Fisher tad 994 stereo wil not load cd's M ERROR i unplugged it to reset per manual, no results
SOURCE: Fisher TAD-5024
YEP IT IS ******** AND I WASTED MY MONEY ON IT
Posted on Jun 15, 2008
PyroPCMan
  • 405 Answers
SOURCE: How to reset the stereo system
To reset remove your negative battery terminal and leave disconnected for a few moments, re-connect negative terminal and you are reset.
Hope this helps
Posted on Jun 27, 2008
SOURCE: cd player
i need part # 6142539071 for fisher tad 993
Posted on Jul 29, 2008
VOTIT
  • 2071 Answers
SOURCE: m-error
If for some reason you would opt for user performed action, then pls try:
1. reset, unplug from the mains for at least an hour and try again;
2. check if there is a slide switch of some sort at the rear of the unit;
3. check if there may be a pinhole somewhere along the bottom of the loading tray where a blunted point safety pin maybe inserted;
4. open the top cover and manually eject the tray;
5. check internally if there is a mechanical problem such as a slipping/cut belt, gears that do not mesh correctly;
6. if the unit has been in use for some time, it may simply need cleaning and re-application of lubricant in the mechanical assembly.
The slider mechanism, depending on the age of the unit and , consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Posted on Sep 06, 2008
SOURCE: fisher tad 5060
the only way to reset a error disc is to unplug the radeo and push air dust the cd mech and lens then push the lens all the way back plug the power cord the, turn on power it should reset itself , i had same problem before and it work.
Posted on Jul 21, 2010
M-error message on Fisher studio 24 tad-9715 how do you reset or fix this so it will play cd's again
TAKE COVER OFF THERE IS A MEMORY RESET BUTTON ON THE LEFT SIDE ON LOWER BOARD
Dec 21, 2012 | Fisher 9925 Shelf System
I HAVE A FISHER TAD-9415 SYSTEM AND THE CD WONT
hope it is not too late but have had the same problem, just got around to open up the case and found the problem and was able to fix mine and now it plays fine. My problem was with the cd turn table it was not be feeding the cd into the player causing the m-error..
Dec 07, 2009 | Fisher 9925 Shelf System
Don't rember how to operate
I bought a new Sony Bravia Home Theater System, if anyone out there has a manual for the Fisher I would still like to have as I have the Fisher Unit up for Sale
Thank You
Joyce
Oct 11, 2009 | Fisher Audio Players & Recorders
Fisher radio TAD-9415 made in 1995
Check firstly, if your radio is Fisher Tad-9415 you are in ****! The only chance which you have it is to make it repaired by the company. The price of repairing: $750 us address I do not know it. Sorry. But, keep really because the casset reader and the radio FM always works. I would pay $1000 us to renovate this radio if I was you! I hope that you is not too much over! Three million times sorry.
Dec 01, 2008 | Fisher 9925 Shelf System
Fisher Model TAD-993
On my Fisher model TAD-993, when I press load/eject button the screen reads m-error, do you know how to cure this
Oct 05, 2008 | Audio Players & Recorders
Cd player
Jul 09, 2008 | Audio Players & Recorders
Fisher TAD-5024
Mar 15, 2008 | Audio Players & Recorders
Fisher tad 5060
Nov 09, 2007 | Fisher Audio Players & Recorders
232 people viewed this question
 Grubhead
Grubhead
