your air conditioner's front panel is to remind you that the unit's air filter needs to be cleaned. Many models will automatically notify you of this via an E1 error code display after the unit has been operated for a predetermined number of hours. For example, many Sharp models will display an E1 code after 720 hours of use. Alternatively, you could have dirt or moisture in your front button controls, causing them to stick or not function properly. This can be a common problem with many models of Haier air conditioners, but the issue is not restricted to any one manufacturer. Your air conditioner could also have a defective thermistor, which is part of the thermostat.
For Samsung, the room thermistor needs replacing. This is a device that senses the temperature in the room.
How to Fix an Air Conditioner When It Gives You an E1 Code eHow
Jan 24, 2016 | Heating & Cooling
Comfort Control Center 2. Why is E-1 error displayed?
[PDF]Customer assistance for air filters cleaning (E1 code)
www.sharpusa.com/.../air_man_AFS100FX_S120FX_S125F...
Sharp SolarCustomer assistance for air filters cleaning (E1 code) on Sharp Air Conditioners. The display will indicate an E1 code and not allow the unit to operate until the ...
Sep 08, 2015 | Dometic Rooftop RV Air Conditioner
How to fix samsung washing machine model TORNADO 7.0kg WA90B error
E1: Water Supply Error
-Display Shows 'E1'
-Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the water level presetting for 20 minutes or more at the time of initial water supply.
-To help fix this problem please check the Hot and Cold water intakes, there is a filter screen in each input valve, remove and clean these filters. ** Make sure you replace the filters, they are very important for the operation of the Washing Machine.**
-The error status can be cleared by turning POWER S/W OFF and resuming the POWER ON initial status.
Nov 01, 2012 | Washing Machines
Error E1 samsung washing machine model TORNADO 7.0KG WA90B
-Display Shows 'E1'
Keep me posted!
E1 shows and i unplug the unit and it will run for about 2mins and shut down with e1 showing
The E1 error code indicates that the air intake filter is dirty or clogged and needs to be removed and cleaned. Turn the unit OFF & unplug it, before removing the filter. Never operate the unit without the filter in place. Doing so, can damage the unit.
Hope this helped you & thanks for choosing FixYa.
Sep 20, 2011 | Haier Heating & Cooling
LG 3 in 1 Dishwasher model LD2131SH showing E1, leaks water
e1 is a leakage error. you will have to find where it is leaking from...crack hose .crack motor assy.. water must be leaking
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Sep 11, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Panasonic KX-TG2258 with E1 ERROR CODE
I was having that problem after cleaning the base and handset. It seems to resolve itself simply by disconnecting the power supply and possibly the phone input line for several hours. I reconnected my phone and it works again.
Apr 14, 2009 | Panasonic KX-TG2382B Cordless Phone
Lint Filter Light comes on and cycle is interupted
Depending on how old this is or how much it is used depends how much lint has built up inside
the air flow tube. I have seen where you look inside where the lint screen is and beneath it with screen removed there is nothing but lint, in which case the dryer thinks the screen is clogged. You might have two screws on the inside of the drum that hold the screen holder in place. First remove the lint screen
and hold the little door that closes when you remove the screen, open the little door and look down inside it with a flash light, if you see a lot of lint, like I said you might be able to remove the holder
and clean this area out, also take a coat hanger and bend a little piece at the end and use this to get most of the lint out of this area and the tube that Leeds down from this area. If this can be done
and you get this area clean and it still happens, you might have to clean the entire area the tube
and the back tube,the tube leeding to the outside of the house and vent. Any questions please post back.
Mar 27, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Trouble shooting problem, Please help!
probably a programming issue ( in a board or something ) might need to call a tech to come out or take it to a shop. under warranty?
Aug 14, 2008 | Heating & Cooling
"Cool" mode shuts off
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The owners manual says to clean the filter and unplug the unit, then plug unit back in and code will be reset. However, a User review stated that his code was not reset until he followed a fairly simple routine. "Unplug the unit. Hold down the power button and plug back in. Wait to hear a "beep" and then unplug it again. Plug unit in again and it should restart without E1 code."
Aug 03, 2007 | Sharp AF-S85FX Wall/Window Air Conditioner
Culligan Sediment Water Filter Logo
153 people viewed this question
Top Culligan Measuring Tools & Sensors Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Culligan Measuring Tool and Sensor Expert? Answer questions, earn points and help others
