Question about Sport & Outdoor - Others
Pro power lay flat home gym have no idea how to connect cables and pulleys to the frame.
How do i take slack off the cable ?
Hi, I do not have this unit however google search gives up : http://www.scribd.com/doc/93058121/PRO-POWER-Lay-Flat-Home-Gym-Inst-DI-v-08 assembly and use manual, hopefully the correct one. If so pay careful attention from pp23 onwards to the threading of the cable(s), and that they had not slipped off and be jammed beside the pulleys. Details of adjustment are given. Good luck. Les.
May 12, 2014 | Pro Power Exercise & Fitness
I need a diagram for pro plus pulley system
Are you talking about the Bowflex Power Pro? Follow that link to look at diagrams of the part. If that's not the part, look at the machine for its model number and search for it on FitnessRepairParts.com, there are thousands of other diagrams freely available to look at which we may help you.
May 28, 2012 | Exercise & Fitness
I need set up instruction manual for pro power lay flat gym
Need help with image pro 11 multi gym need the instructions have lost them?
Apr 24, 2012 | Pro Power Exercise & Fitness
Pro power horizontal and vertical instructions
Pro Power Horizontal and Vertical Multigym. i have lost how to attatch the cables does anyone no if so email me at reeder2008@hotmail.co.uk
Jan 18, 2012 | Exercise & Fitness
Weider pro home gym 355 - the cable that comes up from the bottom pulley, to what does it attach? and how does it attach?
FitnessRepairParts.com has diagrams that may be helpful. For example here is the diagram for the WEBE35560. If you cannot determine where things go from the diagrams you may be able to find a manual.
Aug 16, 2010 | Weider Nutrition Pro 2000 MultiGym
Weider 3650 home gym. Delay on the weights dropping back down.
With weider pulleys you will find that either the little retainer L shaped piece has moved on one or more of the pulleys or the pulleys are scraping against each other.<br />The plastic coating on the cables will start to show wear or you will be able to feel it in a while.<br />Also check to make sure the cables are around all the pulleys, and have not shifted to the shafts.<br />
Apr 17, 2010 | Weider Nutrition Weider WEBE8077 Home Gym...
Lost instructions for my pro power lay flat multi gym any help please
got the instructions in pdf format if u email me i'll share them
ryjaza@hotmail.com
Jan 25, 2010 | Exercise & Fitness
Lost pro power multi gym instructions
How do set up the wires for a pro gym multi gym
May 03, 2009 | Exercise & Fitness
Instructions lost for my pro power multi gym
also having the same trouble, could anyone email the instructions over if they have a copy plz, many thanks, diamondgeyzer@live.com
Apr 09, 2009 | Power Systems Exercise & Fitness
Weider home gym maintenance
about every month, i spray the pulleys with WD-40 and then spary it into a cloth that I use to wipe the cable covering...my gym is 4 yrs old, sits out on my covered back porch and the cables and pulleys are like new
Mar 16, 2009 | Weider Nutrition Weider WEBE8077 Home Gym...
Sport & Outdoor - Others Logo
220 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
